Re: Struggling, any idea why first run of day so far off???
[Re: Bob_Spelic]
#347719
06/15/09 11:44 AM
06/15/09 11:44 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Do you have any weather Data from those runs? Might check your tune up if the DA is going up and you are going faster. If the DA is going down, as in you race at night T&T in the evening/day then it makes sense to me.
[Re: jamesc]
#347728
06/15/09 02:54 PM
06/15/09 02:54 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
I try to drive the pits and run the shifter up for several gear changes and put some heat in the motor 140 deg....most cars I know need a "clean out pass". If sometimes the 1st pass is the best usually really good air or the start line prep is the only one of the day and bite goes away.
The little old lady from Pasadena is back!
[Re: Barnstorm]
#347729
06/15/09 03:36 PM
06/15/09 03:36 PM
Al_Alguire
Las Vegas
Well this is an issue that I for one do not have. We do warm the engine and drivetrain before we make out first pass, HOWEVER I only do it if there is ample cool down time afterward to bring all the the temps back down to where they would normally be while racing. If there is not time we will bring the engine up to temp and cool it down. Will put a little heat in the trans just before we make a pass on the brake. Otherwise the first pass would be a waste of time and sometimes one is all we get.
[Re: Al_Alguire]
#347730
06/15/09 04:23 PM
06/15/09 04:23 PM
Posts: 388 Michigan
SD800
Both my cars do the same thing, I just figured everthing needed a pass to heat things up.
You'll have plenty of time to sleep when your dead, let's go
