Re: '14 JKU M-380 - "Kilroy"
[Re: stumpy]
#3313168
06/26/25 04:03 PM
06/26/25 04:03 PM
Posts: 430 Falcon, CO
Mad-Max
Falcon, CO
yes - all indications are coming from the "valvetrain", spread out 'everywhere' - no single specific location - just 'all of it'. My next step...if I decide to go there...is to pull the valve covers and run it to try again directly on the hardware...
71 Demon (on deck): Magnum 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy": Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 52 Willys M-38 "Poncho" 14 Ram 4500 "Big Mack": 6.7 CTD, Aisin, 4:10s, 4x4
[Re: Mad-Max]
#3313829
06/30/25 01:40 PM
06/30/25 01:40 PM
Mad-Max
Falcon, CO
...so this was interesting...- I pulled the timing chain cover back out to put an intact/not-drilled lifter valley plug back in...and in the process discovered that there is no 'kit' for replacing a damaged oil pan gasket if...like me...yer unlucky enough to rip the gasket when removing the timing chain cover. Ripped the oil pan gasket...but there are no kits out there for a replacement 'front edge' of the Magnum oil pan gasket...so I had to get another complete oil pan gasket and cut off the front edge of it so I could complete the timing cover re-seal. Good times...but it worked fine. Also had to take a sharp chisel and 'cut away' the old pan gasket to make way for the new section. Just interesting that no such kit exists for just that situation. apart - ![[Linked Image]](https://i.imgur.com/v6zrbGC.jpg) ripped oil pan gasket - ![[Linked Image]](https://i.imgur.com/cEK82fN.jpg) cleaned up edges - ![[Linked Image]](https://i.imgur.com/2wuPIAS.jpg) new gasket ready to go in, and I can say is was real fun getting both the pan gasket lined up with the crank seal while also getting the cover gasket lined up with the block... ![[Linked Image]](https://i.imgur.com/mnzERpH.jpg) Meanwhile I installed a set of Comp #7827 pushrods (6.821 long) which should net about a .040-.050 preload, which should be perfect. I don't expect it to change anything but they won't hurt.
[Re: poorboy]
#3314600
07/03/25 06:18 PM
07/03/25 06:18 PM
Mad-Max
Falcon, CO
[Re: poorboy]
#3314729
07/04/25 11:10 AM
07/04/25 11:10 AM
Mad-Max
Falcon, CO
nope - getting a shorter belt
[Re: Mad-Max]
#3314834
07/04/25 06:05 PM
07/04/25 06:05 PM
Posts: 2,871 541 slobovia
A990
541 slobovia
nope - getting a shorter belt FWIW, I've been running a 6 rib belt on my Dakota for years and years with no issues.
[Re: A990]
#3314942
07/05/25 09:58 AM
07/05/25 09:58 AM
Mad-Max
Falcon, CO
...yah I thought about that but my OCD said 'nope'...  --- besides, as big as the rocks are that I'll be playing in I'll take as much 'grip' on the power steering pulley as possible...
[Re: Mad-Max]
#3315150
07/06/25 11:19 AM
07/06/25 11:19 AM
Mad-Max
Falcon, CO
well...with the engine full of coolant and all buttoned up I had it running yesterday......and I am cautiously happy to report that...as far as I can tell...(along with two other friends who were standing next to it with me)...the engine is...quiet...now. The only explanation I can figure is...to my continued astonishment...the newest set of pushrods...and the calculated .050 of lifter preload...has indeed quieted down the engine chatter. I honestly didn't think the new 'rods would result in anything...but it is certainly plausible that the 'rods now placed the lifters right in the proper "sweet spot"...apparently right at/near the .050 preload range. I've had them with .130 and .020 preload...which...apparently...was either too much or too little...but again the engine now indeed sounds 'silent', the only sounds coming from the normal items like the Sniper and fan and such. I'll report back after a few more days of running...but for now I'm just happy the engine is sounding the way I've been wanting it to.
Might have a tiny water pump leak at the pulley seal - time will tell if it's an actual leak or just a 'wake-up' drip, and like before it runs nice and cool. The power steering pump pulley seems to have a very slight 'bobble' to it when running and may have been cored out slightly off kilter...but the steering also seems to be better, and next trail run I'll know for sure if it's enough of a shaft rpm increase to suit the system.
