MSD remote vacuum advance?
#3311483
06/15/25 02:02 PM
06/15/25 02:02 PM
Posts: 7,720 Minnesota
Hemi_Joel
Minnesota
Hi, is there a remote vacuum advance module that you can run a vacuum line to and plug it into an MSD to get vacuum advance on a locked out distributor? I think I remember seeing some kind of MSD years ago that had a vacuum port, but I can't find it on the web. I know that sounds like a weird thing to want, but I find that my drag & drive Hemi runs way better and gets better fuel economy on the street with vacuum advance. But there is a firewall clearance issue with having a vacuum can on the distributor. (Early Hemi)
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: MSD remote vacuum advance?
[Re: Hemi_Joel]
#3311594
06/16/25 10:40 AM
06/16/25 10:40 AM
Posts: 8,169 Tulsa OK
Bad340fish
Tulsa OK
The MSD boxes with the vac reference you are thinking of was probably the 6 BTM IIRC. They were for retarding timing with boost, I am not sure if that would work the other way or not. I am pretty sure they no longer make that model.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3311695
06/16/25 09:20 PM
06/16/25 09:20 PM
Posts: 5,217 CT
GTX MATT
CT
You may be able to achieve what you want with a 6AL2 programmable but you will need to run a map sensor, i’m not sure if it will let you adjust timing under vacuum though. It may be boost only.
[Re: mercman1]
#3312898
06/24/25 09:19 PM
06/24/25 09:19 PM
Hemi_Joel
Minnesota
[Re: GTX MATT]
#3312939
06/25/25 07:42 AM
06/25/25 07:42 AM
Posts: 3,063 A shed in England
Tig
A shed in England
You may be able to achieve what you want with a 6AL2 programmable but you will need to run a map sensor, i’m not sure if it will let you adjust timing under vacuum though. It may be boost only. You can program a vac advance curve on the 6AL programable down to 29 in/hg (1 Bar or -14.7 psi) using the correct MAP sensor (MSD lists it as PN2311, 1-bar for N/A engines). If you have an MSD Grid, there is also a module available (PN7762) which allows you to do the same but can also map ignition timing for boost up to 45psi (3 bar). Page 13 below references the vacuum / boost control on the 6AL (programable). https://documents.holley.com/265ea1b84039cc125d4c605e79a20985a08a9c12.pdf
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
