Balancing Flexplate
#338660
06/05/09 01:02 PM
06/05/09 01:02 PM
Posts: 1,371 Tallmadge, Ohio
Butch
Tallmadge, Ohio
Is balancing a flexplate common? This is on my Duster. Why would it look like this?
What are your thoughts?
'74 Duster 440 '04 Hemi Quad Cab Ram '06 Pacifica '78 MGB
Re: Balancing Flexplate
[Re: IcorkSOAK]
#338664
06/05/09 01:18 PM
06/05/09 01:18 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Hey Butch That may have been a cast crank or external flex plate they modified to use in another balancing application. Looks like the balancer was chasing his tail on that project.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: B G Racing]
#338668
06/05/09 02:48 PM
06/05/09 02:48 PM
Butch
Tallmadge, Ohio
So what plate should I use? The front has a Fluidampr on it.
Thanks for the replies.........
[Re: Butch]
#338669
06/05/09 02:55 PM
06/05/09 02:55 PM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
This was on a motor that you KNOW had no balance issues?
If so .. you are going to have to have a new FP balanced TO THE SAME SPEC as this one.....but properly done.
[Re: IcorkSOAK]
#338670
06/05/09 04:39 PM
06/05/09 04:39 PM
Butch
Tallmadge, Ohio
Everything was fine, I took out the tranny to freshen it up and noticed the plate.
If there are no vibration issues what makes this a dangerous condition.
[Re: Butch]
#338672
06/05/09 07:34 PM
06/05/09 07:34 PM
IcorkSOAK
Florida STAYcation
It is dangerous because of the way the FP is all hacked up. I would have a machine shop check the balance JUST OF that FP ....and if all that hacking they did put-it at ZERO ... just get a STD FP.
If there IS an IMbalance ... you are going to have to have that balance-shop duplicate that on a new UNhacked FP.
