MOPAR 2538940 speedo drive gear
[Re: moparts]
#3300512
04/13/25 12:28 PM
04/13/25 12:28 PM
Posts: 893 In the Middle
roadntrack
In the Middle
N.O.S. MOPAR 2538940 speedo drive gear $80 plus shipping
Remember when cars were FUN?
Re: Mopar Transmission For Sale - 2nd Quarter
[Re: moparts]
#3301010
04/16/25 12:37 AM
04/16/25 12:37 AM
Posts: 46 Jackson,tn
Jwise
Jackson,tn
904 lock up transmission. 2.74 low gear set. Rebuilt with all new clutches ,seals and bushings. New HD direct band and hi energy rear band. Performance shift kit with automatic Valvebody but full manual shift if desired. 700.00. Contact me with any questions.
[Re: Jwise]
#3303245
04/29/25 09:55 AM
04/29/25 09:55 AM
Posts: 3,200 tennessee,usa
mattsmopars
tennessee,usa
*Pending full payment* I have a complete 1969 383HP 440HP 727 Torqueflite. The part number stamp is PK2892093L the date stamp is 2742 which is January 29,1969. The partial vin stamp is 9B303928, so most likely from a 69 charger. Let’s consider this a core unit to restore/ rebuild, comes as pictured with the lower portion of kick down linkage. Asking $1350.00 OBRO for it, and I could deliver it to Carlisle, the nats, or the moparty with a deposit. You can PM me here for more information. Thank you, Matt
[Re: Jwise]
#3306944
05/19/25 03:43 PM
05/19/25 03:43 PM
Posts: 4,646 Michigan
MarkZ
Worthy
Worthy
I've got two Jeep T-18 four speed transmissions and an unknown NP transfer case. Want it all gone. The pictured T-18 is a working pull that came out of a J10 /w 360 for an NV4500 swap. The transfer case and not pictured T-18 should be regarded as cores. $150 for all of it. Located in Saint Clair, MI.
[Re: MarkZ]
#3307171
05/20/25 07:36 PM
05/20/25 07:36 PM
Jwise
Jackson,tn
Mopar Performance deep trans pan. Fits 904,A500,42 and 44re . Cast aluminum with drain plug and bung for temp sensor. Purchased new in the 1990's and never installed. 200.00 will ground ship or meet in the area of you'd like to pick it up in person.
