Building a 416 stroker. 10.5:1 Ported aluminum heads, RPM air gap, 870 holley vac.,3:55 gears, MT drag radials 28" tall. Cam is a Howards 711351-08 Dur.....244/248 @.050"-Lift...566-578 108LSA and a 104 C/L...
I have their 9.5" 4K stall converter in my '80 Diplomat Coupe (3600 lbs).
Here is a bit of an explanation, as that may help you out a little more:
1) 360 motor, Hughes HE3844AL cam (238/244, .571/.576 w/ 1.6 ratio rocker, 108 LSA), 3.91 gearing and then 4.10
- initially had a 2800 stall converter, but that was way too little for that combo
- talked to Dynamic about what I needed, told them this is 95% street car and (at best) 5% track
- they recommended their 9.5" 4K stall, told me not to worry about the low RPM performance of the converter calling it their "tight" design
=> converter arrived, installed it, man what a DAY & NIGHT difference, this was the perfect setup, driving around town is no issue, yes, if you lay into the throttle harder the RPMs will flash but otherwise it is nice
- ran around with the 3.91 gearing for a few seasons but it always felt like something was "holding it back"
- moved to 4.10 gearing: PERFECTION!!! (for that combo, obviously...LOL)
2) 408 stroker, CompCams XR292HR hydraulic roller but on a 112 LSA instead of the 110 that XR292HR has out of the box (240/248, .584/.581 w/ 1.6 ratio rocker, 112 LSA but advanced 4 deg), 4.10 gearing
- the 360 motor was running a Perfomer RPM intake, but the 408 stroker is a W2 build with the Edelbrock 2920 Victor handling the induction chores
- kept the Dynamic 4K converter as-is, was worried a bit about the stall flashing much higher due to the extra displacement of the stroker motor, but decided to chance it thinking that the single plane Victor might bleed off a little low RPM torque, as would the slightly wider LSA on the new roller cam
- yup, the flash stall picked up about 200-300 RPM, but for my use that's not an issue at all
I do run a deep transmission pan and a stacked plate transmission cooler, that seems to be working well.
My advice to you would be: let the converter selection be driven by the camshaft/combo RPM range. Given the 244 dur on the intake with a 108 LSA and your choice of 3.55 gearing I would pick 4K stall at minimum.
When/if you call Dynamic back ask them about their "tight" converters, they'll be able to explain this very well.
