Re: 1972 Duster 340 #8 cylinder won't fire
[Re: ph23vo]
#337225
08/27/09 09:27 PM
08/27/09 09:27 PM
Posts: 386 Maryland
reno340
Maryland
if you are using fat white electrode platimum plugs dont! if they have the tiny pin like tip they should be ok dan
They have the tiny pin like tip.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
[Re: mopars4ever]
#337227
08/27/09 10:36 PM
08/27/09 10:36 PM
Posts: 386 Maryland
reno340
Maryland
are you sure your not getting coolant in that cylinder?
Yeah, pretty sure. Besides, it just is not firing, oil is not milky and there isn't too much pressure in the coolant system. Doesn't the good compression rule that out?
[Re: buildanother]
#337229
08/27/09 11:10 PM
08/27/09 11:10 PM
Posts: 386 Maryland
reno340
Maryland
If it is runnimg good otherwise, off of idle etc, I'd check for vac leak and for pcv or power brake booster prob as mentioned above. The intake runner for that cyl may have the vac port for those two items.
I found the vacuum advance line was disconnected but it is too late to start it tonight to see if it is the fix. (neighbors ruin everything, lol) I don,t have power brakes and the plug over that port is tight w/ teflon tape added
[Re: reno340]
#337230
08/27/09 11:29 PM
08/27/09 11:29 PM
Posts: 386 Maryland
reno340
Maryland
BTW, do I use the timed or full vacuume advance port for the vacuume advance on the distributer? (timed is passenger side) Just checking to see if it is hooked up rifgt. Currently the distributer is hooked to the timed port and I have the vacuume lines in the stock air cleaner hooked to the full vacuume port. ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: RapidRobert]
#337232
08/28/09 08:16 AM
08/28/09 08:16 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Completely swap the #7 and #8 wires see if the skip moves to #7.
[Re: moper]
#337233
08/28/09 08:08 PM
08/28/09 08:08 PM
Posts: 386 Maryland
reno340
Maryland
![](/ubbthreads/images/graemlins/bump.gif) Any other ideas?
Re: 1972 Duster 340 #8 cylinder won't fire **UPDATE**
[Re: Sixpak]
#337235
02/24/11 01:45 PM
02/24/11 01:45 PM
Posts: 386 Maryland
reno340
Maryland
Update I found a broken valve spring on #8. It is the one right next to the firewall. I have never changed a valve spring. What do I do next? ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: reno340]
#337237
02/24/11 03:30 PM
02/24/11 03:30 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Change it,You need to pull the rocker shaft assembly, take out the plug and either hook an air compressor to the spark plug hole or lower the piston to the bottom of the stroke , feed in a piece of rope and slowly bring the piiston to the top till it stops , now you can use one of those on head spring compressors to change the spring .
