Re: 69 single four barrel air grabber base
[Re: torkrules]
#34163
01/21/07 02:06 PM
01/21/07 02:06 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
if you lay it on a flat surface and the round part that sits on the carb is original and uncut
383, the whole unit will sit slightly off the flat surface
440, the unit will touch the flat surface
the 440 unoit is lower due to the 440 being slightly taller than a 383
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
