440-1 Verses 572-13 Heads--Flow Sheets Required..
#355932
06/23/09 06:07 PM
06/23/09 06:07 PM
Posts: 1,416 Lake Charles,Louisiana
BILLYJAY
Ok,,Here we go again..i am looking for flow sheets on the 440-1 verses the 572-13 CNC"d Heads only... Not interested in what someone told you.. post your FLOWSHEETS for either head..Only limits are these are CNC"d pieces with flowsheets ONLY !!!! i am hearing ray Barton is getting over 400cfm on his 440-1 heads and would like to compare to the 572-13 heads..my -1 heads are flowing 386 & 389 @.800..***********************************************************MY FLOWSHEET IS ATTACHED***********************************
Re: 440-1 Verses 572-13 Heads--Flow Sheets Required..
[Re: BILLYJAY]
#355934
06/23/09 07:00 PM
06/23/09 07:00 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Flow sheet not scanable [7-28-99]. 440-1 early head. 2.25 x 1.81. int.385@.800 ex.295 Cost $350 back then to port!!
The little old lady from Pasadena is back!
[Re: Barnstorm]
#355935
06/23/09 08:12 PM
06/23/09 08:12 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Here's my -1 flowed on 2 different benches One is Modern Cylinder Head (MCH) and Dwayne Porter (PRH). Jeff's the exhaust is with an extension, Dwayne's are not. The motor made around 850 HP. BTW, they were hand ported by Barton, All Jeff and Dwayne did was flow them and freshen them
[Re: Bigcube]
#355937
06/23/09 09:47 PM
06/23/09 09:47 PM
BILLYJAY
hey BigCube..your numbers look alot like my cousin's 440-1 that were hand ported by Larry Meaux down in Abeville,La. they were 367@.800 but he has since gone to the 572-13 but didnt get a flow sheet when he bought them...next time we pull his 557Indy Maxx motor down we are going to have them flowed...we were trying to compare how much more air these 385cc heads flow over the 345cc heads..if it is worth the extra money...other than being able to run a bore over 4.5 i dont see what the advantage is...or should i say i dont think the difference is worth the 2100.00 cost between the -1's and -13's...
[Re: BILLYJAY]
#355938
06/23/09 09:58 PM
06/23/09 09:58 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
kenny at indy told me the biggest differnce between the two are the 13* valve angle.he also said they moved the valves around on the 572-13,s.thats why they use there own jessel rockers and stands.they are differnt from -1,s.he also said on a 4.5" bore or larger the 572-13,s will out perform the -1,s.laying the valves back he said really helps to unshroud them.
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Bigcube]
#355941
06/23/09 10:37 PM
06/23/09 10:37 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
My Flow numbers are Identical to hilbillyconquest numbers, cause they are ported and flowed on the same bench. Indy CNC 440-1's in a tube chassis car, and the switch to Indy's 572's were worth less than a tenth NO OTHER CHANGES. Engine was a 572 inch Indy maxx block motor with 14:1 compression running a 4" toilet alky injected...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
