Altnator mounting to keith black hemi heads?
#3300726
04/14/25 04:54 PM
04/14/25 04:54 PM
Posts: 8,917 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Bought a big block mount but when tried to mock up...no luck What is needed here?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Altnator mounting to keith black hemi heads?
[Re: toplescuda]
#3300732
04/14/25 05:53 PM
04/14/25 05:53 PM
Posts: 10,486 A Red State
SNK-EYZ
A Red State
The cylinder head is missing the mounting boss where the bolt attaches.
It's the one next to the distributor cap in the attached pic.
You're going to have to do some fabricating to figure out how to mount the upper (long) bolt.
[Re: SNK-EYZ]
#3300735
04/14/25 06:23 PM
04/14/25 06:23 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Well that sucks maybe i can do a lower mount?
[Re: toplescuda]
#3300752
04/14/25 08:15 PM
04/14/25 08:15 PM
SNK-EYZ
A Red State
Well that sucks maybe i can do a lower mount? Well, you could have someone weld on a boss inn the proper location, the heads do look to be aluminum. If they are, someone should be able to easily TIG weld a boss on there.. Other than that, it'll take fabricating something to work. As already suggested, check the other head at the rear for a boss.
[Re: SNK-EYZ]
#3300792
04/15/25 02:47 AM
04/15/25 02:47 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
The heads are nos heads from back in the day. They have never even had valves installed into them So there has been no grinding/cutting done to any part of them Most likely will try to find a good low mount setup
[Re: toplescuda]
#3300796
04/15/25 04:52 AM
04/15/25 04:52 AM
SNK-EYZ
A Red State
I never said that they were modified in any way, obviously they're not Mopar heads but probably Keith Black heads.
They are aluminum correct?
Unless you're worried about welding a boss on (what I would do), there are options.
As asked, is the boss there on the back of the other head?
It wouldn't be hard to fab up a bracket that would use that lower flat boss on the head and also use the stud mount by the core plug/freeze plug.
You could use the factory alternator brackets that way.
[Re: SNK-EYZ]
#3300859
04/15/25 07:41 AM
04/15/25 07:41 AM
Posts: 5,063 new berlin wisconsin
Mr T2U
when i built my hemi for my 72 roadrunner. i used stage 5 hemi heads. these heads don't have alternator bracket bosses either. there was a bracket that bolted to the alternator ears that completely supported the alternator. i don't know where it came from. i was on my motor when i got it. i took pic, not the best, of the magazine article from Mopar Muscle September 2006. you can easily see the bracket in the pic.
perception is 90% of reality
[Re: SNK-EYZ]
#3300904
04/15/25 12:27 PM
04/15/25 12:27 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
As said in the orignal. They are keith black heads so yeah there aluminum both heads are exactly alike
[Re: toplescuda]
#3300934
04/15/25 02:01 PM
04/15/25 02:01 PM
Posts: 13,731 Marion, South Carolina [><]
an8sec70cuda
You could use the DMI (Doty Manufacturing) low mount alternator bracket. Bracket mounts with the bottom two timing cover bolts, but it doesn't use a stock style alternator.
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
[Re: rickseeman]
#3301527
04/19/25 02:11 PM
04/19/25 02:11 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
There are various low mount kits. This is a Doty. Thats bad ass. But a normal alt won't work with that mount setup?
[Re: toplescuda]
#3301528
04/19/25 02:14 PM
04/19/25 02:14 PM
Posts: 2,929 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
It might. But I don't think you are going for the "stock" look. There are many types/kinds/styles of low mount alternators as well as roll-your-own.
2011 Drag Pak Challenger
[Re: rickseeman]
#3301530
04/19/25 02:31 PM
04/19/25 02:31 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
No at end of the day it would have A blown 572 in it
