SS/AH how do they get them SOOO LOW in front???
#337770
06/03/09 10:35 PM
06/03/09 10:35 PM
Posts: 4,701 On the parachute mount
n20mstr
I know this may never get answered correctly.....
How do these guys get the A body Hemi cars so low in the front and keep the tires stragith up and down???? Are they lengthening the upper arm or shortening the lowers???? I got my car as low as i can. but the tires start to tip in on the top. Just how are they doing it??? I know they are supposed to have "stock" front end parts, that why i may never get a real answer to this
....BAD A$$ STREET CAR.....
Re: SS/AH how do they get them SOOO LOW in front???
[Re: n20mstr]
#337772
06/03/09 10:48 PM
06/03/09 10:48 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I've asked this same question on several different forums and have never got an "real" answer either.Must be some huge secret?? But look into drop spindles....Magnum Force and FatMan has them.
[Re: Chris2581]
#337773
06/03/09 10:54 PM
06/03/09 10:54 PM
Look at the a-arms of one of them. They are smooth and powder coated...They cut them to get correct geometry, along with several other front end parts.. Also all parts have moly heim ends on them not quite factory specs
[Re: n20mstr]
#337775
06/03/09 11:09 PM
06/03/09 11:09 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
Definitely a lot of work in the front ends to get them right. The a arms or lower control arms in our cars aren't cut. A lot of builders approach this area differently. I spent a lot of time on my newest cuda getting everything perfect, which means touching every piece on the front end. Mike Also, don't know anyone using dropped spindles.
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: ScottSmith_Harms]
#337778
06/04/09 07:20 AM
06/04/09 07:20 AM
mr2performance
Lebanon,IN
The bulges only helped after the wheelstand, so the tires don't beat the crap out of the inner fenders. Mike Don't know about widened rails???? Whatever you guys think. Mike
765 483 9371
Post deleted by Defbob
[Re: mr2performance]
#337782
06/04/09 05:30 PM
06/04/09 05:30 PM
