Page 2 of 3 1 2 3
Re: 727 kickdown adjustment?? [Re: minivan] #332042
05/29/09 07:54 PM
05/29/09 07:54 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Lefty do you have the PTK valve??
It does not feel like it does, I wish it did...
Re: 727 kickdown adjustment?? [Re: minivan] #332043
05/29/09 09:51 PM
05/29/09 09:51 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
My 67 w/ a 3.23 shifts into 3rd at 18 mph under light throttle, just like it did from the factory. The manual states it should be 11 to 15 mph. So depending on your gear ratio, what you have may be correct.
Re: 727 kickdown adjustment?? [Re: BSB67] #332044
05/30/09 10:33 AM
05/30/09 10:33 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I run a trans-go shift kit in my 1971 727. Had it now for 9 years. Manually shift all the time. Shifts as good today as it did 9 years ago. No more than I drive it, maybe 2,000 miles a year, the tranny will out last me. I'm old.
PS, if it's so hard on the transmission, why did Ma Morpar make it possible to manually shift from low to drive, and drive to low? Back when I was a kid, we manually shifted them things all the time. I don't remember anyone having transmission troubles.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 727 kickdown adjustment?? [Re: Junky] #332045
05/30/09 02:03 PM
05/30/09 02:03 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Thanks to all the responses on here..
since adjusting the kickdown lever on the tranny so it goes all the way back at WOT the upshifts are alot better..
BUT,it still will not downshift?? I live on a hill and when I make the turn for my house ( at about 5 MPH) the car will not downshift and it will stay in drive all the way to my house if I do not manually shift it down??
any thoughts to my previous question as to installing a 71 valve body with PTK??
Re: 727 kickdown adjustment?? [Re: minivan] #332046
05/30/09 02:08 PM
05/30/09 02:08 PM
CHRGR69 Offline
CHRGR69  Offline
OK OK and sure grip not posi.....
To much with the semantics on this forum!
Grandma always said I had "hands of gold"!
Re: 727 kickdown adjustment?? [Re: CHRGR69] #332047
05/30/09 02:50 PM
05/30/09 02:50 PM
Lefty Offline
Lefty  Offline
That would be "too" much semantics...
Re: 727 kickdown adjustment?? [Re: Junky] #332048
05/30/09 04:28 PM
05/30/09 04:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That kit addresses some of the issues that cause wear in a stocker.
The intent of being able to manually shift and hold certain gears is to delay shifting on a hard pull and/or for compression braking in the hills.
Again, it's about "occasional" versus "frequent".
Re: 727 kickdown adjustment?? [Re: John_Kunkel] #332049
05/30/09 05:40 PM
05/30/09 05:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Come on John, The transmissions aren't that weak. I have driven my autos since the 60s like a stick and never had a failure because of it. I probably shift them 50% of the time and I know lots of other Mopar guys thet do the same thing with no trans troubles. We all can't be lucky and getting away with out failures. I think you are a bit to worried about this.
Re: 727 kickdown adjustment?? [Re: stumpy] #332050
05/30/09 07:26 PM
05/30/09 07:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Do a little experiment...jack the rear wheels clear of the ground, warm up the trans, place the shifter in "1", run the rpms up to 1500 and manually shift to "2". Don't be surprised if you see the rear wheels come to a momentary stop as the trans shifts to 2nd; this illustrates how much overlap there is when manually shifting 1-2. This overlap causes wear on the band, that's why it's not applied in 1st when in Drive.
Don't believe what I'm saying? Go to page 173 in Carl Munroe's 727 book and he'll say the same thing.
Re: 727 kickdown adjustment?? [Re: John_Kunkel] #332051
05/30/09 07:50 PM
05/30/09 07:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
So, thst hasn't seemed to cause me or anyone I know any problems in the last 40 years. Beside that the rear wheels don't do that with the wheels on the ground and shifting at twice that RPM.
Re: 727 kickdown adjustment?? [Re: stumpy] #332052
05/30/09 08:07 PM
05/30/09 08:07 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
man is this internet thing fun
Re: 727 kickdown adjustment?? [Re: stumpy] #332053
05/31/09 03:28 PM
05/31/09 03:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Lemme tell you about my uncle Bunnion, smoked unfiltered cigarettes and chewed snoose until the day he died at age 93. Proof positive that smoking and chewing don't cause any problems.
Re: 727 kickdown adjustment?? [Re: John_Kunkel] #332054
05/31/09 03:33 PM
05/31/09 03:33 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Re: 727 kickdown adjustment?? [Re: stumpy] #332055
06/01/09 01:16 PM
06/01/09 01:16 PM
BRawls Offline
super gas
BRawls  Offline
super gas
Guys, John has told you why its a problem and that its not a big deal, but will lead to the trans wearing out faster. He explained it well and backs it up with references to the exact page in a book that most of us have. How does anybody know if manual sifting shortened the life of their trans or not? There is no standard to compare it to, some stock trans trans go 140K miles before needing to rebuild, some go 60K. This is kind of like fighting over how many angels can dance on the head of a pin. John's answers are well thought out and back-up, he's only sharing his knowledge.
Re: 727 kickdown adjustment?? [Re: BRawls] #332056
06/01/09 03:24 PM
06/01/09 03:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
And I'm sharing my experience. No big deal.
Re: 727 kickdown adjustment?? [Re: stumpy] #332057
06/01/09 05:38 PM
06/01/09 05:38 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Which one of Carl Munroes 727 books should I buy.. One is $20 and the other is $60?? Both look like the same book on Amazon.com....
Re: 727 kickdown adjustment?? [Re: minivan] #332058
06/01/09 06:19 PM
06/01/09 06:19 PM
scratchnfotraction Offline
I under stand what John is saying on the add wear and tear to it
I also drive them like stumpy,if not harder
I have had a lot of jy stockers last yrs and I have went through 4-5 in a yr
so my ? is...if you are drag racing with a more or less "stock" 727/904 auto
instead of putting it in 1st on launch,put it in 2nd on the colum and then launch and let it do the wot 1-2 shift on its own,then do the 2-3 shift manualy
would that be any better?
less wear on the bands?
Re: 727 kickdown adjustment?? [Re: scratchnfotraction] #332059
06/01/09 07:48 PM
06/01/09 07:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With an automatic valve body, launching in any gear but "1" places all of the strain on the overrunning clutch (sprag) which is a known weak link in the TF, that's why it's not recommended. In "1" the rear band is applied and takes some of the strain off of the sprag. Of course, any second now someone will pop up and declare "I been launchin' in 2nd for xx years and never had a probem". I can only advise.
The best setup is a billet rear servo piston and heavy return spring/retainer, there will still be some overlap on the 1-2 upshift but not nearly as much as with the factory parts.
Re: 727 kickdown adjustment?? [Re: minivan] #332060
07/18/14 02:00 AM
07/18/14 02:00 AM
vilonia, Arkansas, u.s.
marshal Offline
marshal  Offline
I'm havin similar problems with my 67 coronet the kick down linkage and it has a hard shift from 1 to 2 gear and 2 gear seems like it won't shift into 3. What speed does 3 kick in
Re: 727 kickdown adjustment?? [Re: marshal] #332061
07/18/14 05:25 PM
07/18/14 05:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Stock carburetor or aftermarket? If aftermarket does it have the correct Mopar throttle lever adapter?
Assuming the carb is correct, late shifts are usually a result of improperly adjusted TP linkage...shorten the top rod to make is shift sooner.
Page 2 of 3 1 2 3
