2009 Dodge Charger Pursuit 115k miles 5.7 Hemi.
Clean rust free inland NC (Charlotte area) car.
This car was reconditioned to include the following services performed:
Rear end lube, transmission fluid & filter, engine oil & filter, antifreeze & thermostat changed.
New spark plugs, headlight housings & bulbs, A/C compressor & clutch, air filter & cabin air filter changed.
New front struts, inner & outer tie rod ends, upper & lower control arms, bushings & ball joints, front sway bar bushings & end links. Four wheel alignment.
New front rotors & brake pads all around.
Following new parts installed: Radiator, heater hoses, water pump, coolant overflow bottle, serpentine belt, idler & tensioner pulleys, rear sway bar end links, & wiper blades.
Brake fluid changed & throttle body cleaned.
Factory center console added.
Interior carpet, seats removed & shampooed.
Price $6500. Cash only, no trades!
Text Tom at: 704-771-2626.
Message me here.
or
Email me at: tarodgers0627@icloud.com
