Page 6 of 6 1 2 3 4 5 6
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3299502
04/08/25 06:58 AM
04/08/25 06:58 AM
west palm beach, florida
modelmakerinc Offline OP
Rear patch finished, jamb sanded and prepped.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3299503
04/08/25 07:01 AM
04/08/25 07:01 AM
No pics but has 2 coats of epoxy and two coats of 2k like the rest of the car.
the roof damage is next then the front clip is going to be addressed
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3300528
04/13/25 01:54 PM
04/13/25 01:54 PM
I had posted a pic of the roof before but these are more detailed of the damage, the repair is to follow as I am waiting on the roof rail segment from AMD. at some point it looks like it got hit above the A pillar, there is very little rust at the lead seam. Most of the rust is in the inner structure along the drip rail flange and roof rail.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3300529
04/13/25 02:02 PM
04/13/25 02:02 PM
Cut out a section of the inner structure to be reinstalled and the entire roof rail segment that was mostly compromised by the rust. The drip rail flange had also rusted away but I will add use panel bond between the surfaces to make a solid structural seal.
I will be adding more pics and how it gets reconstructed in a week or two.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3300531
04/13/25 02:13 PM
04/13/25 02:13 PM
the insane amount of filler on this car is astounding. I blocked down all that was on the driver fender to the tune of over 6 pounds. This fender did not have any damage other than a few dings here and there and 50 plus years of who knows what. The remaining filler is barely a skim coat but you can see layers upon layers that were removed. I will block it down more before epoxy and 2k.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3300533
04/13/25 02:25 PM
04/13/25 02:25 PM
One of the most important Mopar details is the curbside Pentastar, digging down 3/16 i found where it should be. blocked it flat and re-drilled the welded holes. Just the leading edge on the fender you can see the thickness of the filler.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3300534
04/13/25 02:30 PM
04/13/25 02:30 PM
These are great comparison pics, the driver fender shape as compared to sanded back to stock passenger side. The profiles really show how bad this car had mud plastered on.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3303266
04/29/25 11:21 AM
04/29/25 11:21 AM
Well I jumped around from task to task as my schedule allowed and waiting on a few patch panels to arrive. I revisited the fitment of the rear bumper, the re-pop doesn't have good shape to the stamping. since it needs re-chrome anyway, I trimmed and added as needed to correct the shape.
before and after pics
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3303268
04/29/25 11:24 AM
04/29/25 11:24 AM
bumper final fitment.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3303272
04/29/25 11:37 AM
04/29/25 11:37 AM
Back to the roof rail, the passenger A-pillar area has a previous repair, It had been welded in the glass channel and at an angle across the corner. The stories that can be asked about this cars history...
I did some massaging of that metal for a better shape requiring little filler. cleaned up what wasn't done well, added a few small patches along the drip rail, welded on the trim pins. I was able to sandblast and treat the backside of the roof along the seam since I cut out part of the structure, panel fit the roof rail and re-fit the interior structure I removed.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3303273
04/29/25 11:43 AM
04/29/25 11:43 AM
few more pics of roof rail
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3303277
04/29/25 11:52 AM
04/29/25 11:52 AM
Onto the driver fender. No shortage of POUNDS of filler eek
The entire fender has dings dents and generally has been beat up its existence. the dogleg is wasted, rust and an dumbazz with a pick hammer just decided to pound and pave. This fender has alot of issues but is fixable with patience and work.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3303278
04/29/25 11:58 AM
04/29/25 11:58 AM
Like the rest of the car, 1/8" to 5/16" thick filler is everywhere hiding all the subtle body lines and details. The gentle recessed curve above the bumper was filled and flat, leading edge of the fender opening and grill surround, the wheel flare was non existent. CRAZY realcrazy runaway
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3303484
04/30/25 01:43 PM
04/30/25 01:43 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Nice work on the patches. I have similar work to do on the doors of my Charger.
Two questions: How did all that gravel and what-not get behind that panel? Through the rust hole prior to previous repair?
Originally Posted by modelmakerinc
Moved to the pass side and tore into lower A-pillar. Found a little rot, much more solid than drivers side. CUT, BLAST,FAB,PREP,WELD,GRIND,SAND, DONE, NEXT....
Also, what is the copper colored spray you are using on the edges of these repairs?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
