66 Plymouth Valiant, 273/904, original motor and trans. Fresh motor, carb to pan, .030 over, forged pistons, CR ratio approximately 9.4 to 1, 920 heads, stainlesss valves, mild porting, HP 273 solid cam, LD4B, Carter 9636.
Fresh Radiator, all brackets go with the motor, has brackets to mount aftermarket AC, single 2 1/4 exhaust with high flow muffler and HP resonator. Transmission has a shift kit with a fresh converter, many new assecessories, starter, electronic ignition etc.
Rebuilt front end, FF sway bar, Bilstien shocks, extra set of springs, BFG 215/60/15 on TT Thrust 2, converted to Big bolt pattern with 75 Disk brakes
Decent interior, original AZ car with patina. Some rust pin holes in the trunk and the typical rust patch in the lower left quarter panel.
Good starter hot rod.
The only thing that needs to be done install the engine/trans and drive.
$6500
Shipping is on the buyer
Mesa, AZ
