Re: Passenger mirror factory location 70 GTX
[Re: crash520]
#3306519
05/17/25 11:49 AM
05/17/25 11:49 AM
Posts: 27,937 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
Try the same position on the passenger door i.e. same dimension from the front door edge and the window.
[Re: crash520]
#3306571
05/17/25 02:59 PM
05/17/25 02:59 PM
Posts: 5,536 So Cal
Sinitro
So Cal
On a 70 Body mounting a mirror on the passenger door matching the driver's factory side position results in a very poor viewing angle for the driver. So one has (2) choices, either mount the mirror to match the driver's for best visual appearance or modify/mount it in a different, slightly more rearward position. Just my $0.02...
[Re: Sinitro]
#3306638
05/18/25 03:18 AM
05/18/25 03:18 AM
Posts: 6,892 Abilene, Texas
fastmark
Abilene, Texas
On a 70 Body mounting a mirror on the passenger door matching the driver's factory side position results in a very poor viewing angle for the driver. So one has (2) choices, either mount the mirror to match the driver's for best visual appearance or modify/mount it in a different, slightly more rearward position. Just my $0.02... The right mirror on my 70 Charger is practically worthless for viewing. I think farther back may be worse. I have to lean back to even get any image. It’s the vent wing post in the way for me and just a bad angle. After driving a modern car or truck with good mirrors, we get spoiled.
[Re: Sinitro]
#3306735
05/18/25 02:55 PM
05/18/25 02:55 PM
John_Kunkel
Rio Linda, CA
On a 70 Body mounting a mirror on the passenger door matching the driver's factory side position results in a very poor viewing angle for the driver. So one has (2) choices, either mount the mirror to match the driver's for best visual appearance or modify/mount it in a different, slightly more rearward position. Just my $0.02... On my '68 RR I added a passenger mirror positioned exactly like the drivers side and had a good view from it...should be the same as a '70 GTX.The view depends a lot on the seat position, I usually have the seat all the way back.
[Re: John_Kunkel]
#3306798
05/18/25 08:01 PM
05/18/25 08:01 PM
Posts: 5,536 So Cal
Sinitro
So Cal
On a 70 Body mounting a mirror on the passenger door matching the driver's factory side position results in a very poor viewing angle for the driver. So one has (2) choices, either mount the mirror to match the driver's for best visual appearance or modify/mount it in a different, slightly more rearward position. Just my $0.02... On my '68 RR I added a passenger mirror positioned exactly like the drivers side and had a good view from it...should be the same as a '70 GTX.The view depends a lot on the seat position, I usually have the seat all the way back. Was your driver's side mirror remote control? On my 70 RR the driver's mirror was OE and remote control... I mounted the fixed passenger side mirror in the same position and it is useless for viewing this is with the bench seat all the way back.. But is balanced mounted identically compared to the driver's side.. Just my $0.02...
[Re: topside]
#3306838
05/19/25 12:08 AM
05/19/25 12:08 AM
Posts: 10,648 Someplace you aren't
SomeCarGuy
I bought one to match the remote driver side from Tony d and he said to just lay it out like the driver side to have it like the factory did it. I have yet to get around to it, so I can’t say how that would do. I had a 68 charger about 25 years ago and I don’t recall the pass mirror being useless. I have to have my seat all the way back fwiw
I want my fair share
[Re: Sinitro]
#3306903
05/19/25 12:49 PM
05/19/25 12:49 PM
John_Kunkel
Rio Linda, CA
Well, like all external mirrors of that era, I wouldn't say "useless"...more like "limited".
[Re: John_Kunkel]
#3308063
05/26/25 01:25 PM
05/26/25 01:25 PM
Posts: 5,536 So Cal
Sinitro
So Cal
Well, like all external mirrors of that era, I wouldn't say "useless"...more like "limited". Actually one has options when installing a right-side mirror... 1. Mount the mirror in the same position as the driver-side remote OE mirror 2. Mount the mirror in a better viewing position but then typically there will be a mismatch compared to the position of the remote OE mirrorJust my $0.02...
