Manual to Power Steering Swap ? #3301634
04/20/25 11:42 AM
04/20/25 11:42 AM
North Dakota
Azzkikrcuda Offline OP
North Dakota
I have a 1976 D100 2wd with manual steering I want to change to Power steering. Is the steering column length different like a car or do they use the same column for both Manual and Power?
The only Carbs I care about are under the hood!
Re: Manual to Power Steering Swap ? [Re: Azzkikrcuda] #3301772
04/20/25 10:02 PM
04/20/25 10:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Pretty sure the column length is ok. The rag joint is different as the spline size is different. I know I did the swap on a 75 w-100 and all that was different was the rag joint.
Re: Manual to Power Steering Swap ? [Re: NITROUSN] #3302176
04/23/25 08:28 AM
04/23/25 08:28 AM
North Dakota
North Dakota
Ok, thanks for the info.
