bullet cams
#337355
06/03/09 06:09 PM
06/03/09 06:09 PM
Posts: 8,074 Mt Morris Michigan
mopar dave
Mt Morris Michigan
i talked to bullet cams today to nail down a good profile. they recommended a 275/283@50-.685 lift/1.6 on a 108. sounds a bit large for my combo, what do you guys think? 408 indy 360-1 flow 312@600/209@600, 12:1 comp,ported indy intake,1 7/8 tti,4500 stall,727,4.10,28" tire,car race wieght 3400. street/strip. current cam is 258/264@50-630 lift on a 108. still uncertain.
Re: bullet cams
[Re: emarine01]
#337362
06/03/09 09:03 PM
06/03/09 09:03 PM
Posts: 331 Cincinnati Oh
fasthawk6
Cincinnati Oh
Is that bullet 272 a shelf cam?
could not tell you,it came with the motor when i bought it cam part # is 504000 grind # cra 301/307-06r
Re: bullet cams
[Re: fasthawk6]
#337363
06/04/09 08:19 AM
06/04/09 08:19 AM
mopar dave
Mt Morris Michigan
emarine, what was your experience like with the 260 and 280 cams? fasthawk, thanks for the info. i use nothing but T&D rockers. any other info would be great to have on cams that have worked well in the 408's. nice car fasthawk, here's mine.
Re: bullet cams
[Re: mopar dave]
#337364
06/04/09 10:28 AM
06/04/09 10:28 AM
Posts: 3,695 nc
emarine01
nc
The 280/283 @ 50 cam motion cam had a high power band, good power at 7500 and a little soft on the torque at 5000 , its lift was 645 with 1.5 lsa 107 in at 103, we mud race and went to a bigger tire and the torque down at 5000 became an issue, With a factory 360 block I was trying to build a power band between 5k and 7k so I installed a used comp solid roller 260/262 @ 50 , .630 with 1.5s , 106 in @ 106 ,This cam hits hard @ 5k and pulls real strong to 6700 than starts to fade, the comp cam will pull power into the low 7k range but not in the time frame I need< we only run 200ft, in 250ft the cam is real good , My thoughts are close to yours 268 -272 intake duration with around 4 or 5 degrees more on the exhaust with around 680 lift 108 installed on 104, havent found one close used, when I do we will install and test to see if I have any Idea what I am talking about, this should give me some Ideas for a custom cam I hope
Re: bullet cams
[Re: mopar dave]
#337367
06/04/09 12:49 PM
06/04/09 12:49 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I believe the cam in my 422 is a Bullet with 280/283 and lift of .712/.694. I may be off in some areas. Installed at 104. RyanJ spec'd it for my for a 13to1 motor. Pistons didn't work out and ended up with 11.58to1. With 360-2 heads and intake, 850 Quickfuel, 1 7/8 Hedmans. Has run a best on 6.42@105 in the 1/8th with no tuning. Had some main bearing issues so it is coming back out. The car 60' well but was low to me mph wise. But tuning will help that. Also will mill the heads some to get around 12 to 12.5to1 when putting back together.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: bullet cams
[Re: Ian]
#337370
06/04/09 01:39 PM
06/04/09 01:39 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I have a 416 with Indybrock heads 12.8-1 comp with a tiny Erson it is 246/254@ 50 with .592 lift with a 108 in at 108 and am running 6.53 at 106 in a 2961lb car.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: bullet cams
[Re: Ian]
#337374
06/04/09 02:31 PM
06/04/09 02:31 PM
Posts: 3,695 nc
emarine01
nc
mine seams a bit flat 6700 tops need cam 5000 to 7500 to get the best out of the heads according to indy
Thankx Ian, the thing that I am trying to work out is power band , my comp 260 roller has a kick a$$ band of around 1500 or so and I need 2000 , 5 to 7k is what I an shooting for, this is where lsa and timing come into play , I guess its all some kinda trade , your heads flow more than mine we crap out around 650 @ 325cfm on the intake side, your looking for a 2500 rpm power band, let me know how ya did it
