Re: The 1971 RR Thrash at last! [Re: mopars_1] #347624
06/18/09 07:44 AM
06/18/09 07:44 AM
Millersville, PA
HemiChallenger Offline
Millersville, PA
Thing looks good! Drive her over when your done with the shift rod!
Re: The 1971 RR Thrash at last! [Re: HemiChallenger] #347625
06/20/09 07:01 AM
06/20/09 07:01 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
awesome , will it be at carlisle ?
Re: The 1971 RR Thrash at last! [Re: sogtx] #347626
06/20/09 07:04 AM
06/20/09 07:04 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
what did you do with the engine ..
wish i lived closer
youve had your hands full
Re: The 1971 RR Thrash at last! [Re: sogtx] #347627
06/20/09 11:48 AM
06/20/09 11:48 AM
Hunt Valley, Maryland
1fastrunner Offline OP
Andy,
Yes, I will be at Carlisle. I'm also going to be in Rochester the following Wed or Thurs on my way to the Syracuse Nationals.
440 30 over
Aries pistons .003 from deck
Stealth heads shaved 25 (9.75 comp.)
Erson cam e410060
intake .340 valve .510
exhaust .340 valve .510
244 duration
Edelbrock ch 4b duel plane manifold
Hooker 1 7/8 supper comp headers
Holley 750 DP
4-speed
3.23 rear
1971 RoadRunner
Passon did the tranny
I've had it out a couple times to make sure everything id Ok.
I'm getting it aligned and adjusting the exhaust pipes that keep rattling on my floorboard.
I still have to mess with the timing and carb adjustments. It doesn't want to idle below 1000, but that might just be the cam.
Re: The 1971 RR Thrash at last! [Re: 1fastrunner] #347628
06/20/09 09:32 PM
06/20/09 09:32 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
dont think its the cam ..
did you do overdrive ?
wheres your timing set dont be afraid to set initial above 15
Re: The 1971 RR Thrash at last! [Re: sogtx] #347629
06/20/09 09:36 PM
06/20/09 09:36 PM
Not enough cash for overdrive, but in the future, yes
Timing @18 unless the mark is off, I have to check it out
Re: The 1971 RR Thrash at last! [Re: 1fastrunner] #347630
06/21/09 02:28 AM
06/21/09 02:28 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Don't overlook the carb. I've had that problem with a couple Holleys in the past. Not sure WHAT causes it (I was young) but replacing the carbs changed the problem.
2 Demons...no, not my kids!
