2004 11.5 diff #3304689
05/07/25 08:00 AM
05/07/25 08:00 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
according to my service hand book in bold letters it says "DOES NOT REQUIRE ATISLIP ADDITIVE" WELL the oil i put in has anti slip additive in it.is it going to hurt anything to run it or should i change it out?
Re: 2004 11.5 diff [Re: bonefish] #3304762
05/07/25 12:48 PM
05/07/25 12:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Shouldn't hurt a thing.
Re: 2004 11.5 diff [Re: stumpy] #3304972
05/08/25 12:43 PM
05/08/25 12:43 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Thanks up
Re: 2004 11.5 diff [Re: bonefish] #3305166
05/09/25 04:47 PM
05/09/25 04:47 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
My handbook for my 2004 2500 says no need to change the oil in the 6 speed manual transmission. I bought mine new and it's never been abused or jerked around. It got to where it didn't want to go in gear at a stop....wasn't grinding like the clutch was bad, just very hard to get in gear. Also didn't like going into the next gear after getting it rolling. I found some You Tube videos about the problem and they said change the oil and it would fix it. Also said to remove the shifter and overfill it one quart from there instead of the fill plug on the side. I did all that and it went right back to shifting like butter again. I'm beginning to wonder if whoever wrote the handbook is realcrazy
Re: 2004 11.5 diff [Re: JDMopar] #3305240
05/10/25 10:17 AM
05/10/25 10:17 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
SRT-4 transmissions call for ATF-4, and it is hard on the fiber synchros. 10-30 motor oil is the best because it doesn't have friction modifier.
Rumor is the trans mfg was only using ATF-4 in their products, and was going to upcharge for the different oil fill..................
