Page 4 of 4 1 2 3 4
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: kotacars] #345237
07/30/13 02:19 AM
07/30/13 02:19 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
Well my little 387ci did 614hp and 538 tq on pump gas and its a street car
give us a run down of your parts
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: Stroker Scamp] #345238
07/30/13 07:54 PM
07/30/13 07:54 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
My 394 c.i. small block made 662 hp and 533 ft lbs torque with a 1050 on it and pump gas. It has a 950 holley on it now.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: dirt] #345239
07/30/13 08:02 PM
07/30/13 08:02 PM
Az
Crizila Offline
Crizila  Offline
Az
Here's the trick.
Fastest 300
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: Crizila] #345240
07/30/13 11:18 PM
07/30/13 11:18 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
575 hp at about 5900 rpm with a 408, pre magnum roller block. Hydraulic roller lifters and an erson cam in the 256 @.050 range if I recall correctly. Heads were Indy oval ports flowing at peak, 337 cfm @ .650" lift, cam was opening valves to approximately .600" so the full airflow wasn't being utilized. Scat forged crankshaft, studded mains, stock caps. Scat I beam rods (I would have opted for H beams on this build) Icon flat top pistons at zero deck. FelPro .039" crushed head gaskets, 65 cc chambers and thoroughly modified Indy rocker arms (grooved shafts, grooved rocker body to provide close to full time oiling to the ball and cup at the pushrod) Smith brothers pushrods and polished ball adjusters on the rocker arms (that Indy rocker arm stuff is crap). Ported Indy intake matched to the heads, some 1-3/4" dirt track headers and a 950 quickfuel carb if I remember correctly. It ran on pump fuel but our elevation is right around 5000 ft. The numbers were corrected to sea level with DTS' dyno software. With a solid roller camshaft and T&D rockers, this engine would have been over 600 hp. A similar build we did was with rectangle port heads that I did prior to these oval ports that flowed about 335 cfm, had the matching intake, a solid roller camshaft and approximately 10.8:1 cr instead of 11.6 made 591 hp on the same dyno. The owners threw nitrous at it and couldn't quite break into the 9's. Finally missed the tune and burned a piston then proceeded to take the engine to another shop which tore the engine apart and talked nothing but crap about the parts we used. Ah well, I thought it did quite well for a stock 360 block and caps with enough nitrous to pick up over 1 second in the quarter. We knew they were going to use nitrous, but they didn't tell us how much. I suspect it was a snowball effect, we want to go faster so let's throw some more nitrous at it. I feel that either one of those engines would do what the op is asking an engine to do.
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: dodgeboy11] #345241
07/31/13 02:00 PM
07/31/13 02:00 PM
SoCal
Brian Hafliger Offline
SoCal
Brian Hafliger
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: Brian Hafliger] #345242
07/31/13 05:31 PM
07/31/13 05:31 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I guess I'd have to eat my words!
http://www.carcraft.com/techarticles/ccrp_1110_pump_gas_small_block_mopar/
Nice build...
For people to think 600 on pumpgas at 400+ inches in this day and age isn't VERY doable, is incredible.
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: dodgeboy11] #345243
07/31/13 05:36 PM
07/31/13 05:36 PM
Toronto
mshred Offline
mshred  Offline
Toronto
What kind of rpms was that motor shifted at with the hydraulic roller? Double valvesprings on it? Stock lifters?
Sorry for all the questions, just got me curious thats all. My hydraulic rollers never really seemed to like rpm so just wondering where this one did
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: Brian Hafliger] #345244
07/31/13 08:52 PM
07/31/13 08:52 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Now you're just showing off Brian.
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: Brian Hafliger] #345245
07/31/13 09:43 PM
07/31/13 09:43 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Hey Brian, what does a motor like that cost???
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: MIKES_DUSTER] #345246
07/31/13 09:50 PM
07/31/13 09:50 PM
SoCal
SoCal
I think CC did the cost at the end of the article...something like 10K or 11K.
Had alot of guys question the 9000 series crank...I tell them if the BLOCK doesn't break first, I'd be surprised!
Those 9000 cranks are pretty tough...if you don't detonate the engine.
If your going to race it alot, the 4340 crank is a better choice as it will go many many years without breakage.
But I would still use the I beam rods at that power level.
Brian
Brian Hafliger
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: Brian Hafliger] #345247
07/31/13 10:38 PM
07/31/13 10:38 PM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
My 410 magnum with the factory hydraulic roller and 11.8 compression made 582HP and 594HP with a dominator. I drive it everywhere and in rush hour traffic.
The build: https://board.moparts.org/ubbthreads/show...rue#Post7220612
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: onebaddakota] #345248
07/31/13 11:22 PM
07/31/13 11:22 PM
Brian, I'm surprised you would use the I beams again. Lol
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: Brian Hafliger] #345249
08/01/13 12:25 AM
08/01/13 12:25 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Is installing the brass tubes pretty basic? Why not tube the pushrod pinch?
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: viperblue72] #345250
08/01/13 02:07 AM
08/01/13 02:07 AM
SoCal
SoCal
Tubing the pinch doesn't do much IMO. I slow the air down other ways that seem to make great power without the hassle of all those tubes.
I don't even tube the head bolt hole anymore when pushrod oiling...I just leave the bolt showing and seal the threads/underhead with a bit of silicone.
Brian Hafliger
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: Brian Hafliger] #345251
08/01/13 04:32 PM
08/01/13 04:32 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Wow, someone dug up this thread after 4 years.
I still have not finished the 340 that I originally posted about. but I still hope to. I just finished helping my son build a dart and that took at least 3 years so now I can get back to my own car again.
how well does that blow through supercharger work? I have thought about one of those before but don't know anyone who used one on a carb car.
Re: smallblock stroker, 600 HP out of question? on pump gas [Re: mshred] #345252
08/03/13 04:11 AM
08/03/13 04:11 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I don't recall what the solid roller motor was turning rpm, about all I had to do with that one was the heads and intake. The hyd roller motor wouldn't turn over 6500, and when it reached 6500, it wasn't happy. Shift points, realistically, are probably 6200, maybe 6300. I really didn't like the pushrod angles. Between the 59 degree lifter angle and the short pushrods necessary with the tall hydraulic lifters, it just seemed like an accident waiting to happen. But it never did spit anything out and it sure ran strong on the dyno.
Here's a picture down one of the intake runners on the oval port.
Page 4 of 4 1 2 3 4
