Page 1 of 5 1 2 3 4 5
INDY 360-1 245 CNC #34501
02/15/07 07:19 PM
02/15/07 07:19 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Been working on first set of these I've done....
Out of box, W/2.15 Ferrea Comp Plus
LIFT---IN
.100"--68.7
.200"--147.1
.300"--212.9
.400"--268.6
.450"--286.6
.500"--294.4
.550"--303.6
.600"--312.4
.650"--324.3
.700"--321.6
ICH claims 330 @ .700" in their literature.
I did a VJ, and a 10 minute seat/ST blend:
LIFT---IN
.100"--69.6
.200"--146.8
.300"--210.2
.400"--265.7
.450"--292.0
.500"--310.3
.550"--320.9
.600"--331.9
.650"--331.9
.700"--331.9
I was'nt happy with the shape/size of the ICH short turn so.... another 45 minutes of work....(also opened Pushrod area .100")
LIFT---IN
.100"--69.6
.200"--143.6
.300"--210.2
.400"--268.9
.450"--294.2
.500"--312.6
.550"--331.2
.600"--343.6
.650"--351.4
.700"--360.8
Misc notes:
Actual Min CSA of the out of box port..... 2.85" 245 CC
Actual Min CSA of my 360 cfm port......... 2.95" 255CC
Intake manifold fitment is a definite concern, as the out of box port window is 2.4" tall. So after port matching the 360-3R ICH manifold you have ~.060" of gasket sealing area above the port.
The exhaust port and chamber are basically the same as the 230 CC CNC -2 head.
Re: INDY 360-1 245 CNC [Re: RyanJ] #34502
02/15/07 08:05 PM
02/15/07 08:05 PM
Iowa City, Iowa
joaks360 Offline
super gas
joaks360  Offline
super gas
Iowa City, Iowa
.100"--69.6
.200"--143.6
.300"--210.2
.400"--268.9
.450"--294.2
.500"--312.6
.550"--331.2
.600"--343.6
.650"--351.4
.700"--360.8
Slow '71 Demon W2 360 4-spd (in the works) Slower '92 Dakota Sport 3.9 (blown) Slowest '87 Dakota 3.9 (cute lil' p.o.s.) I know Jack.
Re: INDY 360-1 245 CNC [Re: joaks360] #34503
02/15/07 09:40 PM
02/15/07 09:40 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
and thats your first set?
Re: INDY 360-1 245 CNC [Re: RyanJ] #34504
02/15/07 10:35 PM
02/15/07 10:35 PM
ohio
prochamp Offline
prochamp  Offline
ohio
it looks like you found something to outdue the w5's in 59 degree.what about the exhaust side? oh i just reread your post and saw the exhaust post.looks like that head will need some help on the exhaust with more cam on that side.with that cross section a 4 inch stroker motor with the right parts of course ought to be able to see 7400 rpm before choke.
Re: INDY 360-1 245 CNC [Re: Stroker Scamp] #34505
02/15/07 10:45 PM
02/15/07 10:45 PM
oregon
greendart408 Offline
oregon
These heads are being done for a new motor my uncle is building. It will be a siamese bore tall deck 59* r3 block. It will be 439ci. 14-1comp, roller cam on alcohol. It will be going in my new drag car. A 69 dart 3000lb, ladder bars and coil overs 29.5x11.5 tire. Converter will be bought after dynoing, 727trans and a dana 60. What do you think it will run at 200ft above sea level.
Re: INDY 360-1 245 CNC [Re: greendart408] #34506
02/15/07 11:19 PM
02/15/07 11:19 PM
you the man Ryan nice #'s
Re: INDY 360-1 245 CNC #34507
02/15/07 11:46 PM
02/15/07 11:46 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
OH YEAH!!!!!
Re: INDY 360-1 245 CNC [Re: MIKES_DUSTER] #34508
02/15/07 11:47 PM
02/15/07 11:47 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
How much do these heads cost?
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: INDY 360-1 245 CNC [Re: RyanJ] #34509
02/15/07 11:58 PM
02/15/07 11:58 PM
i find that interesting. here's the flow numbers you provided with a set you did for a customer of mine. they weren't cnc'd ports but these were supposed to be a max port job. i thought it would be worth a look to compare to your new findings.
.100"--82.8/N/A
.200"--157.3/110.4
.300"--217.4/158.0
.400"--262.9/203.6
.450"--286.0/214.6
.500"--304.0/221.9
.550"--318.1/227.1
.600"--322.4/230.5
.650"--332.9/237.4
.700"--334.0/241.2
Re: INDY 360-1 245 CNC #34510
02/16/07 01:20 AM
02/16/07 01:20 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
SDSS is now an INDY CYL HEAD distributor
Re: INDY 360-1 245 CNC #34511
02/16/07 12:58 PM
02/16/07 12:58 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
.100"--82.8/N/A
.200"--157.3/110.4
.300"--217.4/158.0
.400"--262.9/203.6
.450"--286.0/214.6
.500"--304.0/221.9
.550"--318.1/227.1
.600"--322.4/230.5
.650"--332.9/237.4
.700"--334.0/241.2
Yep, that would be about a max effort -1 rectangle port that was hand ported. Those heads start at 210 CC, and in that level of port work are aound 228 CC. There is just no way I would port a set by hand out to 255 CC, I would have to charge $2000+. I'll get some pics today of a 245 CNC sitting next to an unported -1 rectangle, it's absolutely silly how much material has been taken out of the roof of the CNC head. Like I said, the port is so big, the ICH -1 gasket and manifold don't really "fit" anymore. It would be nice if they came out with a raised runner intake for this head. I'll get a pic of that today as well as I worked on the manifold yesterday.
The exhaust, I only flowed one so far, just with a 3 minute sand roll job and it went 256 cfm. I have had the -2 Oval CNC exhausts up in the mid 260's before. So that's about what they can do, 255-265 cfm on average.
Gerig's car should run around 9.10 @ 148 @ 3000 IMO.
I'm going to do a set for Vic Bailey's new 454" "street" engine (guy who owns B3422W5's old duster) 4.125" X 4.185", 13:1 with a roller, and I'm going to angle mill them 2 degrees. (48 degree block) Should be an easy 700 HP combo. It's just nice to have a head that has ALOT of cross section and is still a true 59 degree piece. This is what the big inch SB's have been needing. CSA wise it is bigger than most W7/8 heads other than BIG sprint and Drag heads. Liek a typical Craftsman Truck W8 has 2.78" CSA, my Lemans heads are 2.55"...
They don't cost anymore than any other INDY SB head. The CNC cost is same on the 245 as the 230 -2 Oval etc. This set and Vic's set I am going to mill the pedestals on and we are running ICH/Jesel .800" offset rockers to eliminate the 440-1 junk. In fact 3 of 4 sets here right now are being converted to Jesel and the last set I did a few months ago also were converted, so it looks like guys are finally willing to pay a little more $ and get the good rockers finally. I know the Jesel and T&D stuff is not cheap, but once you use it, you'll never go back to anything else.
Re: INDY 360-1 245 CNC [Re: RyanJ] #34512
02/16/07 01:06 PM
02/16/07 01:06 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Nice
Re: INDY 360-1 245 CNC [Re: 340RICK] #34513
02/16/07 01:07 PM
02/16/07 01:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
good info Ryan, I am guessing you kind of like the 360-1s now
Re: INDY 360-1 245 CNC [Re: Quicktree] #34514
02/16/07 05:45 PM
02/16/07 05:45 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
INTAKE PORT
Re: INDY 360-1 245 CNC [Re: RyanJ] #34515
02/16/07 05:49 PM
02/16/07 05:49 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
230 CC CNC -2 OVAL VS 245 CC CNC -1 RECTANGLE
Re: INDY 360-1 245 CNC [Re: RyanJ] #34516
02/16/07 05:53 PM
02/16/07 05:53 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
230 CC CNC -2 INTAKE PORT, keep in mind, if you've never seen these heads in person, for getting a feel for how big the 245 head is, a normal W2 head fully ported is in the 195 CC range. So the 230 CC Oval ICH is a BIG Oval, and the 245 rectangle dwarfs it. The actual minimum CSA of the 230 CC CNC -2 is 2.52" Someone wanted to know taht a few months ago, and I just got around to measuring it today.
Re: INDY 360-1 245 CNC [Re: RyanJ] #34517
02/16/07 06:00 PM
02/16/07 06:00 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
245 CNC next to an unported -1 rectangle, the roof of the 245 is raised .275", and the port is widened .050"
Re: INDY 360-1 245 CNC [Re: RyanJ] #34518
02/16/07 06:05 PM
02/16/07 06:05 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
The 245 has a very wide ST, and I moved the head bolt bulge over, and widened it even more to slow the air down.
Re: INDY 360-1 245 CNC [Re: RyanJ] #34519
02/16/07 06:11 PM
02/16/07 06:11 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
-3 Manifold. You can't really raise the roof of the port as far as it needs to be to do a perfect match, hence the need for a raised runner intake manifold. So I just took it up and left .080" for gasket sealing. Going to have to make custom gaskets as the ICH -1 gaskets run out of material at the roof.
Re: INDY 360-1 245 CNC [Re: RyanJ] #34520
02/16/07 06:22 PM
02/16/07 06:22 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
My prediction 9.35@145. Ryan why not use a W8 Intake with this all you have to do is mill it down to fit. Then port and bolt match and then hog out the intake to move the big air.
