best battery to put inside oem red cap battery ?
#3314574
07/03/25 03:39 PM
07/03/25 03:39 PM
Posts: 1,022 montreal,quebec,canada
buzz440
Well..... my mopar repro battery finally let go. My battery already has one of those junk chinese agm in it, so no gutting needed however it is fully sealed no trap door on the bottom where you can remove 4 screws and the bottom panel comes off so, cutting the bottom will be nessesary but before I do this I need to know if a Optimum or Oddessy battery will fit inside the casing..... if so what model, make, size & number do I need and of course the battery spec's, this is for a group 27 red cap battery.
Later,BUZZ
Re: best battery to put inside oem red cap battery ?
[Re: buzz440]
#3314581
07/03/25 04:13 PM
07/03/25 04:13 PM
Posts: 549 Charlotte, NC
Kowal
Charlotte, NC
I use an Odessey AGM28L, I get it from Battery Mart. Works really well. Double check the size before ordering, they refreshed some of their offerings lately. I have done three of these to date, two have been in constant use and work great! I cut the top off with a dremel, glue it back on with black RTV. I use Yamabond black RTV which dries really hard. Also, you will need to chisel out the epoxy in the bottom that is holding the Chinese generic in place in order to fit the new AGM. I would do the dremel work outside, pretty messy as you make the cut.
'69 Hemi Charger 500, ‘13 Viper GTS (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Kowal]
#3314756
07/04/25 12:30 PM
07/04/25 12:30 PM
Posts: 4,814 Motor City
6PKRTSE
Motor City
I have used Odyssey along with whatever other brand name that is on sale in my repro conversions.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1970 Challenger R/T S.E. 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic 5.7L
