Re: 1972 Duster 340 #8 cylinder won't fire [Re: reno340] #337224
08/27/09 08:19 PM
08/27/09 08:19 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Pull the valve cover and inspect the rockers/pushrods for #8
Crank it over watching those rockers to make sure they are moving.
Re: 1972 Duster 340 #8 cylinder won't fire [Re: ph23vo] #337225
08/27/09 08:27 PM
08/27/09 08:27 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
if you are using fat white electrode platimum plugs dont! if they have the tiny pin like tip they should be ok dan
They have the tiny pin like tip.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: 1972 Duster 340 #8 cylinder won't fire [Re: reno340] #337226
08/27/09 08:36 PM
08/27/09 08:36 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
are you sure your not getting coolant in that cylinder?
Re: 1972 Duster 340 #8 cylinder won't fire [Re: mopars4ever] #337227
08/27/09 09:36 PM
08/27/09 09:36 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
Yeah, pretty sure. Besides, it just is not firing, oil is not milky and there isn't too much pressure in the coolant system. Doesn't the good compression rule that out?
Re: 1972 Duster 340 #8 cylinder won't fire [Re: reno340] #337228
08/27/09 09:48 PM
08/27/09 09:48 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it is runnimg good otherwise, off of idle etc, I'd check for vac leak and for pcv or power brake booster prob as mentioned above. The intake runner for that cyl may have the vac port for those two items.
Re: 1972 Duster 340 #8 cylinder won't fire [Re: buildanother] #337229
08/27/09 10:10 PM
08/27/09 10:10 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
I found the vacuum advance line was disconnected but it is too late to start it tonight to see if it is the fix. (neighbors ruin everything, lol) I don,t have power brakes and the plug over that port is tight w/ teflon tape added
Re: 1972 Duster 340 #8 cylinder won't fire [Re: reno340] #337230
08/27/09 10:29 PM
08/27/09 10:29 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
BTW, do I use the timed or full vacuume advance port for the vacuume advance on the distributer? (timed is passenger side) Just checking to see if it is hooked up rifgt. Currently the distributer is hooked to the timed port and I have the vacuume lines in the stock air cleaner hooked to the full vacuume port.
Re: 1972 Duster 340 #8 cylinder won't fire [Re: reno340] #337231
08/28/09 12:11 AM
08/28/09 12:11 AM
You have both correct
Re: 1972 Duster 340 #8 cylinder won't fire [Re: RapidRobert] #337232
08/28/09 07:16 AM
08/28/09 07:16 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Completely swap the #7 and #8 wires see if the skip moves to #7.
Re: 1972 Duster 340 #8 cylinder won't fire [Re: moper] #337233
08/28/09 07:08 PM
08/28/09 07:08 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
Any other ideas?
Re: 1972 Duster 340 #8 cylinder won't fire [Re: reno340] #337234
08/28/09 09:19 PM
08/28/09 09:19 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Change the plugs to Autolites. Bosch plugs are junk, platinum or not.
Re: 1972 Duster 340 #8 cylinder won't fire **UPDATE** [Re: Sixpak] #337235
02/24/11 12:45 PM
02/24/11 12:45 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
Update
I found a broken valve spring on #8. It is the one right next to the firewall. I have never changed a valve spring. What do I do next?
Re: 1972 Duster 340 #8 cylinder won't fire **UPDATE** [Re: reno340] #337236
02/24/11 12:56 PM
02/24/11 12:56 PM
N.J. north west
1972challenger Offline
N.J. north west
You may have sucked the intake gasket in under the intake. Just a thought
Re: 1972 Duster 340 #8 cylinder won't fire **UPDATE** [Re: reno340] #337237
02/24/11 02:30 PM
02/24/11 02:30 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Update
Change it,You need to pull the rocker shaft assembly, take out the plug and either hook an air compressor to the spark plug hole or lower the piston to the bottom of the stroke , feed in a piece of rope and slowly bring the piiston to the top till it stops , now you can use one of those on head spring compressors to change the spring .
