Need Edumication on the various Hemi Crate engine ECU's #3307253
05/21/25 10:10 AM
05/21/25 10:10 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
As I shop around on-line for G3 stuff, some crate engines popped up.
So I know a little bit about the Hellcrate engine. Its a great price for the HP, and it comes with a lot of factory parts, but it needs to run a factory type ECU and harness due to the dual throttle bodies in it. Do the Redeye Hellcrates also need to have the OEM ECU as well?
Re: Need Edumication on the various Hemi Crate engine ECU's [Re: Dragula] #3307382
05/21/25 08:50 PM
05/21/25 08:50 PM
Andrewh Offline
Andrewh  Offline
I don't know if they need to.
I think holley has stuff that will run it,
but clearly they were made to, as you can pick up the ecu kit from mopar.
if you buy both the crate motor and ecu from them you get a 3 year 36 warranty. but you have to show they were both purchased at the same time.
