Page 2 of 3 1 2 3
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: 408strokerdart] #357376
06/27/09 07:27 AM
06/27/09 07:27 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
11bs here on 12" wide wheels.1.25 60
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: bigtimeauto] #357377
06/27/09 08:11 AM
06/27/09 08:11 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We've recently changed over to stiff sidewalls. Only did 3 passes before hurting the motor but I can tell the car did not like 11.5 psi in them (on my gauge). Car squirmed around a lot from the startline. We started @ 12.5 and went down. Next time out we'll start there and go up, tyre was wadding pretty bad in hindsight. Got a 1.41 60ft but track wasn't there, so everyone was saying, so it sorta equalled the non stiff wall slicks given the conditions. I think the normal slicks are a bit more forgiving when it comes to pressure.
We still run ours with tubes too, is this right?
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: Tig] #357378
06/27/09 08:18 AM
06/27/09 08:18 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I run Tubes in ours they are recommended by the manufacturer.
sounds like you need more air pressure.
does your rim width match the tire width?
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: Rodney] #357379
06/27/09 08:34 AM
06/27/09 08:34 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
This is a pic of a 9.81 @ 138, 1.41 60ft run. Tyres are @ 12.0 psi. Rim is 10 inch.
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: Tig] #357380
06/27/09 08:46 AM
06/27/09 08:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You should always run as much air pressure as you can
without spinning.... gives you better MPH
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: MR_P_BODY] #357381
07/13/14 07:55 PM
07/13/14 07:55 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Did a google search on this topic and this thread came up I know this old but instead of starting an new one thought I'll give this a interesting replies here fellas...........
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: 408strokerdart] #357382
07/13/14 10:28 PM
07/13/14 10:28 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
i run a m/t 29.5 10.5 S wall 12.5 psi warm. 3950lb 68 dart.i think i picked up about 3or4 hun with the stiff wall. and yes i run tubes.i was buying two sets a year.and replace in them at about 75 to 90 passes.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: 408strokerdart] #357383
07/13/14 11:53 PM
07/13/14 11:53 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Bye far the most popular tire on the east coast 12.5 psi.Brian one day try the MT pro radial and become one of the men that all smile at how smooth it feels and the tenth they all pick up
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: racerx] #357384
07/14/14 12:08 AM
07/14/14 12:08 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
i run 28x10.5'a stiff with a 12in. wheel no tube's at 14.5 lbs.
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: 408strokerdart] #357385
07/14/14 02:19 AM
07/14/14 02:19 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve got those on my car now and although I havn`t hit the track or street raced yet, they sure try to hook on the street rollin along and sabbin it in second which is better than the QTP`s. I know that doesn`t help but they are sticky AND stable driving around on the street........
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: WHITEDART] #357386
07/14/14 08:18 AM
07/14/14 08:18 AM
Mo.
racerx Offline
racerx  Offline
Mo.
If all possible can you guys give the spec.(60',et.,tire pre.)
The reason I'm asking is my car has been as fast as 140.93 mph with a best et. of 9.56,with a 1.38 60'(with the stiff sidewall tire) looking at Wallace cal. that mph. should be 9.40's it has been a best of 1.28(but that was with a w-tire@9.5lbs)it seems to be dropping off at the 330' on .............Thaxs fellas
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: racerx] #357387
07/14/14 10:26 AM
07/14/14 10:26 AM
Out West
408strokerdart Offline OP
Out West
The reason I'm asking is my car has been as fast as 140.93 mph with a best et. of 9.56,with a 1.38 60'(with the stiff sidewall tire) looking at Wallace cal. that mph. should be 9.40's it has been a best of 1.28(but that was with a [Email]w-tire@9.5lbs)it[/Email] seems to be dropping off at the 330' on .............Thaxs fellas
If it is dropping off from the 330' on I would look somewhere other than the tires.
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: 408strokerdart] #357388
07/14/14 10:43 AM
07/14/14 10:43 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I put 10,5 Hoosier stiff walls on my Dakota this year. It hates them, nothing I can do will make them work. Truck weighs 3400 with me in it, but 500 lbs heavier on the nose than the rear.
I've battled them for the last weekend, they are coming off tomorrow in favor of the regular side wall Hoosiers. My 60' is down, my ET is down but I sure love the way they launch, I just can't make a full pass on them, the rear end starts to skate around going down the track, but our track has some serious issues too.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: 408strokerdart] #357389
07/14/14 10:52 AM
07/14/14 10:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
... could be over reving the engine on the
top end.. if you put on a taller tire might do it or
a gear change... this is just a guess if you are over
reving... I know I am a little.. I run a best 60' of
1.19 but the normal is a 1.21 and 8.96 at 152 best but
normal is 9.01 at 150... I know my cam is way short
on lift
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: MR_P_BODY] #357390
07/14/14 12:15 PM
07/14/14 12:15 PM
Renton Washington
Triple Threat Offline
Renton Washington
12.5-13.5 for me with the 3062W, shares the same sidewall. No more radials on yours?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: Triple Threat] #357391
07/14/14 01:52 PM
07/14/14 01:52 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
We normally run 315 radials, but when we DO run slicks, we run the tire the OP is asking about. Our car race ready is about 2800lbs on slicks. They are mounted on beadlocked 12" wheels and we DO run tubes. We normally run them at 12-13 psi at that weight. A heavier car will need more or it will absolutely CRUSH the sidewall at the hit
Remember....MORE air, puts MORE rubber on the ground because it flattens the tire out and stiffens up the sidewall. Low air, lets the tire "cup" in the middle and has less rubber on the ground.
We have been 1.09 in 60ft on this tire and 4.30s in the 1/8th at 173+
A high hp car that hooks hard and crushes the sidewall will beat the sidewalls out in short order. Our slicks are DONE for us in 12 passes, but would still be fine for lower hp stuff.
Monte
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: Triple Threat] #357392
07/14/14 08:53 PM
07/14/14 08:53 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
This post is from 2009 and do believe he runs radial slicks now.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: Monte_Smith] #357393
07/14/14 08:55 PM
07/14/14 08:55 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Monte
How many runs do you get out of a radial?
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: 1967dartgt] #357394
07/14/14 09:06 PM
07/14/14 09:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Until they are slick and I just feel like we need new ones........LOL!!! Ones on the car now probably have 40 or 50 licks. Even on the radials, we usually beat the sidewall out before the tread is done. We are light on burnouts. Killing the tire on the burnout does you NO GOOD. With the car just sitting there, slicks or radials and I can see lines in the sidewall where they have been wrinkling......off they come.
Monte
Re: Anyone run M/T 10.5 stiff sidewall slicks? [Re: Monte_Smith] #357395
07/14/14 09:07 PM
07/14/14 09:07 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Wow you have any experience with the pro's?
Page 2 of 3 1 2 3
