Page 11 of 13 1 2 9 10 11 12 13
Re: VIN Stamping: MYTH or FACT [Re: Diego (not Ted)] #342617
03/31/11 11:07 AM
03/31/11 11:07 AM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
Buy 1967 Cars (see below) We Don't Need No Stinkin VIN!!
RS23L7 4-Speed
Re: VIN Stamping: MYTH or FACT [Re: Mopar_Mike] #342618
03/31/11 03:03 PM
03/31/11 03:03 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
That's right , easier to pass off as matching numbers , all you need to do is find a good dated block and such ... kidding ...
Re: VIN Stamping: MYTH or FACT [Re: Diego (not Ted)] #342619
03/31/11 03:05 PM
03/31/11 03:05 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Out of curiosity, seeing a learning opportunity, I emailed the guy asking him why there were two sets of numbers on the tranny.
He said, "first set is serial # the second set i think is dates or line numbers"
Then I asked, "Shouldn't they be in the same font?"
He said, "thats how they came"
So then I asked, "From my experience, they were the same font. You sure it's #s match from the factory?"
He replied, "yes i had it a a mopar show"
I think I still have a lot to learn.
Yes you do have a lot to learn , but at least you want to learn. The trans stampings are correct , the part number/build date/sequence built fonts is always smaller than the VIN font , the trans in that auction is CORRECT factory stampings , the VIN on the block is NOT .
Re: VIN Stamping: MYTH or FACT [Re: JohnRR] #342620
03/31/11 04:56 PM
03/31/11 04:56 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
oh my gawd.. i agree with johnRR...
Re: VIN Stamping: MYTH or FACT *DELETED* *DELETED* [Re: ph23vo] #342621
03/31/11 05:03 PM
03/31/11 05:03 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Post deleted by 71redcuda
Re: VIN Stamping: MYTH or FACT [Re: 71redcuda] #342622
03/31/11 05:05 PM
03/31/11 05:05 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
thats a deep pad also and very factory looking stamped! maybe the one above is a repl block? dan
Re: VIN Stamping: MYTH or FACT *DELETED* [Re: ph23vo] #342623
03/31/11 05:08 PM
03/31/11 05:08 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Re: VIN Stamping: MYTH or FACT [Re: 71redcuda] #342624
03/31/11 05:15 PM
03/31/11 05:15 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
trans
You got two different 3s there
Re: VIN Stamping: MYTH or FACT [Re: Morty426] #342625
03/31/11 05:21 PM
03/31/11 05:21 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Ok what does that mean?
Re: VIN Stamping: MYTH or FACT [Re: 71redcuda] #342626
03/31/11 06:39 PM
03/31/11 06:39 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
That means your block is a restamp-the B is not even close in size to the 3, not to mention they aren't the same font! Sorry, that's prob not what you want to hear!
Re: VIN Stamping: MYTH or FACT [Re: Paul Jacobs] #342627
03/31/11 08:29 PM
03/31/11 08:29 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
I don't see how you can be so sure.
Re: VIN Stamping: MYTH or FACT [Re: pacifica] #342628
03/31/11 08:57 PM
03/31/11 08:57 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
pauls right.. the block alone [though heavily painted makes it hard to really see] looks ok until you see the trans.. one of them isnt right! whats the history on the car? ever owned by a used muscle car dealer? dan
Re: VIN Stamping: MYTH or FACT [Re: Paul Jacobs] #342629
03/31/11 11:49 PM
03/31/11 11:49 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
What about this one,does the stamping look ok "factory" or? Block made:1-7-70
The two stampings are so different there is no way they are right. Transmission looks good, engine stamp is a mess.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: VIN Stamping: MYTH or FACT [Re: pacifica] #342630
04/01/11 12:01 AM
04/01/11 12:01 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
I'm not trying to come across as a know it all - I base my statement on the 25 years restoration experience, the 50 Mopars I've owned, over 100 I've dismantled, and over 10,000 pictures to document original cars. Remember, I work on these EVERY day, so you pick up on details of parts very quickly-just like you probably know your particular job inside & out.
There are plenty of originals that are quirky, but this one is very obvious when studied.
Cheers
Re: VIN Stamping: MYTH or FACT [Re: Paul Jacobs] #342631
04/01/11 12:28 AM
04/01/11 12:28 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Cheers
I know a little about these cars as well and I must say that is the worst restamp I think I have ever seen.
Hi Paul, hope all is well.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: VIN Stamping: MYTH or FACT [Re: BS27R1B] #342632
04/01/11 01:24 AM
04/01/11 01:24 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
they used many different letters and numbers obviously..however once you posted the trans it was clear there are 2 diff stamps used.. also the block is painted thick so that makes the block harder to see.. the trans indeed does look right.. dan
Re: VIN Stamping: MYTH or FACT [Re: Morty426] #342633
04/01/11 01:46 AM
04/01/11 01:46 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
trans
Good eye , the engine was not stamped at the same time the trans was stamped judging by the difference in fonts .
Re: VIN Stamping: MYTH or FACT [Re: JohnRR] #342634
04/01/11 02:33 AM
04/01/11 02:33 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
I think the 1B159 block looks ok but the three last numbers locks wrong.
I have a few more pictures if someone is intrested..
Owned in the 90`s by Ed Briggs.The car was restored 2002-2005 by 2 brothers in Fort Wayne,Indiana. Tom and Jeff Ruble. When the car was finished it was bought by Gary S,work/worked on Atlantamusclecars.Gary sold the car in 2006 to a guy in Romeo,Michigan.
Re: VIN Stamping: MYTH or FACT [Re: 71redcuda] #342635
04/01/11 02:39 AM
04/01/11 02:39 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
more.2780930-340-? Its a 1971 (E55) 340 car.
Re: VIN Stamping: MYTH or FACT [Re: 71redcuda] #342636
04/01/11 04:09 AM
04/01/11 04:09 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree with Paul on this one, USUALLY the complete stamping (numbers spacing, alignment, etc.) should match very closely if not exactly, but the actual letter and number fonts should ALWAYS match in size and shape, they were each stamped moments appart by the same guy with the same stamping tooling on the production line.
