Page 7 of 7 1 2 3 4 5 6 7
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3305715
05/12/25 05:06 PM
05/12/25 05:06 PM
west palm beach, florida
modelmakerinc Offline OP
We had anticipated there were issues with the cowling, we took a wait see what the stripping finds to choose our direction. I wonder how many would suggest to repair or replace the upper cowl panel. It is a repop part welded on top of the old in places, behind the old in places and generally installed like and ass monkey on crack. pass side
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3305716
05/12/25 05:08 PM
05/12/25 05:08 PM
driver side.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3308186
05/27/25 09:08 AM
05/27/25 09:08 AM
Out with the nasty scabbed in part. The window channel was original to the car the replacement cowl was cut and lap welded in the window channel. I had to grind through, two sets of welds , the OG spot welds and the rosette welds the asshats did. It was an aftermarket part but installed very poorly, plenty of bondo covering the [censored] welds. Once it was off i cleaned everything up did a few repairs and alot of prep to install a new AMD upper cowl.
The gray is 3 coats of POR15 to create a complete continuous seal. The bottom side of the upper cowl was scuffed and shot with enamel paint. Test fit pic, shows the brackets removed and the inner fender hinge mount bracket missing the upper tab that spots to the top of the cowl. I began the install by spot welding the windshield channel. The spot welder weighs >40 lbs and is near impossible to hold, maneuver and weld correctly so a couple ratchet straps were my make shift perfect solution.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3308187
05/27/25 09:12 AM
05/27/25 09:12 AM
install done all welded up. I will be doing some filler work to clean up some areas, more important was to get in into epoxy & 2K before going back to work.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3308188
05/27/25 09:16 AM
05/27/25 09:16 AM
Sanded everything with80 on a DA and orbital plus use of a drill motor wire brushes in the nooks and crannies. Primed with PPG DP40 Epoxy
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3308189
05/27/25 09:21 AM
05/27/25 09:21 AM
After a few hours of cure time, It is in 3 med wet coats of 2K. this will be the base for minimal filler to be sanded to 400 for sealer and color when the time comes.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3308190
05/27/25 09:23 AM
05/27/25 09:23 AM
3 more pics
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3308368
05/27/25 10:29 PM
05/27/25 10:29 PM
Phila
P
PhillyRag Online content
PhillyRag  Online Content
P
Phila
That's one beautiful job on the firewall/cowl section. Not many people would tackle such an area.
But you did the work that this area always is needed on most e-bodies.
Great to see the progress.
Re: 71 Cuda Paint Job Project [Re: PhillyRag] #3308386
05/28/25 06:14 AM
05/28/25 06:14 AM
Thank you, trying to do as much as we can and still keep a budget in mind. We are considerate of choosing where to spend the funds. labor, parts, or combination of the two for smartest use and what the car really needs for a solid long lasting build that will add to its value.
This car is definitely not being restored as an investment or to sale, but reality is eventually it will have a number.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3308704
05/29/25 08:35 PM
05/29/25 08:35 PM
Phila
P
P
Phila
For all piratical purposes it certainly will be 100% better then anything that rolled off the assembly line.
Re: 71 Cuda Paint Job Project [Re: PhillyRag] #3309259
06/02/25 07:28 AM
06/02/25 07:28 AM
Was able to find a 72-74 Barracuda fender to use as a donor for the core support to headlamp bucket area. There were issues with a couple of the weldnuts so those needed to be replaced and the leading edge was severely beat and broken. there was a bit of work with this fender but I still think we are better off than using a repop fender.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3309260
06/02/25 07:31 AM
06/02/25 07:31 AM
here is the donor and the patient smile and end result you can see the differences and modifications in the headlamp bucket area. The support bracket needed is the same for 70-74.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3309931
06/05/25 11:42 PM
06/05/25 11:42 PM
Phila
P
P
Phila
If that's a 240volt welder, will do lots of areas of a car. Various tongs are also useful. Yeap: they are a bi-otch to manuever, as I have a Tenca unit.
Re: 71 Cuda Paint Job Project [Re: PhillyRag] #3311079
06/12/25 03:22 PM
06/12/25 03:22 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Fender patches...cowl...heck, all of your work looks very nice.
Teenaged me would have been OK with that previous cowl repair! laugh2
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 71 Cuda Paint Job Project [Re: DynoDave] #3311568
06/16/25 08:20 AM
06/16/25 08:20 AM
Installed the front clip to get alignment and all the parts to work with each other. The fenders of these projects get stored, stuff laying on them them, laying on other things, generally getting moved from place to place, bent twisted tweaked and then you weld patches on them they move even more. I set passenger side door gap, had to adjust the AMD valance, the attaching brackets were off by a good amount and moved the center one altogether.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3311569
06/16/25 08:25 AM
06/16/25 08:25 AM
B4 and after. i removed the center bracket to get the valance in position, then placed it where it was originally welded. second pic shows it corrected.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3311571
06/16/25 08:29 AM
06/16/25 08:29 AM
I installed the driver fender before welding the dog leg patch in place to assure proper fitment so there isn't a wrestling match when I re-install it when it is time for paint. Straight edge showing panel alignment and I will add material to the doors leading edge for a better, more consistent gap.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3311572
06/16/25 08:36 AM
06/16/25 08:36 AM
Measured hood opening, and cross measured square in three different positions. The factory rally hood is +/- 3/8" to 1/2" narrower than the measured opening so the AMD Shaker should fit without issue. The Cuda has an advantage that the header panel dictates the opening so at this moment I did not have to install the hood. grin
