Page 2 of 3 1 2 3
Re: For Sale - Race Parts - 2nd Quarter [Re: racerx] #3300026
04/10/25 01:39 PM
04/10/25 01:39 PM
Missouri
galen Offline
galen  Offline
Missouri
New in box Jesel belt drive big block. KBD-38400. This is the drive with the solid black upper pulley.. 750$ plus shipping. Sale Pending. Isky 9385 springs new in box 150$ plus shipping. Comp 7245-16 dual conical springs. 4669-16 locators for .570 guide. 1738-16 tool steel retainers. New never installed. 450$ plus shipping. Also have new springs, locators and titanium retainers that came on new trick flow 270s set up for mechanical solid roller. Not sure what brand trick flow uses. 400$ plus shipping. i If interested PM me and I will give you my phone number. I can also send pics off of my phone.
Cat [Re: moparts] #3300498
04/13/25 11:46 AM
04/13/25 11:46 AM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
Moroso Breather Tank, catch can part # 85465, 1 qt., Round, Aluminum, Natural, Filtered Breather, Mounting Bracket, Petcock. New Never Used. $75 rich1981@optonline.net
catch can 2.jpg (847 downloads)
catch can.jpg (848 downloads)
Re:Small Block Billet Crankshafts [Re: moparts] #3300504
04/13/25 12:02 PM
04/13/25 12:02 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
Winberg Billet Crankshaft 3.500 stroke, 340 mains and 283 Chevy 2" rods. All standard size. $2,500
Winberg Billet Crankshaft 3.450 stroke, 340 mains and 283 Chevy 2"rods. All standard. $2,500
Bryant Billet Crankshaft 3.250 stroke, Ford mains and Honda rods. All standard. $1,500
Holley Carb Parts [Re: moparts] #3300784
04/14/25 11:52 PM
04/14/25 11:52 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
NEW Holley 20-11 50cc accelerator pump kit. New pump cover, spring, screws and diaphragm, pump arm, 2 pump cams. Original packaging damaged. $70 at Summit.
Sell for $35 + shipping.
Have several new take-off manual choke kits for Holley double pump or 2300 carbs. Some include choke plate, choke shaft-5/16"(big shaft) and choke rod which do not come in Holley 45-225 choke kit. Have some shiny and some in classic gold. $20 each + shipping.
NEW Holley 1:1 Linkage kit for double pump carbs. Includes primary & secondary throttle shafts. *****SOLD*******
New Barry Grant 4500 Dominator booster retaining sleeves (for replacing boosters) $10 + shipping from 56007.
Private message
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
JFZ Disc Brake Calipers [Re: moparts] #3300786
04/15/25 12:25 AM
04/15/25 12:25 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
JFZ race 4 piston, disc brake calipers: All have been disassembled, cleaned and new seals installed. All have (4) 1.75" coated pistons and 5.25" bolt spacing(same as Wilwood). (1) pair is for .810" thick rotors and (1) pair is for thin .380" rotors. I put all new calipers on and carried these for spares, but no longer need them. Sell for $100 per pair + shipping.
PM or call 5zero7-373-59zero7 days.
1974 VW Karman-Ghia
Re: For Sale - Race Parts - 2nd Quarter [Re: GTX5877] #3300968
04/15/25 05:10 PM
04/15/25 05:10 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
- 440/500" Short Block. Diamond flat tops, BME Rods, Ohio 4.15" Crank. 440 Source alum caps, Chenoweth girdle, Rollmaster billet chain set, ARP hardware. No more than 25 passes since it was built. Was meant to go in a street car. $5000
- Winters 727 Shifter, reverse pattern with cable. Nice, was taken apart and painted/detailed. $200
- Richmond 8 3/4 489 5.38 pro gear. Used - $100
- Dana 60 4.56 Richmond Pro Gears - Used - $100/each (have two)
- Set of 8 TRW 426 Max Wedge 11:1 Pistons - New, some wear and tear from sitting. - $250
- 426 Hemi DLI Style Rockers - NEW - unfinished/partially machined. Need the adjuster holes drilled and rollers put in. 9 intakes and 6 exhausts. $750
- Brand New MP Crossram for 426 Hemi - $1500
- RB M-1 Intake - 4500 Flange - $350
- Indy 440 Single Plane - 4150 Flange - $450
- SB 727 Core - $150
- A-body narrowed factory gas tank for in between inboard leafs - $100
- 1.98 Powerglide low gear set - not straight cut - used - $300
- 440/452 rotating assembly. (+.055) Venolia flat tops, BME Rods, polished/lightened factory steel crank. Standard mains/rods, .990 Pins. Used. $1250
All items located in PA, zip 16101.
Re: For Sale - Race Parts - 2nd Quarter [Re: moparts] #3301032
04/16/25 10:34 AM
04/16/25 10:34 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I have a Proform/Quickfuel 1050AN carb for sale. I just removed it from my engine, so very little tuning is necessary. Bolt it on and run. Looking for $600 plus shipping.
I also have an Edlelbrock Torker TM7 RB single plane intake. Looking for $250, OBO.
I have a used set of OE 440 connecting rods. Very good shape $100
I have an adjustable Dana pinion snubber. $25
I also have a 1970 and newer B Body NP A833 23 spline 4 speed transmission $500. I will not ship this item.
143 tooth steel flywheel 8 bolt. Needs resurfaced. $100
All parts are plus shipping, unless special arrangements can be made.
Thanks.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Rocker Arm Shafts for Adjustable Rockers - New [Re: 68LAR] #3301646
04/20/25 12:18 PM
04/20/25 12:18 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a few new sets of small and big block block Mopar rocker arm shafts for stock and aftermarket cylinder heads that use a stock type mechanical rocker arm shaft. These shafts are made here in the U.S. from thick hardened steel. They feature banana groves and oiling holes that are positioned for the loading of mechanical rocker arms. These shafts have reusable press in end plugs for inspection and easy cleaning. End plugs are held in by the end hold down bolts. They are far thicker and stiffer than stock or many aftermarket shafts to minimize flex with stiffer aftermarket valve springs.
Pictures below are the small block shafts for illustration.
Price is $190 for the pair shipped within the lower 48 states.
I can ship internationally for the additional shipping cost.
Contact procketrichard@hotmail.com for more information and pictures.
Forged Mopar 360 & 5.9 Stroker Rotating Assembly - 408" [Re: Rocket] #3301752
04/20/25 08:51 PM
04/20/25 08:51 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new SCAT forged rotating assembly for 360 & 5.9 Magnum Mopar engines. All parts are new high-quality parts. Final cubic inches will be 408”.
The assembly includes the following parts.
• SCAT forged 4.000” crankshaft part # 4-360-4000-6123
• SCAT forged H-beam connecting rods with APR 2000 bolts part # 2-360-6123-2124A
• Diamond Forged flattop 4.030” bore pistons (0.030” oversize) part # 51026
• Trend wrist pins - 0.984” part # TPD-G9842750155
• Diamond wrist pin locks
• Mahle file fit ring set with Moly ductile iron top rings part # MAH4035MS
• Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH
• Clevite P-Series full groove main bearings part # MS-1266P
If you are looking for a 360 stroker with lower compression, I can substitute the pistons and connecting rods for new SRP 4.030” dished pistons part # 220156 (16.9 cc piston head volume) and new Eagle H-beam rods part # CRS6123C3D (360 stroker assembly only).
These rotating assemblies will need balancing.
The price for this complete kit with the Diamond flat top pistons and SCAT rods is $2,750 plus shipping cost.
The price for this complete kit with the SRP dished pistons and the Eagle H-beam rods is $2,600 plus shipping cost.
I also have a similar stroker assembly for a 340 with new Diamond 4.060” (0.020” overbore) flat top pistons, Perfect Circle file fit ring set with Moly ductile iron top rings part # 315-0036.065
and Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH. Displacement would be 414 ci. This rotating assembly will need balancing.
The price for the complete 340 kit is $2,750 plus shipping cost.
I can also meet in CT.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Forged Mopar 340 Stroker Rotating Assembly - 414" [Re: Rocket] #3301753
04/20/25 08:53 PM
04/20/25 08:53 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new SCAT forged rotating assembly for 340 Mopar engines. All parts are new high-quality parts. Final cubic inches will be 414”.
• SCAT forged 4.000” crankshaft part # 4-340-4000-6123
• Diamond Forged flattop 4.060” bore pistons (0.020” oversize) part # 51028
• Trend wrist pins part # TPD-G9842750155
• Perfect Circle file fit ring set with Moly ductile iron top rings part # 315-0036.065
• Clevite P-Series full groove main bearings part # MS-1344P
Price for this complete kit is $2,750 plus shipping cost.
Lunati Big Block Solid Roller Cam & Lifters - New [Re: Rocket] #3301754
04/20/25 08:57 PM
04/20/25 08:57 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new Big Block Lunati solid roller cam part # 40230912 & solid roller lifters part # 72451-16. The specs of the cam are as follows:
Part # 40230912
Basic Operating RPM Range: 4,500-7,500
Duration at 050 inch Lift: 276 int./284 exh.
Advertised Duration: 312 int./320 exh.
Valve Lift with Factory Rocker Ratio: 0.690 int./0.690 exh.
Lobe Separation Angle 106
Camshaft Gear Attachment: 3-bolt
Valve Lash: 0.026 in. Intake 0.028 in. Exhaust
Lifter Specs and Description are as follows:
Part # 72451-16
Fits Engines 361-440
Lifter Diameter 0.903"
Weight – Lifter Pair 256 grams
Seat Height 1.98"
Pressurized Oiling to Roller Bearings - Yes
Pushrod oiling - Yes
Lifter Wheel Diameter 0.81”
Developed for serious racing applications, the pressurized oiling system of these lifters provides constant lubrication through the axle and to the needles. This reduces wear in the axle and increases the durability of the lifter. Also, for increased durability, all surfaces are hardened and polished, which makes the body stronger and smoother while reducing friction. The solid vertical bar roller lifters with pressurized oiling are held to higher standards than the competition for the ultimate in race lifters
Was planning to build a big block bracket engine but plans have changed so these are no longer needed. I have not opened the lifter package as it is one of those plastic packages is like Howards lifters and usually breaks and never stays shut on its own afterwards. Picture of lifter pair is what was on a retailers website.
Price for the cam and lifters is $1,250 plus $30 shipping.
New BRC 4.030" Forged Pistons & pins for 3.79" Stoke Crank [Re: Rocket] #3301757
04/20/25 09:00 PM
04/20/25 09:00 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of BRC 4.030" Forged Pistons & pins for 3.79" Stoke Crankshaft Compression height is ~ 1.57" & the ring lands are 1/16, 1/16 and 3/16. Pins are 0.984”. Approximately 6cc valve reliefs. These pistons can be used in aftermarket race blocks or stock 360/5.9 magnum engine blocks with 4.030” finished bores. Price is $475 shippedin the lower 48 states. I will ship elsewhere for the added cost.
BRC 3.79 P1.JPG (454 downloads)
BRC 3.79 P2.JPG (454 downloads)
BRC 3.79 P4.JPG (455 downloads)
BRC 3.79 P3.JPG (454 downloads)
W2 / W5 Eshaust Roller R0ckers - New [Re: Rocket] #3301759
04/20/25 09:04 PM
04/20/25 09:04 PM
CT
Rocket Offline
Rocket  Offline
CT
I have 25 new Mopar Performance 1.5 ratio roller W2 exhaust rocker arms for the W2 & W5 Race heads using offset drilled blocks and shafts. I will sell individual rockers or sets of 2, 4,6 or 8 as needed. Individual rockers are $40 each shipped. A set of 8 is $290 shipped. I can do sets of 2, 4, ... Let me know what you need.
MSD 7AL2 ignition module and Pro Power Coil [Re: Rocket] #3301760
04/20/25 09:07 PM
04/20/25 09:07 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new MSD 7AL2 ignition module part #7220 and a used MSD Pro Power coil that is designed for use with the 7 series ignition boxes. The ignition box comes with all the original hardware still in the package and the harness. The coil was tested and has tested fine.
Price for the ignition box and coil is $650 shipped in the lower 48 states. I will ship internationally for the added cost if any.
Small Block Roller Rocker Kit 1.6 Ratio - New [Re: Rocket] #3301762
04/20/25 09:09 PM
04/20/25 09:09 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new PRW 1.6 ratio roller rocker arm kit containing all parts needed to install these rocker arms including steel bushed rocker arms, rocker arm shafts, spacers, shims, adjusters, steel shaft hold downs and hold down hardware. This kit is new in the box and is PRW part # 3231812.
Price is $500 shipped in the lower 48 states.
I will ship internationally for the additional shipping cost.
Eagle 4.250 stroke [Re: moparts] #3301832
04/21/25 10:47 AM
04/21/25 10:47 AM
ky
68roadrunner Offline
ky
Eagle 4402502200-8 crankshaft. Used. Chevy rod journal turned .020 after a bearing failure. Std mains. Machine shop checked out and turned, it all checked good except 2 small spots where the bearing went down, included picture of it. $600 OBO + shipping. I have a crank box to ship in if needed.
Re: Trend 3/8 Pushrods [Re: 68roadrunner] #3301871
04/21/25 01:09 PM
04/21/25 01:09 PM
Cent, OH
Mopar.70 Online work
Mopar.70  Online Work
Cent, OH
Brand new set, never used, .080 wall, 9.750 effective length, RB w/Trick Flow length range, $200 plus shipping
PM me here on the board, Thanks Moparts!!!!!
Msd 7531 [Re: Mopar.70] #3302225
04/23/25 01:20 PM
04/23/25 01:20 PM
ar.
bobs69 Offline
bobs69  Offline
ar.
Used msd 7531 350 dollars to your door. Came with a car we bought Not going to use it. What you see in the pictures is what you will get. Contact me here or (judywewer@yahoo.com)
Indy EZ-1 [Re: moparts] #3302986
04/27/25 09:35 PM
04/27/25 09:35 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Pair of used Indy EZ-1 heads. Roller springs and titanium retainers. Heads originally done by Computer-Flow. Flow sheets I can send by email. $2400 OBO plus shipping from 70053. Other parts available to complete top end for more money.
CSR water pump [Re: moparts] #3302987
04/27/25 09:43 PM
04/27/25 09:43 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
New in box CSR 902R water pump $300 plus shipping from 70053. Check, money order, PayPal friends and family or add 3 percent
Page 2 of 3 1 2 3
