360 radiator size #336642
06/02/09 09:22 PM
06/02/09 09:22 PM
close enough to branson, mo
razorback Offline OP
what is the adequate size for a somewhat warmed over 360 (intake, carb, headers) i have a 19x19 3 inch in there now, but id like to try to get a 26x16 radiator due to ground clearance. what is the minimun size i need for a 360?
Mazda Rx7 getting a 360..more details later..
Re: 360 radiator size [Re: razorback] #336643
06/04/09 01:30 PM
06/04/09 01:30 PM
anyone?
Re: 360 radiator size [Re: razorback] #336644
06/04/09 11:50 PM
06/04/09 11:50 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
It depends on the motor and the climate I guess, I run a stock 26" rad with my 360 and cools great for the most part, but the temp does start to creep up when idleing for a long time. I don't think i'd want anything smaller in there but I don't have a shroud. A aftermarket aluminum rad probably cools a bit better, I'd think a 26x16 would be OK.
FWIW, in most cars, a 360 got a bigger standard radiator than a 318. The HD 318 rad is usually the standard 360 rad.
Re: 360 radiator size [Re: 440newport] #336645
06/05/09 12:02 AM
06/05/09 12:02 AM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
I'd definately go with a 3 core 26X16 radiator. you'll appreciate it on those hot summer days in the midwest when you want to cruise slow...
Re: 360 radiator size [Re: Dusted_Ya] #336646
06/05/09 01:58 PM
06/05/09 01:58 PM
ok thanks guys, i was considering that but just wanted to make sure it wasnt overkill. now i just need to figure out the leak out the bolt and the exhaust flange and the fast idle problem and ill be good until i find something else.
Re: 360 radiator size [Re: razorback] #336647
06/05/09 02:08 PM
06/05/09 02:08 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Mine is a 360 Magnum with a 7-blade fan, no shroud, 195 tstat, hi-flow w. pump, and a stock 340 radiator. Works just fine. Idling at a stop light for more than a couple of minutes gets it to 210, but never over. I am going to put a shroud and possibly a 80 stat in there, and I don't think it'll have a problem. I guess the stock 340 radiator is 22" with an 18" core (dual-core).
