Small block oiling (plumbing) question #349736
06/17/09 05:46 AM
06/17/09 05:46 AM
Uppsala, Sweden
Satanized_68 Offline OP
Uppsala, Sweden
I'm really tired of fighting the headers to change my oil filter and I'm going to relocate it to the motor plate.
I have a Hamburger's spin-on adapter...
...and a Hamburger's oil filter mount...
Now for the the plumbing question. Can I just use the "out" from the adapter to the mount and from there directly to the front of the engine block and plug the "in" in the adapter? It's already drilled and tapped in the front of the block but is plugged right now by a NPT plug.
I'm not really sure if this is the preferred way to do it or if I should route the hose back to the adapter? It would make a much cleaner install if it's possible to route directly to the front of the block...
Any input on this is greatly appreciated!
//Mike
Getting closer... <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Small block oiling (plumbing) question [Re: Satanized_68] #349737
06/17/09 07:26 AM
06/17/09 07:26 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Yes, that is the main oil feed on the SB and conveniently
tapped on some R-blocks.
Re: Small block oiling (plumbing) question [Re: S/ST 3040] #349738
06/17/09 08:07 AM
06/17/09 08:07 AM
Uppsala, Sweden
Uppsala, Sweden
Thank you!
Just to make it idiot clear (for me ) ...this is the oil coming from the oil filter and returning to the block? The tapped hole will be the "returning" oil and not the "output" pressure going to the filter?
I don't want to turn the key and have no oil pressure
Re: Small block oiling (plumbing) question [Re: Satanized_68] #349739
06/17/09 08:10 AM
06/17/09 08:10 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
you could also pull the distributor and drive gear and prime the engine with a priming tool and drill motor before starting the engine.
Re: Small block oiling (plumbing) question [Re: Satanized_68] #349740
06/17/09 09:05 AM
06/17/09 09:05 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
This is a R3 block install
Re: Small block oiling (plumbing) question [Re: Satanized_68] #349741
06/17/09 09:29 AM
06/17/09 09:29 AM
S/ST 3040 Offline
S/ST 3040  Offline
Tap the pressure passage. ( blue )
Plug the other two. ( red )
Pressure goes to your adapter marked IN
OUT goes to the main oil feed.
Re: Small block oiling (plumbing) question [Re: S/ST 3040] #349742
06/19/09 01:30 PM
06/19/09 01:30 PM
Uppsala, Sweden
Uppsala, Sweden
Thanks for all your help!
Just one more question...or more
Why would I need to plug the hole marked in white?
Wouldn't it just be ok to plug the "in" in the adapter that sits in the original place for the oil filter (see the top photo in 1st post).
Then from the "out" from the new oil filter mount (2nd pic) I would put the line directly to the tapped hole in the front of the block.
Re: Small block oiling (plumbing) question [Re: Satanized_68] #349743
06/19/09 02:10 PM
06/19/09 02:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
By using the hole at the front that gives you the
mains priority oiling(mains first)
Re: Small block oiling (plumbing) question [Re: MR_P_BODY] #349744
06/19/09 02:41 PM
06/19/09 02:41 PM
Uppsala, Sweden
Uppsala, Sweden
Even if I plumb it like this (I know, I'm a master of paint ) and don't plug the hole circled in white (above pic)?
Re: Small block oiling (plumbing) question [Re: Satanized_68] #349745
06/19/09 02:57 PM
06/19/09 02:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It'll still do the same thing... the oil will hit
that port and back up against the block off plate
Re: Small block oiling (plumbing) question [Re: Satanized_68] #349746
06/19/09 03:25 PM
06/19/09 03:25 PM
S/ST 3040 Offline
S/ST 3040  Offline
I see what you're doing now.
I wasn't paying attention and see the first adapter went on the block.
I thought they were two different variations of the remote filter.
The two ports, I have marked with red, are the same passage so, you'll
need to plug the one on the left anyway, or you'll have an internal leak.
In other words, you will be pressurizing both ends of the system, with only
partial filtration unless, your adapter blocks it. (plugged in OEM system)
I'd leave the block adapter off and plug the two I have marked.
Re: Small block oiling (plumbing) question [Re: S/ST 3040] #349747
06/19/09 05:17 PM
06/19/09 05:17 PM
Uppsala, Sweden
Uppsala, Sweden
partial filtration unless, your adapter blocks it. ( plugged in OEM system )
So, what you are saying is that the left port (the one I circled in white) is plugged in a OEM system?
I will check that tomorrow, maybe it's already plugged...
The adapter doesn't block it, that I know. It just spins on instead of the oil filter, I haven't taken the "filter plate" off.
Re: Small block oiling (plumbing) question [Re: Satanized_68] #349748
06/19/09 06:03 PM
06/19/09 06:03 PM
S/ST 3040 Offline
S/ST 3040  Offline
Correct
