Re: Part # for '71 e-body turn sig. switch?
[Re: bremotorsports]
#338536
06/05/09 01:41 PM
06/05/09 01:41 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
wondering if the RIGHT unit with thin hazzard knob and turning on by push in instead pull out like laters is available. I have found the new pieces made are the later kind, and nothing like the 70/ first half 71 kind
[Re: NachoRT74]
#338538
06/05/09 02:04 PM
06/05/09 02:04 PM
NachoRT74
Valencia, España
note the right one on MOST earliers setup ( it does appear diff PN on box ): this is still pull out ON function maybe the 3488477 PN is with the push in ON function here is the later one with cornering lights with 3488805 PN note the diff on hazzard knob this is the new one available ( non Mopar )... note the horn switch is not anymore a roller to roll againts the horn track on wheel/adapter, now is really simply a brass stud. Later hazzard button kind New Mopar part, with cornering light ( new 3488805 piece made ) is with same horn switch kind than the one above( not anymore a roller ) everyone without tilt wheel
[Re: NachoRT74]
#338541
06/05/09 09:10 PM
06/05/09 09:10 PM
Posts: 2,901 New Jersey Bada Bing
bremotorsports
Superceded by 3488805.
Bill Rolik
This PN is with cornering lights and is the later kind... won't fit correctly on push in hazzard kind setup what as far I know is 70 and firts 71 half... just by the thick of hazzard knob. maybe trimming will fit and of course would get the reveresed ON operation
without cornering light, ends on 04 on PN
Correct. The SUPERCEDED switch for 70 cars is 3488804.
Bill Rolik
#338542
06/08/09 10:21 AM
06/08/09 10:21 AM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Bill Rolik
Bill Rolik
For 1971 cars, 3488805 will work?!?!?
[Re: 2fast4yourBrain]
#338543
06/08/09 01:45 PM
06/08/09 01:45 PM
NachoRT74
Valencia, España
the diff between 04 and 05 is just the extra harness to cornering lamps. now, would need to confirm the knob size. this pictured one is supposelly correct for 70 and maybe 71s ? Maybe first 71 half ? on ebay it was on $500 knob is diff thick
[Re: Snoopy]
#338549
06/08/09 03:41 PM
06/08/09 03:41 PM
NachoRT74
Valencia, España
amazing all the diff info and kind of switches, but basically the same 3488805 the same than 3488477, however newer pieces are without roller on horn switch stud. then 3488804 is the same without cornering lamp harness. But if E bodies doesn't have cornering lamps should use 3488804... right ? then we have 2947905... right piece to 70 E body, maybe also first 71 half then I have in B bodies the same than 2947905 but with PUSH IN to knob ON... maybe 2947503 ?
[Re: Snoopy]
#338553
06/09/09 02:04 AM
06/09/09 02:04 AM
NachoRT74
Valencia, España
GREAT INFO!!! thanks.
My car does have whoever the key courtesy light, diff than that one, but steering collar have a cutout for that. I mounted recently. It had before a plastic plug to fill the cutout bolted at same point. Removed the plug and fit the light.
of course we are talking about diff years and bodies, but trying to make a further info research, about what and where was used that or this setup
