Re: 440 six pack - running hot - why
[Re: JSSuperbee]
#356189
07/31/09 12:29 AM
07/31/09 12:29 AM
Posts: 18,166 Mass
DAYCLONA
Mass
Jim, If you'd like, try this, won't cost anything but time, and a little gas,.....if you have a standard radiator cap, not one of those snap locking rad caps,.....check the fluid level in the radiator, put the cap on, tighten it, then back it off to the point were its loose, but can't be removed unless you fully depress and turn it past the locking tabs, the point were it's ready to be removed, but just flops around, leave it like this, start the car, let it warm up, slowly rev it, causeing the overflow tube to purge what fluid it don't need for top tank volume, usually 1 inch below the filling neck,.....if the car is running within temp, take it out for a drive, reason for keeping the cap loose is for pressure not to build in the ststem, as you drive you may purge some fluid out the overflow as engine RPM increases,.....post your results with this test if you would please Mike
[Re: DAYCLONA]
#356190
07/31/09 07:03 AM
07/31/09 07:03 AM
Posts: 533 Williamsport, PA
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Then Mike said try Zerex G-05. Crossed my fingers and drained the Prestone and put in the Zerex. No good. Still idles as about 210 degrees with an outside temperature at a below normal 82 degrees.
Did you dilute the Zerex-05 with distilled water and secondly did you add a bottle of water wetter?
[Re: Rob440Magnum]
#356192
07/31/09 10:11 AM
07/31/09 10:11 AM
Posts: 1,527 minnesota
Kirby
minnesota
Running without a stat can cause the motor to run hotter because the coolant never stays in the radiator long enough to be cooled.
After all the different things you recently tried, you may want to put the stat back in and see how it works now.
That is exactly what I was thinking- You pretty much have to have a stat in there, it constantly opens and closes to keep the water in your radiator long enough to cool it, then opens a bit and closes back and forth. With out one, your system is just going to heat up to a certain temp without regulation.
[Re: Kirby]
#356193
07/31/09 03:30 PM
07/31/09 03:30 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Two things:
1) Question I need answered - Does drilling the thermostat 1/8" really help keep the temp down?
2) Years ago my dad was changing freeze plugs and dropped one in the water passage of the block; He said car developed a "hot Spot"? and it always ran hotter after that incident. It was a chevy small block if that matters.
The reason I mention this is the remote possiblity that someone at some point might have left an old punched out freeze plug in the block or head causing a small blockage?
I'm not as knowledgable as some of the previoius posters here on this tgopic, but I thought this might help.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
[Re: DAYCLONA]
#356195
07/31/09 04:54 PM
07/31/09 04:54 PM
Posts: 328 Missouri, U.S.A.
JSSuperbee
Missouri, U.S.A.
Mike:
I'm taking the car out tomorrow night to the local cruise spot. I'll try leaving the radiator cap 1/2 on and loose and let you know. However, the radiator tech did fill the radiator to within about 1 inch from the top yesterday.
James Stinebaker
[Re: DAYCLONA]
#356197
08/01/09 09:46 PM
08/01/09 09:46 PM
JSSuperbee
Missouri, U.S.A.
Mike:
Just got back from the cruise. I did like you said and loosened the radiator cap one notch so it was still on but loose. When I got to the cruise spot it wasn't running hot but it was purging coolant out of both the overflow hose and the radiator cap. About a pint was pushed out on to the ground.
James Stinebaker
[Re: JSSuperbee]
#356198
08/01/09 11:13 PM
08/01/09 11:13 PM
Posts: 18,166 Mass
DAYCLONA
Mass
Mike:
The radiator was "adjusting" fluid level due to Engine RPM, heat expansion, etc
Jim, the reason I asked you to do that "test", and I would repeat another driving run to see if the car overheats, you say it didn't overheat this time, was it at "operational" temp, what was the highest temp you hit?......on the next run, check the fluid level, if you can see it in the radiator, don't add anymore, make sure you have enough fluid in it though, the engine running with the cap loose, purged what it didn't/couldn't hold at full level,.......I had you do this Jim, because I suspect several things, leaving the cap loose, dosen't allow the system to pressurize, I suspect you have a bad head gasket(s), or a cracked head(s), and the exhaust is pressurizeing and heating the cooling system, I've seen this before, in severe cases the cooling system appears to boil over and spew at normal operation tempatures, I 'll assume your running a 14-16 lb cap,........if you were to run a 5-7 lb cap, I'd suspect you'd boil over/spew the system even at a nominal running temp,......what happens is the exhaust gas in the pressurized, and capped, cooling system creates a steam bubble, and prevents the fluid from moving thru the cooling system, so temps go up, pressure builds, eventually spewing,.....buy keeping the radiator cap off slightly, you alow combustion gases/pressures to vent to the atmosphere
run the car a few times up to temp with the radiator cap "loose", if no more overheating/spewing happens, try a 5-7 lb cap, if it overheats/spews,....my money is on the heads/head gaskets,.....I've worked on an engine that had similar problems once, blew 2 head gaskets, would overheat with the cap on, but off was fine, the culprit I found was the machine shop had inserted a block dowl for the head upside down, the tapered end should have been up, the barrel end was holding the head off the deck and gasket by ever so much, it didn't allow the head to fully compress the gasket, resulting in a leak, causing a pressurized cooling system, I've found that you can pressurize a cooling system without having the usual symtoms, like oil in water, or water in the cylinder misting/plumeing out the exhaust, etc........you said the engine was rebuilt?, low mileage, after intial break in, did you retorque the head bolts?....if not, you might get lucky, and try that, you "might" solve the problem, if it's the gaskets,( if they aren't damaged) if it's cracked head(s),.....you know the drill, you might want to have a leakdown compression test done on all the cylinders to pinpoint a cylinder, or bank, or which head, if that's the case,......this is my honest opinion as to what I would suspect, and approach as being the possible problem, from past experience with it,....but keep in mind, I'm on a computer,....not under the hood, hands on, on your car, I can only "see" what you tell me
Mike
PS,...Has your "radiator guy" used an exhaust gas detector to check/take reading for spent exhaust in the coolant/radiator?
[Re: DAYCLONA]
#356199
08/02/09 04:41 PM
08/02/09 04:41 PM
JSSuperbee
Missouri, U.S.A.
Mike:
As I mentioned before....after I put black duct tape around the shroud, the engine runs cooler. At idle and outside temperature of about 82 degrees it idles and maintains a temperature of about 210 degrees. I had just gotten off the highway and drove about 1/4 mile to the cruise spot and the temperature was normal. The needle showed mid way on the gauge. That's probably 195 to 200 degrees. I got out of the car and coolant was running out on the ground. The next run will be Friday afternoon for another local cruise about 10 miles away. The reason I don't think I have a cracked head is because the engine rebuilder did a magnuflux check. You're right....I'm running a stock 16lb. cap. I had the coolant checked twice for combustion gasses and both times proved negative so it would seem that the Fel Pro head gaskets are'nt leaking. The radiator tech suggests getting 600 miles on the newly rebuilt engine and then returning to his shop for more tests. I've got 203 miles on it now. Also, the thermostat has been removed. Here again, it seems to now be holding its own at about 210 degrees at an idle. Maybe I can live with this. Some say putting a Miloden 180 thermostat in it will cause it to run cooler. I was going to wait until I had the 600 miles on it before re-installing a thermostat. At the cruise last night a couple of guys gave me the names of so-called experts to take the car to. I figured that may be a good idea since what ever is making this car run real sluggish may be what is causing the warm running condition (no longer completely overheats after installing the duct tape around the shroud). I did not retorque the headbolts....thought I would run that task by the experts when I take it to one of them. I would think they would also do a leakdown compression test. I'm printing your last post to take to either expert for their review as your input seems helpful and contains some probable causes. Since I hi-jacked this thread...maybe I should PM you with the results of the next test that you suggested.
James Stinebaker
[Re: THESHAKERPROJECT]
#356203
08/03/09 09:06 AM
08/03/09 09:06 AM
Posts: 2,821 Sobieski Wi
bee1971
Sobieski Wi
Did you ever pull any spark plugs from each head to check color/appearance ??? - Lean condition at idle / cruise condition like so many others have mentioned
I agree on the thermostat 160/180 milodon high flow - Has to bee in there
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#356204
08/03/09 04:43 PM
08/03/09 04:43 PM
JSSuperbee
Missouri, U.S.A.
A couple of weeks ago I took it to a profesional engine tuner and he pulled a plug from one head and said it looked perfect.
James Stinebaker
[Re: SomeCarGuy]
#356205
08/03/09 04:48 PM
08/03/09 04:48 PM
JSSuperbee
Missouri, U.S.A.
I ordered a 180 high flow Miloden stat from Year One about 1/2 hour ago. They said it would take 2 weeks to get it. Right now the Zerex G-05 and water wetter are in it from when Mike suggested it. Ill be leaving that combo as is. In a couple weeks I'll be able to perform that test.
James Stinebaker
