39k mile takeout motor anything you would freshen up? #3291696
02/26/25 08:25 PM
02/26/25 08:25 PM
Andrewh Offline OP
Andrewh  Offline OP
I got a 392 takeout motor that has 39k miles on it.
I know I am redoing the valve cover gaskets, because I saw oil in some of the plug holes.
I am debating the hellcat oil pump and since I have it off anyway, a new water pump and thermostat.
but realistically I might put a few k miles on it every year. so is it worth tearing into for that to try and prevent the lifter tick that people talk about?
anything else that might be easier to do while it is out? or am I over thinking?
Re: 39k mile takeout motor anything you would freshen up? [Re: Andrewh] #3291728
02/27/25 12:38 AM
02/27/25 12:38 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I wouldn't mess with any of it, no hellcat pump or anything unless I need more HP of course but they can make well over 500HP with long tube headers and good tuning.
Re: 39k mile takeout motor anything you would freshen up? [Re: HotRodDave] #3291836
02/27/25 03:40 PM
02/27/25 03:40 PM
Andrewh Offline OP
Andrewh  Offline OP
yeah, I don't plan on mods, but was concerned with the lifter tick that could develop but haven't seen a good reason why other than low oil flow.
Re: 39k mile takeout motor anything you would freshen up? [Re: Andrewh] #3291890
02/27/25 10:41 PM
02/27/25 10:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
That has nothing to do with them ticking. The lifter was updated with needle bearings made out of butter starting in 2009 and nothing you do will stop them from failing, it's just a matter of how long. They eventually re-upgraded to bigger needle bearings like the earlier ones had that are far less failure prone.
A 6.4 has a bigger pump than a 5.7 and a 2009 up 5.7 has a bigger oil pump than the earlier 5.7, ironically they got a bigger pump the same year the bearing failures started.
Re: 39k mile takeout motor anything you would freshen up? [Re: HotRodDave] #3291911
02/28/25 07:15 AM
02/28/25 07:15 AM
Andrewh Offline OP
Andrewh  Offline OP
thanks for the info. I did not know that.
Re: 39k mile takeout motor anything you would freshen up? [Re: Andrewh] #3292179
03/01/25 09:46 PM
03/01/25 09:46 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Unfortunately there is tons of really bad info out on these things from people who know more about making youtube videos than they do about how a hemi, VVT, MDS... actually works.
Re: 39k mile takeout motor anything you would freshen up? [Re: HotRodDave] #3292222
03/02/25 09:14 AM
03/02/25 09:14 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Whats the engine going in?
Re: 39k mile takeout motor anything you would freshen up? [Re: moparjim79] #3292224
03/02/25 09:21 AM
03/02/25 09:21 AM
Andrewh Offline OP
Andrewh  Offline OP
65 coronet convertible.
Re: 39k mile takeout motor anything you would freshen up? [Re: Andrewh] #3296515
03/23/25 04:38 PM
03/23/25 04:38 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I'd follow HotRodDave's advice. I pulled my oil pan when doing water pump (I just kept removing stuff lol). '10 Charger Pursuit 80k miles at time. Here is what the pan looked like (before and after). My guess is that when I got the car and started using a good high detergent oil it loosened up some of this garbage. Amazing how well the car ran. 96k miles now and quiet as can be and I did not replace oil pump, just the gasket which was and still is leak free.
I bet your pan is clean though but you could do the gasket.
Facts are stubborn things.
Re: 39k mile takeout motor anything you would freshen up? [Re: larrymopar360] #3302890
04/27/25 09:36 AM
04/27/25 09:36 AM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
I would install new pistons. Its a $1000, but i went thru it already. Tuner put in to much timing and blew the ring lands on about 4 pistons. I do another i will pull the pistons and put in MMX stock forged. IMO
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
