Page 2 of 3 1 2 3
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: 73cudaproject] #343476
06/29/09 01:25 PM
06/29/09 01:25 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
I have TTI headers back to TTI head pipes with servo controlled cutouts grafted onto the head pipes, then the exhaust runs back to Accurate Ltd. high flow AAR mufflers and out the diffuser-less Accurate Ltd. side pipes.
I took a 6" diameter 3/8" sidewall pipe and cut out some "channels" to graft into the subframe connectors. Super rigid and turned out really nice. It was A LOT of work, but I've seen what you took on with your Cuda, so I know you can handle it. Here are a couple of pics.
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343477
06/29/09 01:27 PM
06/29/09 01:27 PM
Houston Texas
Houston Texas
Here is where I tacked that carefully sectioned piece of pipe and tacked it into the connector.
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343478
06/29/09 01:28 PM
06/29/09 01:28 PM
Houston Texas
Houston Texas
Here it is before grinding.
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343479
06/29/09 01:28 PM
06/29/09 01:28 PM
Houston Texas
Houston Texas
And here after grinding... ( I welded inside and out)
Note: Before I welded these in, I drilled a big hole in the middle of the arch and ended up plug welding the apex of the arch to the bottom of the rear sub frame, then grinding it back smooth again.
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343480
06/29/09 01:32 PM
06/29/09 01:32 PM
Houston Texas
Houston Texas
It is a very unnoticeable detail and it is under appreciated because no one would ever notice... but my car is so much tighter because of the connectors and I still get to keep the AAR theme true.
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343481
07/02/09 12:25 PM
07/02/09 12:25 PM
Houston Texas
Houston Texas
Here are the latest pics. Set to go into the booth Monday 7/6. The doors and fenders were black, but they finished up the body and went for one last test fit and thought it could use just a little more TLC. I am ecstatic to see the black in the headlight bucket!
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343482
07/02/09 12:41 PM
07/02/09 12:41 PM
Houston Texas
Houston Texas
Here's a rear shot. We are over on time, but the car's looking good, so I can deal with it.
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343483
07/02/09 01:25 PM
07/02/09 01:25 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Looks really good!
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: jrwoodjoe] #343484
07/09/09 07:12 PM
07/09/09 07:12 PM
Houston Texas
Houston Texas
Got proof the car was in the booth today, so its all good! Body looks straight and man, I am excited. Next pic will hopefully be of a black Cuda, not a gray one.
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343485
07/12/09 05:00 PM
07/12/09 05:00 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Well...we're waiting.
Joe
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: jrwoodjoe] #343486
07/12/09 09:24 PM
07/12/09 09:24 PM
Houston Texas
Houston Texas
Joe
Patience is a virtue...
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343487
07/12/09 10:54 PM
07/12/09 10:54 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Joe
Ummm...Actually, I think it's a noun.
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: jrwoodjoe] #343488
08/10/09 02:22 PM
08/10/09 02:22 PM
Houston Texas
Houston Texas
I wanna see it painted, painted black
Black as night, black as coal
I wanna see the sun blotted out from the sky
I wanna see it painted, painted, painted, painted black
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343489
08/10/09 02:24 PM
08/10/09 02:24 PM
Houston Texas
Houston Texas
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343490
08/10/09 02:25 PM
08/10/09 02:25 PM
Houston Texas
Houston Texas
Black is SO
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343491
08/10/09 04:14 PM
08/10/09 04:14 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Yep...that's a black car. I can tell cause it's sucking up all the flash from your camera.
Cool
Joe
65 Barracuda
70 Challenger
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: jrwoodjoe] #343492
08/12/09 07:45 AM
08/12/09 07:45 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
OK...It's black now.....GET IT TOGETHER !
CHECK OUT MY NEW WEB SITE !
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: anlauto] #343493
09/28/09 04:43 PM
09/28/09 04:43 PM
Houston Texas
Houston Texas
Not all of us work as quick as Alan...
Steve at Paintshop101 says it will be ready to pick up within two weeks. They put the final polish on it yesterday after these pics, but the front end back together, and are spraying the flat black today. I am certain that this thing will be drop dead gorgeous once they get it done and cleaned up. I am impressed with the panel fitment/body work.
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343494
09/28/09 04:44 PM
09/28/09 04:44 PM
Houston Texas
Houston Texas
Re: The 6 year saga continues... My Gran Coupe...er... Cuda [Re: PAINT IT BLACK] #343495
09/29/09 04:22 PM
09/29/09 04:22 PM
pennsylvania
conv71 Offline
conv71  Offline
pennsylvania
is it an orig black car???
Page 2 of 3 1 2 3
