Correct fan for a 71 Challenger 440/6 with 22"..... #345834
06/13/09 04:14 PM
06/13/09 04:14 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
I was installing my 22" rad and shroud and I see that the fan is hitting the fan shroud so I must have the wrong fan. I have the 216 fan but is the correct one the 224 ??? Is the 224 fan smaller ??? Should I have a spacer and not a fan cluch ?? The car was apart when I got it and I think I have the wrong fan setup....
Re: Correct fan for a 71 Challenger 440/6 with 22"..... [Re: THESHAKERPROJECT] #345835
06/13/09 05:30 PM
06/13/09 05:30 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Yup. 224 fan with spacer is the ticket with a 22" rad. You must have an automatic with 8 and 3/4 rear end in your car. My 70 cuda conv. is the same.
Re: Correct fan for a 71 Challenger 440/6 with 22"..... [Re: m46rat] #345836
06/13/09 05:44 PM
06/13/09 05:44 PM
NORTHERN VA
NORTHERN VA
Thanks.....yeah my car DID have auto 3.23 open rear but now has a 4spd and 355 sure grip. Is there a part number for the spacer and does anyone make new ones ??
Re: Correct fan for a 71 Challenger 440/6 with 22"..... [Re: THESHAKERPROJECT] #345837
06/13/09 07:42 PM
06/13/09 07:42 PM
m46rat Offline
m46rat  Offline
Well, the only way you could get that 22" rad is with an automatic and non optional rear end. If you had a four speed or an optional rear end, either of those would upgrade the cooling to a 26" rad. Frankly, it would be dumb to try and cool your now upgraded car with the smaller rad. I believe your only real option is the 26" with clutch.
Re: Correct fan for a 71 Challenger 440/6 with 22"..... [Re: m46rat] #345838
06/14/09 11:57 AM
06/14/09 11:57 AM
NORTHERN VA
NORTHERN VA
Well, yes I already knew that the 22in was standard size unless you got the 3.55/391 (a36) but the orig owner of this car must of wanted a cruzer with a 3.23 open rear and whitwall tires on a orig 440/6 car. BTW , a 22in rad with a modern HIGH EFFICENCY core and a good water pump (edelbrock/ milidon ) will cool a 528 Hemi without a problem and at some point in time ,I may want to sell this car with its orig auto/3.23 combo and orig rad . Remember, a 71 440/6pack Challenger (numb match and citron yellow ) is a VERY rare car.
Re: Correct fan for a 71 Challenger 440/6 with 22"..... [Re: THESHAKERPROJECT] #345839
06/14/09 12:07 PM
06/14/09 12:07 PM
cataclysm80 Offline
cataclysm80  Offline
Tav
Forum Statistics
Forums32
Topics193,575
Posts2,260,625
Members25,805
Most Online1,424
Jun 20th, 2018
7000 RPM Small block oiling mods.
by RUNCHARGER. 03/25/19 10:02 PM
99 ram p/u 2500 V10 2WD oil pan gasket replacement
by moparjo68. 03/25/19 09:27 PM
Valve Springs
by 71birdJ68. 03/25/19 08:38 PM
