Re: Wiring schematic help [Re: TJP] #3311429
06/15/25 06:20 AM
06/15/25 06:20 AM
Greenville, PA
redraptor Offline OP
Greenville, PA
Originally Posted by TJP
i believe you would find American Autowires instructions to be exactly what your looking for and they have a good tech support if you would need it.
Thanks, those look good. I'll print them off tomorrow.
Re: Wiring schematic help [Re: Mike P] #3314902
07/05/25 06:49 AM
07/05/25 06:49 AM
Greenville, PA
Greenville, PA
Got started on this project las week. Got most everything run to where it's supposed to go. Wired some stuff up and tested. He's got more components to buy so kinda on hold for now. Will update when we fire it up or catch it on fire! panic
Re: Wiring schematic help [Re: redraptor] #3314961
07/05/25 11:21 AM
07/05/25 11:21 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
sounds good. up
beer
Re: Wiring schematic help [Re: Moparite] #3315113
07/06/25 07:31 AM
07/06/25 07:31 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Originally Posted by Moparite
From what I seen painless is for basic wiring needs. You may be able to fine one that would work but from what your description says some mods will be needed. I would look around and see what's available. Make a wiring diagram added to whatever you get for future reference. Another option would be to check out some early 80's cars wiring harnesses that maybe could be used. There you will already have many different wire colors and a factor wiring diagram. From that modify it to work with what you have. Years ago you could walk around junk yards and look for something like this, Today is another story.
I've done the adapt a newer vehicle harness trick and it works. Obviously this guy is going all Chevy so using a Chevy harness would be the way to go. Plus you can probably buy a repop depending on what the donor truck was. Sounds like late 70s Chevy pickup.
Angry white pureblood male
