Page 3 of 3 1 2 3
(11) Small block lifters Part# 4049338 [Re: CompWedgeEngines] #3304327
05/05/25 01:24 PM
05/05/25 01:24 PM
BRIDGEWATER, CT.
WINGNUT Offline
WINGNUT  Offline
BRIDGEWATER, CT.
I am told these may be for a Magnum engine? All are new from 8/90. Still sealed in original bags. VERY slight bit of surface rust or discoloration on some of them Will clean up with WD-40 and a fine Scotchbrite pad. $100 for all 11 including postage. No Paypal, U.S. money order only. VEIGHTPETE@GMAIL.COM
Re: 1970 340 Main Cap Bolts [Re: VCODE] #3304473
05/06/25 08:54 AM
05/06/25 08:54 AM
PA
P
plumcrazycuda Offline
P
PA
Looking for a 340 90 degree oil filter adapter. Let me know if you have one. 🙏
NOS 1970-74 Small Block PS Belt w/AC - Part 2951 [Re: WINGNUT] #3304537
05/06/25 02:06 PM
05/06/25 02:06 PM
MD
floyd Offline
floyd  Offline
MD
NOS Mopar power steering pump belt, part number 2951898. Correct for multiple 1970-74 318/340 A/B/C/E-Bodies with air conditioning. $40 plus shipping from MD.
Thanks for the ad!
Re: For Sale/ Wanted - Small Block Engine - 2nd Quarter [Re: moparts] #3306310
05/16/25 11:26 AM
05/16/25 11:26 AM
USA
rftroy Offline
rftroy  Offline
USA
Wanted: 360 LA crank near Los Angeles.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 500 6 pack, Passon 5-speed, 3.55, B7 Blue
1973 Thermo Quad 6339S for a 340 manual Carb [Re: moparts] #3306670
05/18/25 09:44 AM
05/18/25 09:44 AM
blewbyu Offline
blewbyu  Offline
This is a very nice super clean original 73 340 Thermo quad. It is correct by the part number for a manual transmission. It still has all the factory markings as seen in the one pic on the side. It is also correct for California built car only. Price is $350 plus shipping from Florida. blewbyu2bad@aol.com
73 carb.jpeg (754 downloads)
73 carb1.jpeg (755 downloads)
73 carb2.jpeg (757 downloads)
73 carb 3.jpeg (753 downloads)
1972 340 – Manual Trans Carburetor - Carter TQ 6938SA [Re: blewbyu] #3307773
05/24/25 11:39 AM
05/24/25 11:39 AM
MD
floyd Offline
floyd  Offline
MD
Correct for 1972 340 w/4-spd, 0584 Date (replacement). It's a remanufactured carb in decent shape but I would consider it a core only. All parts move freely. Additional pics on request. $125 plus shipping from MD or pick up at Carlisle or the Nats. Thanks for the ad!
SOLD
1972 340 – Automatic Trans Carburetor - Carter TQ 6939S [Re: floyd] #3307777
05/24/25 11:58 AM
05/24/25 11:58 AM
MD
floyd Offline
floyd  Offline
MD
Correct for 1972 340 w/727, 2671 Date. Appears to be an unmolested original carburetor. All parts move freely. Excellent core but will require rebuild/restoration. Additional pics on request. $225 plus shipping from MD or pick up at Carlisle or the Nats. Thanks for the ad!
SOLD
NOS Mopar 318/340/360 Timing Chain Cover [Re: 11secdart] #3308681
05/29/25 05:34 PM
05/29/25 05:34 PM
MD
floyd Offline
floyd  Offline
MD
NOS aluminum timing chain cover in excellent unused condition, Part/Casting Number 3769964/3769966. Fits 1970-later LA small block engines. Additional pics on request. $150 plus shipping from MD or pick up at Carlisle or the Nats. Thanks for the ad!
SOLD
Re: For Sale/ Wanted - Small Block Engine - 2nd Quarter [Re: moparts] #3310164
06/06/25 11:18 PM
06/06/25 11:18 PM
Locomotion Offline
Locomotion  Offline
FOR SALE - MOPAR SMALL BLOCK rebuild parts - odds & ends - bearings, rings, gaskets, etc.
1) Victor Reinz 3536 SG - Head gaskets .040" - $50.00 for 3 head gaskets
2) Cloyes 9-135 Std. replacement True Roller timing chain only - (3 available) - $45.00 ea.
3) Cloyes 9-135-5 (.005 short) replacement True Roller timing chain only - (2 available) - $45.00 ea.
4) Cloyes True Roller 9-3103-5 (.005 short) Timing Chain Set – $65.00/set
** Can be alternative to chain tensioner after line boring.
5) Ross 984-01-25 Wrist Pins, Type 1, .984 in. Diameter, 2.500 in. Length, .150 in. Wall, 125 Grams - $80.00/set of 8
6) Hastings 2M 5505 035 – 4.035 1/16 file fit, low tension oil rings - $50.00 set
7) Childs & Albert RS-10477 – 25 4.025 5/64 file fit, low tension oil rings - $70.00 set
8) Childs & Albert RS-10477 – 45 4.045 5/64 file fit, low tension oil rings - $70.00 set
9) Eagle 12055 3/8" SIR replacement rod bolts (SBM, also fits several Chevy, Ford, 3/8" SIR rods) - (2 available) - $90.00 set
10) JE Pistons 32-990-.042-CT Spirolox (Jeg's has the correct photo) - $50.00 set of 32
11) Clevite - MS1051P 10 – 360 Main Bearings (½ groove) - $65.00/set
12) Sealed Power/Federal Mogul 8-2130CP .030 rod bearings - $40.00/set of 8
13) Clevite CB481 HN - std. rod bearings - $60.00 set of 8 (SOLD)
14) Mopar Performance P4349022 Clevite .001" .U.S rod bearings - $40.00 set of 8 (SOLD)
15) Summit G2418 318/340/360 intake gaskets - $15.00 (2 available) (SOLD)
16) Mr. Gasket 5949 Ultra seal Exhaust gaskets for 1992 318 Magnum style heads - $20.00
17) Mr. Gasket 5935 Ultra seal Exhaust gaskets for LA heads - $20.00
18) TTI GA-HG-340 Exhaust gaskets for LA heads - $15.00
Prices + shipping from Florida 32117
locomo@bellsouth.net
Sorry, no PayPal
Money orders preferred.
For sale - Comp Cams SB LA Ultra Pro-magnum Rockers 1622-16 [Re: moparts] #3310501
06/09/25 11:07 AM
06/09/25 11:07 AM
Baton Rouge, La
N
NP2 Offline
NP2  Offline
N
Baton Rouge, La
Comp Cams SB LA Ultra Pro-magnum Rockers 1622-16, new in box. Located in Baton Rouge, La. Payment via USPS money order. $730 plus shipping.
Re: For Sale - Edelbrock 7176 SB LA Performer RPM non-air ga [Re: moparts] #3310511
06/09/25 11:29 AM
06/09/25 11:29 AM
Baton Rouge, La
N
NP2 Offline
NP2  Offline
N
Baton Rouge, La
Edelbrock 7176 SB LA Performer RPM non-air gap intake manifold, new. Located in Baton Rouge, La. Payment via USPS money order. $370 plus shipping.
Re: For Sale - Mopar P5249558, LA water pump, high volume 6- [Re: moparts] #3310512
06/09/25 11:32 AM
06/09/25 11:32 AM
Baton Rouge, La
N
NP2 Offline
NP2  Offline
N
Baton Rouge, La
Mopar P5249558, LA water pump, high volume 6-blade. New in box. Located in Baton Rouge, La. Payment via USPS money order. $70 plus shipping.
Re: For Sale - Mopar replacement LA timing chain cover [Re: moparts] #3310514
06/09/25 11:36 AM
06/09/25 11:36 AM
Baton Rouge, La
N
NP2 Offline
NP2  Offline
N
Baton Rouge, La
Mopar P5249930 replacement timing chain cover, new in box. Located in Baton Rouge, La. Payment via USPS money order. $80 plus shipping.
Re: For Sale - Mopar LA Fuel Pump Eccentric [Re: moparts] #3310516
06/09/25 11:44 AM
06/09/25 11:44 AM
Baton Rouge, La
N
NP2 Offline
NP2  Offline
N
Baton Rouge, La
Mopar P4120484 moly coated fuel pump eccentric, new in box. Located in Baton Rouge, La. Payment via USPS money order. $50 plus shipping.
Re: For Sale - Mopar P4529838 LA cam bolt and washer [Re: moparts] #3310517
06/09/25 11:47 AM
06/09/25 11:47 AM
Baton Rouge, La
N
NP2 Offline
NP2  Offline
N
Baton Rouge, La
Mopar P4529838 LA cam bolt and washer, new. Located in Baton Rouge, La. Payment via USPS money order. $25 plus shipping.
Re: For Sale - Mopar P4876056 crank pilot bearing [Re: moparts] #3310518
06/09/25 11:50 AM
06/09/25 11:50 AM
Baton Rouge, La
N
NP2 Offline
NP2  Offline
N
Baton Rouge, La
Mopar P4876056 crank pilot bearing. New. Located in Baton Rouge, La. Payment via USPS money order. $20 plus shipping.
340 six pack [Re: moparts] #3311476
06/15/25 01:31 PM
06/15/25 01:31 PM
Wisconsin
71duster414 Offline
71duster414  Offline
Wisconsin
Front 4789 date 0840. Rear 4790 date 0890. Center 4782 date 2460.
Intake is in excellent condition
$3000 plus Shipping for everything
Located in Wisconsin
hoffmanhhr@gmail.com
Re: For Sale/ Wanted - Small Block Engine - 2nd Quarter [Re: moparts] #3311752
06/17/25 10:43 AM
06/17/25 10:43 AM
ct.
moparlouie Offline
moparlouie  Offline
ct.
OEM 1971 318 small block manifold and heat shield. Manifold $100, shield $65 plus shipping. Manifold studs intact, and shield is near mint. lafrancebiglou@aol.com
Have been a member for years!
Re: For Sale/ Wanted - Small Block Engine - 2nd Quarter [Re: moparts] #3312032
06/19/25 02:51 PM
06/19/25 02:51 PM
ct.
moparlouie Offline
moparlouie  Offline
ct.
3 sets of 273 Heads, 2 sets of 64-65 heads, and one set of 66-67 heads. Complete sold as cores. $250 set. NO shipping, in Connecticut. lafrancebiglou@aol.com
Page 3 of 3 1 2 3
