BILL EVANS WIRING HARNESSES ???? #340119
06/06/09 11:46 PM
06/06/09 11:46 PM
Anonymous OP
Anonymous OP
Has anyone had engine harnesses made up by Bill Evans,out of Erie,Pennsylvania? I heard he does quality work,and does custom pieces,like MSD control boxes. Any opinions,good or bad,are appreciated! Randy Borawski
Re: BILL EVANS WIRING HARNESSES ???? #340120
06/07/09 12:08 AM
06/07/09 12:08 AM
Gateway to the West.
hemi_harvester Offline
YES I have bought 3 harnesses from him, all worked perfect and no issues. I can't say if they are all 100% concorse correct because I don't know. But they work as intended and I highly recommend,
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: BILL EVANS WIRING HARNESSES ???? [Re: hemi_harvester] #340121
06/07/09 12:21 AM
06/07/09 12:21 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I was happy with mine as well. Plus they are a decent price to boot.
Re: BILL EVANS WIRING HARNESSES ???? [Re: moparmojo] #340122
06/07/09 12:28 AM
06/07/09 12:28 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i have some for my demon, not installed yet but they do look nice.
Re: BILL EVANS WIRING HARNESSES ???? [Re: chrisf] #340123
06/07/09 06:23 AM
06/07/09 06:23 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Yes, yes and yes.
Bill has always treated me right and makes a great product.
Whenever I get an engine harness from him, I have him extend and hide the wires for the ECU under the battery tray.
http://evanswiring.tripod.com
Re: BILL EVANS WIRING HARNESSES ???? #340124
06/07/09 06:45 AM
06/07/09 06:45 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
One more for Evans.........
Makes a great product and as mentioned will customize a bit as well!
I've always liked what I've got from them, highly recommend
"Keep the new stuff, I'll stick with my 55 year old Dodges"...unless its a LS1 powered f-body or 5th generation Mustang. whistling
Re: BILL EVANS WIRING HARNESSES ???? [Re: idrivevintage] #340125
06/07/09 07:01 AM
06/07/09 07:01 AM
Anonymous OP
Anonymous OP
my A12 superbee harness wire from the bulkhead wasnt crimped properly in one of the wires and it caused my car not to start. it was in the engine compartment side, after going over all the wires we found the culprit.
i emailed bil evans and he said send the harness back, i was hoping for him to say ill send you another one out and then send me back the defective one after you get the new one installed.
oh BTW, its not close to concourse correct.
the ones from Frank Badalson and yearone are better concourse correct.
Re: BILL EVANS WIRING HARNESSES ???? #340126
06/07/09 10:46 AM
06/07/09 10:46 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
concourse and CORRECT should NEVER be used in the same sentence
Re: BILL EVANS WIRING HARNESSES ???? [Re: JohnRR] #340127
06/07/09 11:10 AM
06/07/09 11:10 AM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
care to elaborate
Enjoy life today, It has an expiration date
Re: BILL EVANS WIRING HARNESSES ???? [Re: gtx6970] #340128
06/07/09 11:29 AM
06/07/09 11:29 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you want absalute OE correct you'll need original harnesses (NOS or mint used, etc.). As far as reproductions, M&H (sold exclusively through Year One) produces the best I've seen concerning correct original colors and details, but none of them are an exact match to original.
Re: BILL EVANS WIRING HARNESSES ???? [Re: ScottSmith_Harms] #340129
06/07/09 12:01 PM
06/07/09 12:01 PM
Anonymous OP
Anonymous OP
Thanks for ALL the input fellas! Concourse correct is NOT an issue on my concourse-incorrect GTX! Sounds like the mojority of you were/are satisfied with his product. I will be ordering my harnesses today! Thanks again! RandyB
Re: BILL EVANS WIRING HARNESSES ???? #340130
06/07/09 12:45 PM
06/07/09 12:45 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Randy I did run into the same issue as superstockracer , had a connector come off from a bad crimp , called and had them send me another connector instead of expecting a complete replacement harness before returning the other
Re: BILL EVANS WIRING HARNESSES ???? [Re: JohnRR] #340131
06/07/09 01:01 PM
06/07/09 01:01 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I also had 3 crimps come loose at the bulkhead connector but I got one last week for another car that looks better. I would chect it at the bulkhead side befor you install it. He replaced the bad one I got from him with a new one and that one has been good for the last 5 years.
Re: BILL EVANS WIRING HARNESSES ???? [Re: THESHAKERPROJECT] #340132
06/07/09 02:16 PM
06/07/09 02:16 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Set one on fire the other day, guess the E-Body I was working on has a shorted amp guage which caused the original harness to burn. I am going with M&H this time, the Evans harness had issues with proper wire lengths at the coil which caused other issues with connections.
JB Rhinehart, Realist
A-Body's RULE!
Re: BILL EVANS WIRING HARNESSES ???? [Re: Rhinodart] #340133
06/08/09 01:06 AM
06/08/09 01:06 AM
California
70SportSatellite Offline
super street
super street
California
Sent a Bill Evans to Mike at M & H. Let's just say I was lucky I didn't use it. Go with M & H.
Re: BILL EVANS WIRING HARNESSES ???? [Re: 70SportSatellite] #340134
06/08/09 06:42 AM
06/08/09 06:42 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Did you expect him to tell you otherwise ?
Re: BILL EVANS WIRING HARNESSES ???? [Re: AdamR] #340135
06/08/09 10:29 AM
06/08/09 10:29 AM
SE Pa.
LimeliteAero Offline
SE Pa.
the Evans harnesses have been around for a long time, I would say they cant be too bad or word would be out to avoid them at all cost in which case they would be gone.
Maybe not the best game in town but I think theres a case of piling on going on now.
Re: BILL EVANS WIRING HARNESSES ???? [Re: LimeliteAero] #340136
06/08/09 12:24 PM
06/08/09 12:24 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Did you just join Moparts this morning ?
Re: BILL EVANS WIRING HARNESSES ???? [Re: JohnRR] #340137
06/08/09 07:33 PM
06/08/09 07:33 PM
Anonymous OP
Anonymous OP
Still haven't ordered my harnesses yet!! I don't like,or feel comfortable,with a product that gets such mixed reviews! I guess I'll have to do a little more research! RandyB
Re: BILL EVANS WIRING HARNESSES ???? #340138
06/08/09 07:42 PM
06/08/09 07:42 PM
Nazareth,Pa.
JACKSON Offline
JACKSON  Offline
Nazareth,Pa.
i had a evans harness that had 4 connectors fall out of the bulkhead. it was a piece of junk.
i called him and his attitude wasnt good, hes not much of a people person, his attitude at carlisle is i cant be bothered with no personality.
i got mine from yearone and with the 15% discount it wasnt bad.
Re: BILL EVANS WIRING HARNESSES ???? [Re: JACKSON] #340139
06/08/09 08:12 PM
06/08/09 08:12 PM
Anonymous OP
Anonymous OP
Now I'm gettin' REAL NERVOUS!!! I don't need connectors falling off a "brand new piece"!!! I'll check Year One on their stuff! Help!!!
Re: BILL EVANS WIRING HARNESSES ???? #340140
06/08/09 10:46 PM
06/08/09 10:46 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
I used one on my car 3 years ago and I have had NO problems or issues with mine. I bought from Bill based on a freinds recomendation. He has had his for quite a while with no problems.
Re: BILL EVANS WIRING HARNESSES ???? [Re: pacifica] #340141
06/08/09 11:50 PM
06/08/09 11:50 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I use Bill's all the time (at least a dozen or more).
I've had no issues with them, however Bill is a stubborn fart.
Last year at Carlisle I purchased over $1000 worth of harnesses from him and he would even take $5 bucks off....Most vendors would knock 10% - 15% off a large purchase...
CHECK OUT MY NEW WEB SITE !
Re: BILL EVANS WIRING HARNESSES ???? [Re: anlauto] #340142
06/09/09 07:52 AM
06/09/09 07:52 AM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
I just installed engine/forward/rear harnesses in my 'Cuda. They looked great,fit great and so far are working perfectly. He made me a custom engine harness and got the order to me quickly.
I would buy from him again.
1971 BS23H1B
Re: BILL EVANS WIRING HARNESSES ???? [Re: tx9cuda] #340143
06/09/09 08:38 AM
06/09/09 08:38 AM
Lexington,VA
68gtxsurvivor Offline
Lexington,VA
I use Bill's on all of the restorations I do about 5 to 7 cars a year and never have had any problems, I've been nuying from Bill for a long time now.
Re: BILL EVANS WIRING HARNESSES ???? #340144
06/09/09 09:28 AM
06/09/09 09:28 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Then you will be stuck never buying any product from any maker EVER AGAIN , you can't please everyone no matter what a bunch of screwballs on the internet tell you .
Re: BILL EVANS WIRING HARNESSES ???? [Re: AdamR] #340145
06/09/09 01:17 PM
06/09/09 01:17 PM
California
super street
super street
California
Never met him or spoke with him before and he repaired it for FREE! Did I expect him to say otherwise? I wouldn't allow it, I bought him lunch!
Re: BILL EVANS WIRING HARNESSES ???? [Re: 70SportSatellite] #340146
06/09/09 04:20 PM
06/09/09 04:20 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
I just ordered one Friday of last week. They were reccomended by a friend of mine, but he did say to check all the bulkhead connections before installing. It should be at my door any day. I ordered it with the Mopar electronic ignition modification. I'm anxious to see how it works. I'll let you know my thoughts when it starts making sparks. Tom
Re: BILL EVANS WIRING HARNESSES ???? [Re: Tommy D] #340147
06/09/09 05:31 PM
06/09/09 05:31 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The biggest complaint with Evans' wiring is bad crimps. If you are going to buy any wiring harnesses from any vendor, make sure you do a pull test on all the crimped connectors. If you are afraid of pulling the connectors off, you should be more concerned that they might cause a fire if they are loose. If you run across a marginal crimp, you can always solder the crimped wire.
Note: M&H does the above when they make the harness and it is part of their assembly process.
You should also check the connectors and make sure they fit tightly together. You can do this with a separate test male connector. Just take your test connector and plug it into each female connector and make sure that all the connectors are a snug fit. If any are loose, you can squeeze the contacts closed with a pair of pliers.
Re: BILL EVANS WIRING HARNESSES ???? [Re: Snoopy] #340148
06/09/09 07:19 PM
06/09/09 07:19 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
While I didn't use them yet I bought a complete harness set for a 71 RR clone I am doin. 4spd. nuetral safety,engine,light and wiper harness's. I will check all of the connections after reading about this but one thing I will say is that he replaced one of the bulhead connectors for me. It was totally different than all of the others and since I spent some $$$ I wanted them to match,I gave it to him at the Nats in Ohio and he made it right...
Re: BILL EVANS WIRING HARNESSES ???? [Re: QuickBpBp] #340149
06/09/09 11:43 PM
06/09/09 11:43 PM
Anonymous OP
Anonymous OP
Thanks everyone! If I decide to go with Mr. Evans,I'll definately check ALL the crimps,especially at the bulkhead! RandyB
Re: BILL EVANS WIRING HARNESSES ???? #340150
06/10/09 06:22 AM
06/10/09 06:22 AM
Anonymous OP
Anonymous OP
big mistake.
Re: BILL EVANS WIRING HARNESSES ???? #340151
06/12/09 12:06 AM
06/12/09 12:06 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Don't be scared off by these guys. If you like one guy then use him, but dont scare off someone else based on some random event. As someone said if Evans was bad we would all know to stay away from them. Fact is they have a good product. Maybe not the greatest out there, but go check out the prices of the other guys, maybe they can afford to put on a smile from you guys while taking your hard earned paycheck. I've seen the Evan's at plenty of shows personally and they have always been willing to answer questions. I guess personally doing an all day show out in the hot sun (even with a canopy) has to be tiring on anyone. Dealing with the public is not the easiest job sometime. Shame someone bought a $1000 worth of harnesses without a discount but life is tough sometimes. What would those same harnesses cost from the other guys? Bet it would have been a significant amount. Like I said, buy who you like. If you know so and so personally and always got good stuff from him and they were friendly to you, then go with your gut. But I think being fair to the other guy should be expected unless you personally have some knowledge of some serious poor workmanship. A suspected bad crimp sucks, but who knows maybe the installer was a little too rough.
Re: BILL EVANS WIRING HARNESSES ???? [Re: moparmojo] #340152
06/13/09 07:45 PM
06/13/09 07:45 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Go with M&H from Year One
Re: BILL EVANS WIRING HARNESSES ???? [Re: Michael] #340153
06/14/09 09:42 AM
06/14/09 09:42 AM
Anonymous OP
Anonymous OP
Thank You all for your experiences and opinions! After talking with my good friend,Ron Wilson(Firefighter3931)I'm going with the M&H harnesses from Year One. He just re-wired his '68' Charger, and said the quality was excellent! Thanks again guys, I truly appreciate it! RandyB
Re: BILL EVANS WIRING HARNESSES ???? #340154
06/14/09 10:11 AM
06/14/09 10:11 AM
Anonymous OP
Anonymous OP
you made the right choice, you wont be disappointed.
Re: BILL EVANS WIRING HARNESSES ???? #340155
06/14/09 12:07 PM
06/14/09 12:07 PM
NORTHERN VA
NORTHERN VA
The only problem I saw with the YO /MH harness is that you had to use that ugly 4 pin ballast resistor that does not look rite on the older cars....OR did they change that part on there harness ?
Re: BILL EVANS WIRING HARNESSES ???? [Re: THESHAKERPROJECT] #340156
06/14/09 12:22 PM
06/14/09 12:22 PM
Snoopy Offline
Snoopy  Offline
That's only on the harness modified for electronic ignition.
Re: BILL EVANS WIRING HARNESSES ???? [Re: THESHAKERPROJECT] #340157
06/14/09 10:50 PM
06/14/09 10:50 PM
Anonymous OP
Anonymous OP
Not a problem! I don't run a ballast resistor with a MSD 6AL control box. Thanks guys! RandyB
