fuel sending unit #3304405
05/05/25 08:20 PM
05/05/25 08:20 PM
alabama, usa
burks340 Offline OP
burks340  Offline OP
alabama, usa
i removed my fuel sending unit from my 71 dart and when the gauge reads 1/2 tank the float is on empty is there anyway i can adjust it to read correctly its a repop.it has been in the tank 2 or 3 years and just got around to getting a signal back at the unit.
Re: fuel sending unit [Re: burks340] #3304409
05/05/25 08:54 PM
05/05/25 08:54 PM
New York, United States
fredyn777 Offline
fredyn777  Offline
Was it always reading off like that or did it change after sitting for those couple years? Sometimes the float can stick or get saturated if it’s been sitting in fuel too long
Re: fuel sending unit [Re: burks340] #3304430
05/05/25 09:46 PM
05/05/25 09:46 PM
Use a good ohmmeter and set the float arm up so it reads like the factory service manuals call for, I can't remember if it should read max ohms at the top of the travel or on the bottom level confused.
I'm thinking it should read from 30 to 90 ohms from empty to full but I'm not sure which reading should be empty and which one should be full whiney
Re: fuel sending unit [Re: Cab_Burge] #3304431
05/05/25 09:48 PM
05/05/25 09:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have yet to find a aftermarket repro sender to read accurately .
Time just gets away from us
I`m here until I`m not
Re: fuel sending unit [Re: fredyn777] #3304435
05/05/25 10:08 PM
05/05/25 10:08 PM
alabama, usa
burks340 Offline OP
burks340  Offline OP
alabama, usa
i had no fuel in it i just got the engine in a year ago it had no engine or tranny when i bought it i jus got the fuel gauge working and it ran out of gas on my carport and the gauge read 1/2 tank so i took sending unit out and wired it up so i could see what he gauge read when the float was at lowest point and gauge read 1/2 on fuel gauge.
Re: fuel sending unit [Re: mopars4ever] #3304436
05/05/25 10:19 PM
05/05/25 10:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up use the search function and you'll find it's an all to common issue whistling beer
Re: fuel sending unit [Re: burks340] #3304665
05/07/25 12:25 AM
05/07/25 12:25 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Just watched a really informative video about this today on BoobTube. I'm also in this boat with my '71 Charger - it's got a brand new sending unit & it's all over the place.
https://youtu.be/cPjEH8_Bdlc
Re: fuel sending unit [Re: mopars4ever] #3304710
05/07/25 09:46 AM
05/07/25 09:46 AM
Arizona
jsully Offline
jsully  Offline
Arizona
Ditto
Re: fuel sending unit [Re: Sunroofcuda] #3304761
05/07/25 12:42 PM
05/07/25 12:42 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
unless the sending unit is NOS, that is a common problem with all of the reproductions on the market today.
beer
Re: fuel sending unit [Re: moparx] #3304808
05/07/25 04:41 PM
05/07/25 04:41 PM
alabama, usa
burks340 Offline OP
burks340  Offline OP
alabama, usa
please dont tell me that i just ordered a new 1 from summit cost over $100.00 but i gonna check it to my gauge in car before i install i in tank if its not accurate its going back to summit and i dont know what i gonna do then . any suggestions?
Re: fuel sending unit [Re: burks340] #3304821
05/07/25 05:08 PM
05/07/25 05:08 PM
Canada
E
EW1BH27 Online content
EW1BH27  Online Content
E
Canada
What's wrong with your original one?
Re: fuel sending unit [Re: EW1BH27] #3304844
05/07/25 07:51 PM
05/07/25 07:51 PM
alabama, usa
burks340 Offline OP
burks340  Offline OP
alabama, usa
i dont have the original unit when i bought a new tank i just bought a new sending unit. i should get the summit unit friday or monday.
Re: fuel sending unit [Re: burks340] #3304958
05/08/25 11:59 AM
05/08/25 11:59 AM
md
mopars4ever Offline
mopars4ever  Offline
md
My guess i the summit one won`t be any better. My 73 Charger aftermarket gauge seemed to work ok out of the tank but it was way off after I installed it. I just tried to keep my tank on the full side and filled up often.
Re: fuel sending unit [Re: mopars4ever] #3305156
05/09/25 02:53 PM
05/09/25 02:53 PM
alabama, usa
burks340 Offline OP
burks340  Offline OP
alabama, usa
well i just recieved my sending unit from summit yesterday the 1 they sell thats made in taiwan and its identical to the 1 i pulled out of my tank i will test it 2day and see what my gauge reads.
Re: fuel sending unit [Re: burks340] #3305158
05/09/25 03:41 PM
05/09/25 03:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't know that fuel gauges have ever been dead-on accurate, and my newer cars exhibit similar readings:
Starting with a full tank, the reading moves very slowly from full to 7/8, then drops at an increasing rate without a change in driving habits/routes.
As a result, for years now I just add fuel when I see 1/4 tank.
Re: fuel sending unit [Re: topside] #3305176
05/09/25 06:57 PM
05/09/25 06:57 PM
alabama, usa
burks340 Offline OP
burks340  Offline OP
alabama, usa
i run atest on my new sending unit and it reads just under 1/2 tank with the float at its lowest point so gonna be sending it back . they offer 2 other units 1 is imported from republic of china and the other from mexico they are out of these he stated they would be getting some in the end of the month i may try the mexican unit.
Re: fuel sending unit [Re: burks340] #3305185
05/09/25 10:01 PM
05/09/25 10:01 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Good Luck and keep us posted up
FYI: In my extensive experience with different suppliers, makes and models, what they do in the tank with fuel can be completely different than without fuel or on the bench whistling twocents beer
Re: fuel sending unit [Re: burks340] #3305207
05/10/25 06:31 AM
05/10/25 06:31 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Have you tested the ohm readings on either sender?
Have you tested the gauge function?
Changing a part multiple times with the same results indicates the problem may be elsewhere.
Angry white pureblood male
Re: fuel sending unit [Re: ruderunner] #3305210
05/10/25 07:20 AM
05/10/25 07:20 AM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
I was considering trying out meter match from tanks inc. any feedback?https://www.youtube.com/watch?v=xCQhoJw6MhA
Re: fuel sending unit [Re: stinger] #3305229
05/10/25 09:22 AM
05/10/25 09:22 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
The point with things like that meter match thing is the factory didn't need them, neither should the aftermarket ones.
My son has had 4-5 aftermarket ones. Every damn one reads empty when you really have a 1/2 a tank.
I found him an NOS one to put in place of one of them and it reads almost perfect.
I mean it reads empty with like 1/8 tank but that's more like they should be
