For Sale - Vehicles/Parts - Modern Mopar - 2nd Quarter
#3297850
03/30/25 06:32 PM
03/30/25 06:32 PM
Posts: 15,759 Norwich CT USA
moparts
Norwich CT USA
Re: For Sale - Vehicles/Parts - Modern Mopar - 2nd Quarter
[Re: moparts]
#3300524
04/13/25 01:42 PM
04/13/25 01:42 PM
Posts: 893 In the Middle
roadntrack
In the Middle
300C Heritage right front door mld O.E. from 2006-2009 NOS Mopar number 4806348AB item 13 in drawing $150 plus shipping
Remember when cars were FUN?
SOLD*thanks Moparts!
[Re: roadntrack]
#3300977
04/15/25 06:19 PM
04/15/25 06:19 PM
Posts: 16,698 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I have to make room at my house and going to sell my beloved 2010 Charger Pursuit 5.7. I have owned it since 2018. It's in VERY good shape and runs great. 96k miles and only 132 idle hours which is extremely low for Police car. I have never ever heard this 5.7 tick or make any odd engine noises. It can sit for a month, start right up and with ZERO lifter noise. It uses zero oil between oil changes (every 5k miles). It runs super strong and while I don't beat it, every once in awhile when you need some acceleration to merge or something it is really impressive. I've taken meticulous care as I do with all my cars. The only "mod" I made is a catch can. Otherwise all stock with VERY cold a/c, hot heat, and all HVAC doors work perfectly. Every single thing works as it should except horn which was disconnected to connect to a siren. All p/l, p/w/, wipers and squirter, etc. work perfectly. I've done a huge amount of preventative maintenance such as (all OEM Mopar) Police severe duty radiator, Water Pump, Thermostat, Police Alternator, idler pulley, HD serpentine belt, coolant flush and distilled water mix added and more. I dropped trans pan and put new filter and new fluid short time ago. It shifts perfectly. I installed new OEM headlight assemblies not too long ago so they are still nice. Newer Power Stop drilled and slotted rotors, new calipers and pads, new sealed hub assembly. All of this other than alternator was preventative. The plastic cowl cover is still good without cracking and wiper arms aren't all peeled. The car has newer Eagle RSA radials and newer TPMS. There are no warning lights on dash. Paint is very shiny with some touched up chips from it's road years. ZERO rust anywhere. It has a working very bright LED spotlight.
$4500 firm. I priced it to sell IMO so there doesn't have to be a lot of back and forth on price. Clear Title in my name and clear carfax when I bought it years ago and I've never had so much as a fender bender.
Please message me here if interested and we can talk. You truly can buy sight unseen with confidence, or drive it anywhere. I'll add more pics.
Edit: Cruise works and it has a CD player but I haven't tried it in so long. I will test it soon. Interior is very nice. No tears in seats. You can see some wear on driver's seat but no splits and dash is good and o separating. Ceramic window tint in VG condition. Nice Nenno products after market console with arm rest and storage. Weather Tech matts in front, Dodge in back. Bottom engine cover/belly pan is HD Police aluminum and in good shape.
I have factory manual and Window Sticker
Facts are stubborn things.
[Re: moparts]
#3301495
04/19/25 11:59 AM
04/19/25 11:59 AM
Posts: 645 Monroe NC
Luvcars69
Monroe NC
2009 Dodge Charger Pursuit 115k miles 5.7 Hemi.
Clean rust free inland NC (Charlotte area) car.
This car was reconditioned to include the following services performed:
Rear end lube, transmission fluid & filter, engine oil & filter, antifreeze & thermostat changed.
New spark plugs, headlight housings & bulbs, A/C compressor & clutch, air filter & cabin air filter changed.
New front struts, inner & outer tie rod ends, upper & lower control arms, bushings & ball joints, front sway bar bushings & end links. Four wheel alignment.
New front rotors & brake pads all around.
Following new parts installed: Radiator, heater hoses, water pump, coolant overflow bottle, serpentine belt, idler & tensioner pulleys, rear sway bar end links, & wiper blades.
Brake fluid changed & throttle body cleaned.
Factory center console added.
Interior carpet, seats removed & shampooed.
Price $6500. Cash only, no trades!
Text Tom at: 704-771-2626.
Message me here.
or
Email me at: tarodgers0627@icloud.com
Making cars faster one at a time!
19 Challenger Scat Pack white 16 Ram Sport SB Regular cab black 14 Charger Pursuit silver 78 Magnum 400 gray 69 SuperBee 512 Passion 4-speed 4:10
[Re: moparts]
#3301501
04/19/25 12:10 PM
04/19/25 12:10 PM
Luvcars69
Monroe NC
2010 Dodge Charger Pursuit 129k miles 5.7 Hemi
New spark plugs, headlight housings, bulbs, air filter, cabin air filter & wiper blades.
New inner & outer tie rod ends, upper & lower control arms, bushings & ball joints, front sway bar bushings & end links. Four wheel alignment.
Brake pads 75% all 4 wheels. Tires 75% tread.
Following new parts installed: Mopar cam, lifters, timing chain, guides, valve seals, Melling HV oil pump, heater hoses & both fuel pumps.
Brake fluid flushed & throttle body cleaned.
Will be NC state safety & emissions inspected before delivery.
NOTE: THIS CAR DOES HAVE HAIL DAMAGE, FRONT & REAR WINDSHIELDS WERE REPLACED.
FIRM
FIRM Price $6,500 Cash only, no trades! FIRM
FIRM
[Re: moparts]
#3308540
05/29/25 01:43 AM
05/29/25 01:43 AM
Posts: 1,019 Cumberland, MD
Moparguy383
Cumberland, MD
2010 Challenger R/T, 115,000 miles. SUPERCHARGED 5.7 Hemi, Magnuson supercharger 7 pounds of boost. 6 speed manual with Barton short throw shifter. Black leather interior, heated front seats. PW, PDL, Cruise, cold A/C, keyless entry, Dynomax Ultraflow mufflers. Nice car, with clean title. Gets 22 m.p.g. on the freeway. $16,500. Message me here or call two four zero-nine two zero-seven three three eight. Ask for Steve
