How many miles before your Cummins needed injectors?
#3308486
05/28/25 04:53 PM
05/28/25 04:53 PM
Posts: 5,051 Wichita
GY3
Wichita
My '09 6.7 managed 447,000 before it needed them replaced.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: How many miles before your Cummins needed injectors?
[Re: GY3]
#3308504
05/28/25 07:00 PM
05/28/25 07:00 PM
Posts: 891 Avondale AZ
Prodart440
Avondale AZ
I am at 310,000 or so, with an 05 5.9l, and the stock originals are going strong.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: J_BODY]
#3308601
05/29/25 12:26 PM
05/29/25 12:26 PM
Posts: 2,183 Byron, NY
W.I.N. Racing
Byron, NY
12v….. only when you wanted performance upgrade 24v VP44 ERA….. Same 03-07 common rail….. done a ton in the 150-200k range. 08+…… other than a rare electronic failure or def damage I haven’t put a set in one yet just from general wear. I attribute that to much better filtration. Pretty much sums it up...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3308652
05/29/25 03:11 PM
05/29/25 03:11 PM
GY3
Wichita
TBH, not sure if it was an injector starting to fail or the wiring that is integrated with the valvecover gasket? The insulation on the wires start to get hard and brittle over time.
I just went ahead and did both while in there.
'63 Dodge 330
[Re: GY3]
#3308685
05/29/25 06:54 PM
05/29/25 06:54 PM
Posts: 4,809 Motor City
6PKRTSE
Motor City
228+ on my 04.5 dually so far.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1970 Challenger R/T S.E. 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic 5.7L
[Re: J_BODY]
#3308893
05/30/25 07:43 PM
05/30/25 07:43 PM
Posts: 9,384 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
12v….. only when you wanted performance upgrade 24v VP44 ERA….. Same 03-07 common rail….. done a ton in the 150-200k range. 08+…… other than a rare electronic failure or def damage I haven’t put a set in one yet just from general wear. I attribute that to much better filtration. My 06 has the aftermarket filters, fuel and water separator, CAT filter that does 2 microns. The stock filter is 10 microns and injectors stop up at 4-5 microns. Cummins told Chrysler of this issue with the common rail injectors but they said NO, $6000 to replace, money for the service department lol. I think I’m down to just two orifices still open (has 3). Doesn’t run to good on regular mode so I keep it in tow mode with programmer box. 155,000 miles.
[Re: cudaman1969]
#3308950
05/31/25 07:25 AM
05/31/25 07:25 AM
Posts: 7,106 ohio
ruderunner
ohio
92 with 200,000, all original
Angry white pureblood male
[Re: ruderunner]
#3310406
06/08/25 04:54 PM
06/08/25 04:54 PM
Posts: 287 Bennett, Colorado
Charger69RT8
Bennett, Colorado
99 24V 305K no issues so far.
2012 Challenger SRT 2012 Charger SXT AWD 69 Charger R/T 78 Chrysler New Yorker 440CI 89 Dodge Daytona ES 2.5L Turbo 99 Ram 2500 4X4 5.9L6
[Re: Rhinodart]
#3310620
06/09/25 05:40 PM
06/09/25 05:40 PM
GY3
Wichita
301K on my 2010 with original injectors. However, I lost two engines, a 2004 and 2005 with injector issues, the 04 had one go wide open and hydraulic'd the engine spitting out a rod, the 05 had one go dead burning a hole in a cylinder. Both were in the 200K range... Between this and transmissions, you have the worst luck of anyone I've ever seen!
'63 Dodge 330
[Re: GY3]
#3310627
06/09/25 06:10 PM
06/09/25 06:10 PM
Posts: 552 SW CO
HemiSportFury
SW CO
220,000 miles on my '03 HO.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 227,000 miles and still going strong
[Re: GY3]
#3310794
06/11/25 12:34 AM
06/11/25 12:34 AM
Posts: 12,661 Kalispell Mt.
HotRodDave
Kalispell Mt.
I won't own a modern diesel but I work on them for customers and 200,000 to 300,000 is pretty normal, some more and some less but it costs more than replacing the entire engine in a hemi truck.
[Re: moparx]
#3310885
06/11/25 02:46 PM
06/11/25 02:46 PM
Posts: 44,467 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
301K on my 2010 with original injectors. However, I lost two engines, a 2004 and 2005 with injector issues, the 04 had one go wide open and hydraulic'd the engine spitting out a rod, the 05 had one go dead burning a hole in a cylinder. Both were in the 200K range... Between this and transmissions, you have the worst luck of anyone I've ever seen! i certainly have to agree with this !  you must have been REAL BAD in a previous life, and now are paying the price in this one. Nope, I was real bad in my youth, about even with karma now. I have 301K on my 2010 Cummins with the 68RFE and it is probably time to do a service if nothing else. I put 80-100K miles on my trucks hauling open and enclosed trailers, got 422K on my 2015 Hemi Ram now. But I am trying to figure out what the filter is on the passenger side frame rail. I've had the fuel filter changed several times but nobody ever mentions the filter there, looks like it has been there for a long time, maybe the water seperation filter?
JB Rhinehart, Realist
A-Body's RULE!
