Re: 360/408 JE / SRP pistons
[Re: 572charger]
#3306144
05/15/25 12:36 PM
05/15/25 12:36 PM
Posts: 204 Texas
Chief
Texas
4 1/2 stroke Crankshaft Specialties crank for a RB block, fresh from crankshaft shop. 20/20 undersize. 500.00 and you ship from 76539, or pick up. Contact me here or text 254-2nine12six28
Thanks Dave
Dave Covey
Indy IC RB Dominator Intake
[Re: Chief]
#3307110
05/20/25 02:21 PM
05/20/25 02:21 PM
Posts: 257 Wisconsin
Jet Doc
Wisconsin
For sale, Indy IC 12 RB Dominator intake for RB engines only, bolted to engine and never ran, dirty from sitting. $550 shipped PayPal plus 3%, money order or local pickup. Thanks!
Holley 5.7 Dash
[Re: Jet Doc]
#3307173
05/20/25 08:16 PM
05/20/25 08:16 PM
Posts: 1,826 North Dakota
Azzkikrcuda
North Dakota
New in box, part #553-103 $400+shipping, PM here if interested
The only Carbs I care about are under the hood!
Re: For Sale - Race Parts - 2nd Quarter
[Re: moparts]
#3308640
05/29/25 01:47 PM
05/29/25 01:47 PM
Posts: 128 Nevada
theman440
Nevada
This is a 727 transbrake valve body made by JW Transmissions in Florida. Reverese pattern, It DOES NOT have low band apply. Works great, I just don't need it anymore. Clean & ready to install. $300 plus the ride.
** I would consider a trade - I want a set of 15x7 Magnum 500 wheels for my convertible **
[Re: theman440]
#3308997
05/31/25 02:08 PM
05/31/25 02:08 PM
Posts: 5,146 new jersey usa
11secdart
new jersey usa
Misc parts For Sale , selling off some parts to finance my spare motor build : , B&M flex plate for 727 ( SFI expired ) $40 , Small block chrome valve covers $35 , -8 hose 28 inches long $25 , K&N filter 8 1/2 X 4 $25 , K&N extreme filter top 9 inch diameter $25 ( not pictured ) or consider trade for Victor 340 plus $ , prices negotiable , lbvracing@aol.com or pm. FLEX PLATE AND FILTER LID ARE SOLD, H pipe no longer available
[Re: 11secdart]
#3309034
05/31/25 06:01 PM
05/31/25 06:01 PM
Posts: 1,652 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Used: SPARCO Racing Jacket slight fading and small partial hole- shown in picture. Pants good shape. Gloves small separation in thumb stitching, can be resewn, All LARGE in size. Located in Ringtown, Pa. Asking $125 for all.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: moparts]
#3309983
06/06/25 09:47 AM
06/06/25 09:47 AM
Posts: 5,948 Florida
Locomotion
Holley carb related parts -odds & ends1) Summit 200PV36 - Holley power valve plug (single) - $3.002) Holley 135-10 30ccpump diaphragm (GFLT) - $8.00 ea. (4 available) (SOLD 2)3) BG 12001 Pair steel jet extensions - $6.00 ea. pr. (2 available) (SOLD 1 SET.)4) Bill Mitchell 217-21825-5 - Accelerator pump squirter check needles (5 pack) - $10.005) Holley 121-7 Hollow accelerator pump squirter straight slot screws for .040"+ nozzles (single pk.) - $10.00 ea. (2 available) 6) Summit 200252 Holley30cc pump diaphragm (std.) - $3.00 ea. (2 available) 7) Mr. Gasket 6060 Pair Holley jet extensions - $6.008) Moroso 65225 Holley nylon float bowl washers (10 pk) - $8.00 (SOLD)9) Russell 641090 Holley 4150 fuel line kit (USED) $30.00_________________________________________________ 10) Holley/ROL CM0055-001 Composite 4-hole base gasket - $3.00 ea. (11 available) 11) Holley Composite open base gasket - $3.0012) Bill Mitchell 217-20461-1 Hi-flow squirter screws (Allen head) - $8.00 ea. (2 available) 13) Holley 26-36 Power valve plugs (2 pk) $5.0014) Holley 20-64 Universal throttle lever stud. $10.00____________________________________________ 15) Holley (Red,Blue) electric fuel pump/regulator service kit. Most parts still there, more pics available.) - $40.0016) Holley used accellerator pump squirters - Standard - $5.00 ea. - w/nozzles - $10.00 ea. Phillips screws - $1.00 ea.All prices + shipping from Florida 32117 Sorry, No PayPal. Money orders preferred. locomo@bellsouth.net
[Re: Locomotion]
#3310460
06/08/25 11:44 PM
06/08/25 11:44 PM
Posts: 586 Boise Idaho
65coronet500
Boise Idaho
I have a Milodon # 13250 Big block gear drive for sale All gears seem to be in really good shape top gear has the cam thrust button I have made roughly 30 1/4 mile passes and very minimal street driving (maybe 300 miles ) Haven’t ran it in quite awhile and decided I probably won’t use it so I figured I would sell it to someone that will $ 550 or make offer Thanks Matt Pm me here please I will get back to you .
All steel 3800 lbs with me in it 65 Coronet 451 CID Indy 440-1 heads by Dwayne Porter racing heads . ..... 10.31 @ 129.4 mph 1.40 60 ft ALL MOTOR!!!!
Re: For Sale - New Proform 67257 750 Double Pumper
[Re: moparts]
#3310519
06/09/25 11:56 AM
06/09/25 11:56 AM
Posts: 22 Baton Rouge, La
NP2
Baton Rouge, La
Proform 67257 750 double pumper with electric choke, never out of the box. Located in Baton Rouge, La. Payment via USPS money order. $485 plus shipping. https://www.summitracing.com/parts/...7KABnvRrCbyh6rFZAKnVdHr6ZI0OMcO#overviewProform Aluminum Street Series Carburetors Hand-assembled in the USA, Street Series carburetors from Proform are constructed from 100 percent lightweight aluminum, including interchangeable idle air bleeds, for easy, non-permanent calibration changes. Yes, fine-tuning is done by simply changing air bleeds, so you can leave your drills in your toolbox. Developed for today's high performance engines, these carburetors feature metering blocks with street performance calibration and lightweight, die-cast aluminum bowls with fuel level windows for quick visual reference. Changeable idle feed restrictions expand the idle adjustment capabilities, and 4-corner idle on mechanical secondary models lets you fine-tune the idle for more aggressive cam profiles. Also available with a vacuum secondary, Proform Street Series aluminum carburetors offer easy high performance at a price that you can afford
Cool Shirt Medium Vest
[Re: DusterDog]
#3310611
06/09/25 05:02 PM
06/09/25 05:02 PM
Posts: 283 Indiana
dragracer1
Indiana
Hey moparts fanatics! I gotta sell my Cool Shirt Vest for their motorsports system. Size: Medium Condition: Brand new, never had water ran through it. I haven’t raced in 5 years and have gained some poundage  since I bought this vest. They no longer produce these vests so this is the chance to get one of the few out there. $60.00….INCLUDES SHIPPING IN THE LOWER 48PM me if interested.
(NEW) Aeromotive A1000 Fuel Pump
[Re: John Burdine]
#3311908
06/18/25 03:02 PM
06/18/25 03:02 PM
Posts: 6,437 Heaven
EvilB1Dart
Heaven
Aeromotive A1000 Electric Fuel Pump. Box opened to take photos only. Brand new never mounted. Part Number 11101. https://www.jegs.com/i/Aeromotive/027/11101/10002/-1$400 shipped. PayPal, Zelle, US Postal Money Order, Check Send a PM if interested. Thanks Moparts!
"If you can still hear your fears - shift a gear."
PPP Shifter
[Re: EvilB1Dart]
#3312523
06/22/25 04:14 PM
06/22/25 04:14 PM
Posts: 17,937 Akron, Ohio
ProSport
Akron, Ohio
Black Precision Performance Products AIR shifter, reverse manual 727 with clean neutral, can be used with or without air. Like brand new, car was never driven, switched to a regular street strip valve body with matching PPP shifter so I no longer need this one. Comes with everything pictured, and it comes with the small pin that attaches the cable to the shifter. $575 o.b.o. These are over $900 new. Will ship for an extra $20 Call/Text 330-631-FiveFourSevenNine
