Mike Moran BBM build video #3310505
06/09/25 11:16 AM
06/09/25 11:16 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Interesting, but for me it raises more questions than answers
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Mike Moran BBM build video [Re: Brad_Haak] #3310550
06/09/25 01:02 PM
06/09/25 01:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Agreed. Way more.
Re: Mike Moran BBM build video [Re: fast68plymouth] #3310567
06/09/25 01:40 PM
06/09/25 01:40 PM
an8sec70cuda Offline
I guess he's one of MCH's preferred customers. work
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: Mike Moran BBM build video [Re: Brad_Haak] #3310571
06/09/25 01:44 PM
06/09/25 01:44 PM
Anyone recognize that engine dyno brand? confused
Re: Mike Moran BBM build video [Re: an8sec70cuda] #3310572
06/09/25 01:53 PM
06/09/25 01:53 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
MCH ported those heads overnight?? Thats crazy huh
anyway, thats def a nice street car engine, wonder what it would run with about 275-300hp nitrous plate on it ?? whistling
....BAD A$$ STREET CAR.....
Re: Mike Moran BBM build video [Re: Cab_Burge] #3310573
06/09/25 01:54 PM
06/09/25 01:54 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
yes, it's a land & sea dyno
Joe
Without Data, you’re just another guy with an opinion.
Re: Mike Moran BBM build video [Re: Cab_Burge] #3310575
06/09/25 01:57 PM
06/09/25 01:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Most if not all shops with a single cell dyno's are usually "happy dyno's" to begin with. We do a ton of OEM work so all our dyno's are SAE calibrated. Almost every engine we dyno after someone else has dyno'd it prior always makes less power and torque. How much, depends on the engine.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1970 Challenger R/T S.E. 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic 5.7L
Re: Mike Moran BBM build video [Re: 6PKRTSE] #3310582
06/09/25 02:29 PM
06/09/25 02:29 PM
I've personally seen that up
Our local Studka engine dyno operator was testing one of my motors several years back when I was doing a lot more engine building and dyno testing. He did calibrate their dyno after me asking him how often and how long ago was it last calibrated. He didn't know so we calibrated it and that motor lost 50 HP and similar torque ( I don't remember exactly how much torque, sorry: blush) with no other changes to the motor shock puke
He was the 2nd or 3rd operator of that dyno that I had do testing for me on it work shruggy
The owner of that dyno did not run it, he let several of his local mechanic friends use and run it. He died several years ago so I am now using a different shop now in Mefford, OR which s a lot further drive whiney That shop uses a Super Flow engine dyno that has all the latest's updates on it and seems to be a good one up luck
I've come to the conclusion that the gross numbers don't really matter as long as I can see the changes when making tuning and part changes wrench up work
Re: Mike Moran BBM build video [Re: Cab_Burge] #3310684
06/10/25 12:12 AM
06/10/25 12:12 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Victor heads
Re: Mike Moran BBM build video [Re: CSK] #3310685
06/10/25 12:37 AM
06/10/25 12:37 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The amazing thing to me was that they thought I wanted that bad music blasting in my ears for 5 minutes.
2011 Drag Pak Challenger
Re: Mike Moran BBM build video [Re: rickseeman] #3310850
06/11/25 12:02 PM
06/11/25 12:02 PM
Loudoun County, VA
Loudoun County, VA
grin
Misc things that popped into my head after watching the full video the 1st time and then looking more closely at certain things going through it a second time:
- no mention of displacement, compression, cam specs, etc., and I'm pretty sure it's NOT a "440" now
- I can't imagine my out-of-the-box Victors would have made almost 700 HP, but picking up 50-60 HP with a full port job sounds right (regardless of what the engine really made before)
- the MCH porting wasn't to Max Wedge size, maybe somewhere between standard and MW like Hughes' "standard port" CNC Victors had
- CNC'd chambers look much bigger than original size ==> bore overhang?
- Harland Sharp rockers, FWIW
- nothing I've heard about Bob at MCH over the last decade would inspire me to send him anything; guess Mike and Bob must be buddies
- I've heard of Land & Sea dynos for years, but don't know anything else about their reputation, accuracy, or... ?
- nice to see an EFI setup that seems to run OK on a combination like that, even though I'd turn up the freakin' idle speed
Re: Mike Moran BBM build video [Re: Brad_Haak] #3310919
06/11/25 04:57 PM
06/11/25 04:57 PM
PA
moparacer Online tonguue
moparacer  Online Tonguue
PA
grin
He was all done at 6200 or so that tells you it's got the big engine with a little head syndrome going on. He did say it was a "street" engine.....
And when they were disassembling the heads you can see someone was in there with a burr bit digging around. So technically they weren't OOTB.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Re: Mike Moran BBM build video [Re: Brad_Haak] #3310984
06/12/25 01:44 AM
06/12/25 01:44 AM
AndyF Offline
AndyF  Offline
With those numbers I'd assume it is a 505 with 12:1 compression and a decent solid roller cam. But he doesn't give any details and I couldn't see any specific part numbers anywhere. I'd think a 505 could make 700 hp with Victor heads but 6000 rpm peak does seem a little low. Heck if I know. Pass car headers don't help with the power numbers that is for sure. Valley plate design doesn't match the heads, guess they are hoping the RTV will keep it sealed up. Big Stuff EFI is a weird choice but I suppose he uses it since it is what he knows. Big Stuff is really outdated, about the only people that use it are the No Prep guys.
Re: Mike Moran BBM build video [Re: rickseeman] #3311145
06/13/25 02:55 AM
06/13/25 02:55 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Could have been worse, could have been Country & Western!
Alan Jones
Re: Mike Moran BBM build video [Re: LA360] #3311232
06/13/25 02:46 PM
06/13/25 02:46 PM
SoCal
Brian Hafliger Offline
SoCal
Ha ha ha ha
Brian Hafliger
Re: Mike Moran BBM build video [Re: LA360] #3311234
06/13/25 02:49 PM
06/13/25 02:49 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I love shopping at Tractor Supply and Atwoods (farm stores) but have to wear earplugs so I don't commit a heinous act.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Mike Moran BBM build video [Re: GY3] #3311451
06/15/25 10:45 AM
06/15/25 10:45 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Why would I bother to watch an engine build or test without specs? I’m glad you guys gave me a heads up. I mean, that’s pretty useless is all I can say.
I want my fair share
Re: Mike Moran BBM build video [Re: Brad_Haak] #3311574
06/16/25 08:45 AM
06/16/25 08:45 AM
Big Rapids Michigan
mopar dave Offline
mopar dave  Offline
Big Rapids Michigan
Not far off my 12.5:1 511 combo. Victor heads with a 330 intake port that flowed 356cfm@.700. Solid roller 269/275@50 on a 108/.700 net lift. Run thru 2" headers ran a 6.3@109 1/8 at 3400#. Compute to 1/4 mile shows only 640hp on the moroso slid rule.
