Re: 340sb with 5 speed conversion?
[Re: Buschi340]
#32933
01/10/07 06:21 PM
01/10/07 06:21 PM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
maybe stupid question, but: why does noone use the complete Dodge truck trans (I think they are called NV5400)? Are they that huge, I eman the A518s are usable in muscle cars too? Wrong gearing for street car? Would tehy fit into a C-body (I got one...)?
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
[Re: Clair_Davis]
#32935
03/01/07 02:38 PM
03/01/07 02:38 PM
Posts: 468 Germany, Northcoast
Buschi340
Germany, Northcoast
Clair, this is a Bellhousing from a 1987 Dakota V6. What do you think? Does it fit? Btw, I just bought the Supra tranny...
[Re: Flo]
#32936
03/01/07 04:57 PM
03/01/07 04:57 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the NVG1500/1550 replaced the AX15 in 4cyl jeeps and 4cyl daks, and that's a very weak tranny--I wouldn't put it behind a V-8. the NVG3500/3550 was behind 5.2's in dakotas and rams, but they are physically very large, and have an integral bellhousing, like an auto tranny. IIRC they're rated from NVG for 300 ft-lbs, and because of that were never offered behind 360's in 1/2 tons, only 318's. I had one in my truck, ratios were nicely spaced, but I don't think it would be worth the hassle (you'd have to do MAJOR surgery for this one--it's physically larger than a tremec TKO) the NVG4500 was in 3/4 and 1 tons, it's a cast iron 5 speed with low (6:1ish) first gear, and is very beefy, but not performance oriented, and larger than the 3500. the 5600 is the cast iron 6 speed that was offered in 1 tons. it makes the 4500 look small. I used to work for the company that built all the shifters for NVG and the Tremec T-800 tranny in the GM pickups (In fact, I did some of the design work on the tremec shifter)
[Re: Buschi340]
#32939
03/24/07 10:57 PM
03/24/07 10:57 PM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
I *THINK* that any 143-tooth flywheel will interchange, but don't quote me on that, I haven't verified. The Dakota V-6 flywheel I've got looks the same as my 130-tooth flywheel, except larger diameter. I need to put them on a flat surface and compare critical dimensions for depth, but they LOOK to be the same. The nice thing about the Dak V-6 'wheel is that it uses a 10.5" clutch & pressure plate, just like the OEM 340's. The smaller clutch disk will shift easier since the synchros in the trans don't have to stop as much mass as a larger flywheel, and the lighter rotating mass on the flywheel will let the engine rev easily. Going to the larger/heavier parts really hurts performance. A nice combo MIGHT be a 143-tooth aluminum flywheel with a 10.5" clutch disk & pressure plate.
Clair
[Re: Buschi340]
#32941
05/08/07 10:09 PM
05/08/07 10:09 PM
Clair_Davis
Fort Worth, TX
No progress on my end, I've been putting all my time (all 3-4 hours per week ) in to getting my EFI running better, now that I have it running at all. Another resource for you might be the little 4-cylinder diesel engines in the Jeep Liberty, and perhaps others over there that use the same engine. They use (from what I understand) an identical flywheel/bellhousing setup. I haven't compared them up close and in person, though. The bell is the magic part, I think just about any 11" flywheel would do the trick. Clair
[Re: Clair_Davis]
#32942
05/09/07 06:45 AM
05/09/07 06:45 AM
Buschi340
Germany, Northcoast
Clair, do you think the 3.9 and the Diesel Bellhousings share the same P/N's? These parts in used condition are really hard, would say impossible, to find here in germany. And new? Cant belive the price.... 4 digits w/o a dot in it!!! My 904 gone down these days and I saw that my crank has the drilling for the pilot bearing. Good to now... What Efi are you running? Think I can take advantage of your knowledge...
[Re: Buschi340]
#32943
05/09/07 08:05 AM
05/09/07 08:05 AM
Clair_Davis
Fort Worth, TX
You'd have to check the PN's on the 3.9/diesel bells to see if they were the same. My only real concern with the Jeep diesel bell is that Jeeps frequently have the starter on the passenger side for space, but I don't know if the Liberty is the same as the Cherokee/Grand Cherokee in that respect.
My EFI is from a 1990-1992 Camaro Z-28, and I'm recalibrating it to like my 72 340 with cam, headers, etc. So far, it's very frustrating. Think of tuning a carb where you have to choose from an infinite quantity of jets, air bleeds, and emulsion tubes... Getting closer, but I'm not very patient...
Clair
[Re: Buschi340]
#32946
05/10/07 09:04 AM
05/10/07 09:04 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If you simply can't find the parts they can always be shipped over there. I know that's expensive but it can be done. If I was planning on another trip over there, I'd carry them with me. I am overdue for the trip. My last visit was for the Grand Prix of Europe at the Ring in 2005.
[Re: Buschi340]
#32948
05/11/07 04:50 AM
05/11/07 04:50 AM
Flo
Berlin, Germany
Two friends of mine will come over in September... They might have some space in their suit cases too. Greets Flo
[Re: Clair_Davis]
#32950
08/07/07 05:03 PM
08/07/07 05:03 PM
Buschi340
Germany, Northcoast
Hi Clair, can you see by the picture if this bell fits? Seller says 1997 3.9L V6 Dakota with all the conversion parts (for a Dakota tranny swap).
[Re: Buschi340]
#32952
08/07/07 10:30 PM
08/07/07 10:30 PM
Clair_Davis
Fort Worth, TX
That looks like the stuff. I think my bell is also from a 97 V6. The flywheel should work fine, as would the pressure plate, but the clutch disk will have a different spline than the Toyota disk. If you used the AX-15 trans, it would be a non-issue. The driveshaft yoke will also have a different spline, as far as I know. I'd have to do some searching to verify that the driveshaft yoke was the same spline as a 727 or 904, though. I'm not sure how Mopar handled that one. I've got an AX-15 in the garage, I guess I could check that one of these days...
Clair
