STEERING BOX SOURCES #3311174
06/13/25 09:55 AM
06/13/25 09:55 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
A friend who's not into the internet, asked me about a source for reman'd ( not rebuilt ) steering boxes. He's doing a 70? Chevy Camper Special.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: STEERING BOX SOURCES [Re: Magnumguy] #3311196
06/13/25 11:38 AM
06/13/25 11:38 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Redhead steering out of Washington state is a good place. Have seen some bad reviews about Steer and Gear. Borgeson is another possible source since its a Saginaw/Delphi box most likely.
Carl Kessel
Re: STEERING BOX SOURCES [Re: CKessel] #3311352
06/14/25 02:28 PM
06/14/25 02:28 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
All of the "reman or rebuilt" ones use old worn parts. Redhead used to have a pic of a guy with a line of steering gears on a table he was reusing. If you want tight steering you need 100% new parts. And few to none offer that so you are stuck with what's available or modifying to use something else that is "new".
Re: STEERING BOX SOURCES [Re: Moparite] #3311557
06/16/25 01:34 AM
06/16/25 01:34 AM
Minnesota
Hemi_Joel Online content
Hemi_Joel  Online Content
Minnesota
Rockauto.com has new and rebuilt, power and manual. I put a new cardone box in my '93 Dodge D 300 and have been very satisfied with it.
https://www.rockauto.com/en/catalog/chevrolet,1970,c20+pickup,5.7l+350cid+v8,1031690,steering,steering+gear,7416
Still, the rest of the front end has to be in decent shape and the alignment set properly or it won't go straight down the road even with a new box.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: STEERING BOX SOURCES [Re: Hemi_Joel] #3312480
06/22/25 12:12 PM
06/22/25 12:12 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I've had good luck with a company called Midwest.
Coincidentally they're within "seeing distance" of midWAY airport Bedford park IL on that side of street, Chicago across the street.
Re: STEERING BOX SOURCES [Re: volaredon] #3312592
06/23/25 01:23 AM
06/23/25 01:23 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
