Re: '14 JKU M-380 - "Kilroy"
[Re: Mad-Max]
#3299757
04/09/25 10:43 AM
04/09/25 10:43 AM
Posts: 430 Falcon, CO
Mad-Max
Falcon, CO
...gas tank filler tube and vent are connected - used Gasoila E-seal to seal the filler neck vent fitting - the 5/8 hose to the tank - ![[Linked Image]](https://i.imgur.com/HOysfuu.jpg) ...steering column is assembled and installed, steering wheel is on, and dash is installed - so far so good - ![[Linked Image]](https://i.imgur.com/b3nczKC.jpg) ![[Linked Image]](https://i.imgur.com/ROxkcQb.jpg) ![[Linked Image]](https://i.imgur.com/FdNXoph.jpg)
71 Demon (on deck): Magnum 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy": Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 52 Willys M-38 "Poncho" 14 Ram 4500 "Big Mack": 6.7 CTD, Aisin, 4:10s, 4x4
[Re: Mad-Max]
#3300521
04/13/25 01:22 PM
04/13/25 01:22 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3300933
04/15/25 01:58 PM
04/15/25 01:58 PM
Mad-Max
Falcon, CO
Most of the engine bay wiring is complete, and the big battery cables and alternator wiring are next. Meanwhile...it can get pretty dusty where we live and wheel, and with that in mind I pulled the d-side valve cover and had a short tube welded to it for this bigger/better/cleanable K&N valve cover breather (my favorite aspect of it is that it isn't chrome), and I'm looking for a pre-filter for it too. ![[Linked Image]](https://i.imgur.com/ajRi1Gg.jpg)
[Re: Mad-Max]
#3301037
04/16/25 11:18 AM
04/16/25 11:18 AM
Mad-Max
Falcon, CO
sweeeet - battery cables are connected, grounds are connected, and on the first try the '12v switched power' half of the fuse block powered up perfectly  , and with the headlight switch already connected the backlights for the gauges powered up too - even the dimmer works  . Booyah  With no oil pressure, no fuel pressure, no power steering fluid, and no spinning alternator, the 4 warning lights are doin' exactly what they're supposed to be doin'  . Soon as the radiator, steering, brakes etc. are wet and ready I should be ready to fire up the engine. ![[Linked Image]](https://i.imgur.com/DSj3yZU.jpg)
[Re: BDW]
#3301201
04/17/25 11:24 AM
04/17/25 11:24 AM
Mad-Max
Falcon, CO
Thanks! I'd say within weeks - I'm within a week (maybe days) of firing it up, and if that goes well then driving it is the next milestone. ************************ The Sniper main wiring harness comes with a 10-pin output plug for lots of accessory items...all but two of which I will not be using, so I dug back into the harness and surgically deleted all of the unneeded wires, leaving the white signal wire to the Hyperspark, and the tach... My modified alternator bracket (removed the drivers-side half) is painted/baked/installed, and the serpentine is on. The power steering pump is a GM type-2 unit and it's located in the same spot as was original for a '94 Grand Cherokee. Not sure if a GC ever came without A/C, but if so they would have used the serpentine in the pic. Regardless it all fits great, and without the big A/C half of the bracket in the way there's lots more access to stuff. Meanwhile, the ram, orbital and lines are filled, and the master cylinder and remainder of the steering hoses should be all in place in a couple days, along with getting the brake wet. ![[Linked Image]](https://i.imgur.com/xVhXvzn.jpg) ![[Linked Image]](https://i.imgur.com/WGl7xCA.jpg)
[Re: moparx]
#3301324
04/18/25 11:43 AM
04/18/25 11:43 AM
Mad-Max
Falcon, CO
sweet - with a successful 'test bump' on the starter cable/wiring, and with the Sniper disconnected and serpentine belt off, I pulled the plugs and pushed/held the starter and free-spun the engine for about 30 seconds: Oil pressure warning light quickly went off and oil pressure began to build climbing up to about 55 psi...and held the starter button for several more seconds to get oil all squished around in there. No bad noises - just the starter which just whined along easily spinning the hardware. Bumped the starter a couple more times just to make sure, and again all good - and that's huge 👍 . Then proceeded to bench-bleed the master cylinder, made a couple plugs to transport it to the engine bay to bolt it in place, then proceeded to gravity bleed the brake lines...which went about as smoothly as I've ever done. Pedal feels good, and no leaks 👍 . Time now to install the fan, do the finishing touches on the shroud, and bolt it in. Remaining steering hoses are next. Getting close! I don't know why, but these 'Dodge' hydrobooster setups include a 45* adapter - probably something to do with the firewall orientation or something, but either way I'm using it all, including the 4-3/4" internal pushrod, and as such there ends up being about a 3/16" gap between the m-cyl and the adapter flange, so I made a 3/16" spacer for it - ![[Linked Image]](https://i.imgur.com/Mv2uJ3L.jpg) ![[Linked Image]](https://i.imgur.com/YfacELc.jpg) ...in a pinch just smash the ends of the tubes - makes for a decent plug - worked great for the short duration of transferring the m-cyl to the engine bay and avoiding a lot of messy brake fluid dribble... ![[Linked Image]](https://i.imgur.com/dl0uqFc.jpg) ![[Linked Image]](https://i.imgur.com/1LlM5hf.jpg)
[Re: Mad-Max]
#3301477
04/19/25 11:24 AM
04/19/25 11:24 AM
Posts: 21,355 north of coder
moparx
Buying your homeless and unwanted bolt on battery terminals
for future reference, eddleman, wagner, and other brake hardware outfits make plugs that are the common 3/8-24 thread size that have the correct seat to seal off brake line adapter fittings and the fittings that come on the sections of line. [i'm sure you know this. just tossing it out for other's who may not know.] i'm sorry i can't provide part numbers, but they should be easy enough to come up with. i have used the "mash the line flat and tight" plugs a ton over the years, and they work as intended every time.
[Re: moparx]
#3301848
04/21/25 11:21 AM
04/21/25 11:21 AM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3301850
04/21/25 11:21 AM
04/21/25 11:21 AM
Mad-Max
Falcon, CO
...pic of the brake flex hoses to the chassis - these are really nice because if I ever need to maintain the hydrobooster I can unbolt the m-cyl and set it aside without losing any fluid - ![[Linked Image]](https://i.imgur.com/dCJqKls.jpg) ...and picked up this simple Outerwares mesh cover for the breather ![[Linked Image]](https://i.imgur.com/HdZ60oA.jpg)
[Re: Mad-Max]
#3302063
04/22/25 12:52 PM
04/22/25 12:52 PM
Mad-Max
Falcon, CO
...with no leaking fittings/hoses, I connected Sniper power wires, hit the main 12v switch, and the EFI 'initiated' just like it's suppose to - fuel pump primed up, pressure warning light went out, throttle body 'squirted', fuel pump deactivated, all as expected. It's ready to fire now, but first have to bolt up the tires, re-bleed the brakes, clean the shop, and a few other things...including taking a couple days to 'breathe'...but everything appears to be 'ready' to fire it up this Sunday  .
[Re: Mad-Max]
#3302110
04/22/25 07:04 PM
04/22/25 07:04 PM
Posts: 11,227 Freeport IL USA
poorboy
Freeport IL USA
 We will all be waiting for the report on this event. The only involvement I have is this project is watching it progress from my in home desk top computer. So, why do I feel like I'm sitting in your shop waiting with you? Must be the excellent write up along with the exultant work! Thank you for bringing us along on your project!
[Re: moparx]
#3302212
04/23/25 12:28 PM
04/23/25 12:28 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3303075
04/28/25 12:41 PM
04/28/25 12:41 PM
Mad-Max
Falcon, CO
woohoo! - Kilroy is alive!! Note to everyone - when first firing up a fresh build after 16 months and 1300 hours of building...make sure ALL of the EFI wiring harness terminals are plugged into their respective plugs - if the distributor plug isn't connected you'll get a whole lotta nuthin' when you try to fire it up...but hey it gave the engine one last oil bath before firing...  I had a half dozen friends standing by as my pit crew ready to immediately begin filling in the tranny, power steering, and coolant, while also checking for leaks and any signs of 'badness'. Once the dizzy was connected it fired right up like it had been running yesterday. Cooling. My #1 unknown was whether or not the stock 3/4" off-the-parts-store-shelf JK radiator would be 'big' enough to cool the 5.9 Magnum engine, and I'm very happy to report that apparently...it is  - at no time during the initial break-in or subsequent drive-around afterwards did the engine get 'hot' - not even 'warm' - it has a 180* thermostat and it never went north of 185* on the Sniper display, with the dash gauge matching suit. Camshaft/lifters. All I can say is it runs smooth and seems to be making less of the 'chattering' sounds it had before, so I'll take that as a win. Voltage. While both a multimeter and Sniper display indicate the charging system appears to be nominal kicking out ~14.3 volts, the voltmeter gauge and charging monitor gizmo are not matching suit - the voltmeter reads high and the charging monitor gizmo doesn't appear to be working right, neither of which are a problem - just annoying. But in the 'well that's cool' column, Don at ISSPRO tech wants me to send the gauge in so he can check it out and see if it's faulty - great customer service at ISSPRO  . Mid way through the initial run a new sound started coming down from the water pump area - a very strange thunking/slapping sound, which ended up being the serpentine belt slapping itself back into the proper grooves. I hadn't pressed the power steering pulley onto the shaft quiiite far enough, which meant the serpentine was trying to slip itself out of place and was slapping back in place, which was resolved 5 minutes later by wrenching it about 1/8" further onto the shaft with the installation tool - didn't have to disassemble anything (my kind of fix). Transmission and power steering were both taking on fluid and bleeding themselves out nicely, repeatedly cycling through the gears and turning the wheel from lock to lock. With everything looking good and the brakes feeling good...we shut it off, grabbed some beers, and celebrated a very successful break-in. Buuuuut it didn't take long before the shop got cleared out so I could back it out for a few test-passes around the property. I quickly discovered the tranny was still thirsty, and the steering was still bleeding itself out, but after 3 or so trips back to the shop and several figure 8's we had the tranny topped off and the steering better and better after each turn, and then to the pit and rock pile I went. Oh and the Prestone power steering fluid is performing every bit as well as the Swepco - no bubbles or signs of aeration...like at all. We have a 12-foot deep crater out back and a pile of boulders next to it, both of which have been sources of big fun over the years, and this time was no different. Went into the pit, and started the first dose of trials. First thing we noticed was the fan was contacting the shroud juuuust a little, and would need more clearancing, which I did this morning. Other than that...well it did great, and in no time I had a really big grin clear around my whole head 😁 . Fortunately the list of 'not goods' is really a list of 'not so bads', and is short to boot. The rear main is leaking a little...which might be partially due to me having the oil pan overfilled by a quart and the Jeep being at a 40* angle for a bit, so I drained a quart out and that might help a little - otherwise not much I'll do in the short run - maybe address it at the end of the season. Another thing I'm less thrilled about is how much the front coils seem to have compressed - even with the 6.5" coils (and 4.5's in back) I'm wanting another inch or two of up-travel in front, so I may have to look into either stiffer coils or spacers. SO - very successful first run, and I'm really pleased with how well everything is working out. Love the size of it, love the Jeep JK muffler and resonator - it's nice and quiet with just the subtle hint of a big V8 under the hood - time will tell if my decision to run a 2.5" single exhaust was a good or bad one...but so far I'm really liking it. Ok - now it's time to start bolting the rest of it together  . - Sam ![[Linked Image]](https://i.imgur.com/FDcoi8J.jpg)
