Re: I lost a second.
[Re: mike67net]
#349096
06/16/09 11:15 PM
06/16/09 11:15 PM
Posts: 62 Kingston, OK
racerb440
Kingston, OK
I had the same problem once. Secondaries on carb didn't open, and car lost 1.2 seconds in quarter.
Bob - 67 Dodge Coronet 11.35,116.95 at 5880'
[Re: emarine01]
#349097
06/17/09 03:28 AM
06/17/09 03:28 AM
Posts: 370 NASHVILLE
MAVERICKSHEMI
NASHVILLE
Wow tuff question on where to start check gear ratio maybe someone else is running your gear set
[Re: MAVERICKSHEMI]
#349100
06/17/09 05:11 AM
06/17/09 05:11 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I had some work done on the rear end, but doesn’t seem to be binding
Chris..
[Re: Chris'sBarracuda]
#349103
06/17/09 07:46 AM
06/17/09 07:46 AM
Posts: 3,695 nc
emarine01
nc
Chris..
Well now. I said it was a tuff question , My first ring and pinnion I ordered I did not count the teeth It wasent even close and to make things worse it was 4 wheel drive I lost more than a second, it was a week end
[Re: KMPX2]
#349105
06/23/09 04:11 PM
06/23/09 04:11 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I believe we found the problem. Leak down showed that #5 cyl had 80% past the intake valve. Also that the valve springs where way down for his set up.So I guess heads come off.
JAKES AUTOMOTIVE
