Mopar Differential For Sale - 1st Quarter #3279397
12/31/24 07:51 PM
12/31/24 07:51 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3279448
12/31/24 09:14 PM
12/31/24 09:14 PM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
Pair of 8 3/4 or Dana shock plates with U-bolts. For 3" tube. A few of the locking nuts missing from U-bolts. Asking $60 for all.
Contact Bud: Kramden426 at aol.com
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3279451
12/31/24 09:26 PM
12/31/24 09:26 PM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
Adjustable pinion snubbers for 8 3/4 center sections. Asking $35 each.
742 Alum 8.75 NIB for sale [Re: moparts] #3279468
12/31/24 10:58 PM
12/31/24 10:58 PM
Capital of Narcissism
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Mopar Alum 8.75 Carrier NIB
Catalog stated when released new design is 10% stronger than original design
Likely last new one available in the country
As Is
$2125 plus shipping, delivery possible east of Mississippi with agreed upon reasonable extra fee
I have 4, decided to use my Mag Dana 60 instead
"We found that, in general, people don't stop to think whether there might be more information that would help them make a more informed decision," said study co-author Angus Fletcher,
8.75" 742 4.30 w/spool for sale [Re: moparts] #3279470
12/31/24 11:01 PM
12/31/24 11:01 PM
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
8.75" 742 with 10 spline MW billet1350 Yoke with 2 MW Billet caps, ARP ring bolts.
MW spool, will have to verify spool spline count and 4.30 ratio, it's been years.
All new bearings/parts brand new except housing, never run nor installed, professionally built
Not sure if a stronger 742 can be built
Over $1500 in parts new w/o labor
$1350 + shipping, delivery east of Mississippi possible at additional fee, from SW Fla PM
8,75" steel MW caps pair New for sale [Re: jcc] #3279471
12/31/24 11:03 PM
12/31/24 11:03 PM
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
These caps are new never been installed. they require minor fitting by installer, as all aftermarket upgrade caps do.
The blue paint marking means they have been Cyro treated.
It's common thinking only the driver's side cap fails first, therefore it's the only one thought to need an upgrade. There is no known downsides to doing both caps other than cost.
Meaning two 8.75's can be upgraded here, I am not willing to separate.
$250 + Shipping SW Fla PM
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3279574
01/01/25 11:45 AM
01/01/25 11:45 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
4.10 and 3.54 gear ratio tags. The 3.54 tag is a little rough but still usable. $10 for the 4.10 and $5 for the 3.54 + postage.
gt340 at yahoo.com
Gear tags.JPG (971 downloads)
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3280041
01/02/25 07:07 PM
01/02/25 07:07 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
A-Body 8-3/4, standard width, perches moved in to the frame rails (for mini-tub car), 3:91 Suregrip, Moser axles, bigger B-body drum brakes, 741 case, very good condition, ready to go complete with parking brake cables and pinion snubber.
Located in Franklin, KY, 5 miles from Interstate 65 at the TN/KY state line. Can mount on a pallet for pickup, zip is 42134.
Asking $1800 - make offer. Click below for pics, PM me here on Moparts if interested.
Thanks, Moparts!
[img]https://imgur.com/a/k5vq5Jb[/img]
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3281852
01/10/25 12:42 PM
01/10/25 12:42 PM
Arizona
sixpakjoe Offline
sixpakjoe  Offline
Arizona
Rear axle Ring & Pinion set. This is a 4:10 ratio gear set used in the 8 3/4 rears, 489 case #. It has very limited usage and is like new. $200 Pickup only (Phoenix, AZ). Too expensive to ship.
Ring and Pinion.jpg (762 downloads)
Rear Axle Tie Down Brackets [Re: moparts] #3282284
01/12/25 06:21 PM
01/12/25 06:21 PM
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
A matching pair of new never used long offered well accepted STD Mopar rear axle steel tie downs, only one pictured.
User determines suitability and supplies own nuts, etc to attach to existing leaf/axle U-bolts.
$40 plus shipping PM
SOLD
8 3/4 & Dana 60 Axle Bearing Retainer Adjuster Flanges [Re: moparts] #3282575
01/14/25 05:08 AM
01/14/25 05:08 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
8 3/4 & Dana 60 Axle Bearing Retainer Adjuster Flanges. Used, $50 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
8-3/4 parts and pieces [Re: moparts] #3283587
01/19/25 01:11 PM
01/19/25 01:11 PM
Out of the State of Confusion
blue_stocker Offline
66/7 B-body 55-1/2" housing, Moser brace, drain, 2-1/4" inspection/fill bung with blue anodized cap, sand blasted, self-etch primed, ready for paint and installation...$250. New: Richmond 4.30 gearset, Timken bearings, 1350 companion/pinion yoke, clean/used Yukon nodular 489 case, Moser 35 spline spool, ready to install...$800. Lightly used 5.12 Richmond gearset in OEM 489 case, Moser 35 spline spool, new: Timken bearings, 1350 companion/pinion yoke, fresh & ready to install...$700. New Yukon 489 case, 5.38, Moser 35 spline spool, 7260 companion/pinion yoke, clean & ready to install...$750. New 5.57 gearset for 489 case...$300. 2 used sets of 5.38 742 gearsets...$180 each. New Moser 35 spline spool with bearings...$200. All parts priced less shipping, located in the Savannah, Tn area. For information or pictures PM me here. Thanks for viewing and thank you Tom for the add space, much appreciate...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
8-3/4 Bench Fixture [Re: blue_stocker] #3284564
01/23/25 07:40 PM
01/23/25 07:40 PM
MO
cdp Offline
cdp  Offline
MO
I have 1 extra custom fixture I had made to rebuild a couple of 8-3/4 center sections.
Steel, powder coated, ambidextrous plate (bolt patter allows for 180 degree up/down) can be setup in a vice or mounted on your bench. Includes a custom yoke tool, and custom powder coated spanner wrench.
I put 240ft per spec without any problems.
SOLD, Paid as gift, PayPal.
816-726-fourfive_one2
chrispy1971gtx@yahoo.com
Re: Strange Axles - E-body 8-3/4 [Re: moparts] #3285209
01/26/25 10:32 PM
01/26/25 10:32 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
These are nearly new street/strip alloy Strange axles for Mopar 8-3/4 rear in a 70-74 E-body (cuda or challenger). I installed them, used for 50 miles, but ended up changing the entire rear end setup. Has green bearings installed so you don’t need to set tapered bearing end play, 30 spline, stock width, made for 1/2” thread in lug studs. These cost over $600 new. Asking $400 plus shipping. EDIT: SOLD.
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3289776
02/15/25 10:16 PM
02/15/25 10:16 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Dana 60 posi side gears - 23 spline
Dana 60 side gears for Spicer posi-traction. These are the 23 spline (others are 35 spline). Part # stamped on the is 34168.
$40 + shipping from 56007 ***************SOLD*************
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3293222
03/07/25 11:51 AM
03/07/25 11:51 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1969 & up Dana 60 pinion snubber for "B" & "E" body cars, nice used condition $250.00 (708) 288-2879
parts 03-05-2025 022.JPG (295 downloads)
parts 03-05-2025 023.JPG (296 downloads)
parts 03-05-2025 024.JPG (296 downloads)
parts 03-05-2025 025.JPG (297 downloads)
Moser Axle [Re: moparts] #3294299
03/12/25 03:37 PM
03/12/25 03:37 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
One Moser Axle for sale. 35 spline. Measures 24 3/4" from flange to end. Mopar bolt pattern to hold axle to rear end housing. 4 1/2" bolt circle for Mopar wheel. $200 including shipping. rich1981@optonline.net
Axle 24.75.jpg (208 downloads)
Re: Axle Tag [Re: ValiantRich] #3295153
03/16/25 04:11 PM
03/16/25 04:11 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
3.23 gear ratio tag. $10 for the tag includes postage.
kudakidd@hotmail.com
742 Aluminum [Re: moparts] #3295780
03/19/25 01:33 PM
03/19/25 01:33 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
New in the box Aluminum 742 Mopar Center Section $1,250 including shipping. rich1981@optonline.net
742 al.JPG (69 downloads)
742 box.JPG (69 downloads)
Gear Sets [Re: ValiantRich] #3295784
03/19/25 01:43 PM
03/19/25 01:43 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
New in the box, US Gear Ring & Pinion 9310 Pro Gear, 4.44 Ratio for 742 Case. $700 including shipping.
New in the box, Toms US Strange 4.86 Ring & Pinion Pro Gears for 742 Case. $600 including shipping.
New in the box, Richmond 8620 Street Gears 4.57 Ratio for 742 Case. $325 including shipping.
