Page 28 of 28 1 2 26 27 28
Re: My 63 Dodge 330 Project: [Re: GY3] #3267802
11/02/24 07:22 PM
11/02/24 07:22 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Another season comes to an end and, while we didn’t get to go to the track much, we made the most of it and got that goal of a 9 second e.t. that I’d been chasing for a while now!
I’m far from done as we had plans of going to a radial prep event and the air was amazing that night. Unfortunately, the top tank on the radiator decided to start leaking when I was preparing to load it on the trailer! At least it happened off the track and didn’t spoil the prep or cause an accident by happening later! Tulsa’s Mopars at the Park was also cancelled, but wasn’t sure I was going to take the car anyway.
I’m sure it has a 9.8x in it and I’m taking some steps to make it easier to get there. I have no plans of cutting the car or even putting in more cage, but there is quite a few lbs. in weight reduction to be had.
One big thing that I would like to accomplish is driving it to our local track, running a 9 and driving it home Just to say I did! grin
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: My 63 Dodge 330 Project: [Re: GY3] #3270126
11/12/24 08:42 PM
11/12/24 08:42 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
More weight reduction today. Titanium alternator bolt and some bolts for the clutch fan.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #3270129
11/12/24 08:46 PM
11/12/24 08:46 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Looks cool, too. May have to stealth it up with some paint!
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #3270154
11/12/24 11:53 PM
11/12/24 11:53 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Shoot, chuck it up in a lathe and take off that rounded part right above the hex. There's another gram or two. work
Re: My 63 Dodge 330 Project: [Re: mopowers] #3270178
11/13/24 08:54 AM
11/13/24 08:54 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I probably could, but I'll just replace the alternator bolt tubing with some aluminum! grin
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #3270339
11/13/24 07:58 PM
11/13/24 07:58 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
There ya go! Don't forget about the brackets. Those would be a piece of cake to replicate in aluminum.
I love this car by the way. Good looking hotrod.
Re: My 63 Dodge 330 Project: [Re: mopowers] #3270344
11/13/24 08:38 PM
11/13/24 08:38 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Thanks!
Brackets are already aluminum. There’s a post about them a couple of pages back.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #3286143
01/31/25 09:45 AM
01/31/25 09:45 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I decided to pull the carb off and go through it. It’s been on the car close to 10 years now and was still working great but was looking pretty rough and starting to dribble near one of the accelerator pumps. I’m glad I did! All the bolts in it were just finger tight! I bought an ultrasonic cleaner to see how it worked and was pleasantly surprised at how well it cleaned!
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #3286813
02/03/25 09:56 AM
02/03/25 09:56 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I went to start the car the other day after installing the radiator and it made some strange sounds. Keep in mind I had just driven it across town and filled it up with 93 octane.
I pulled the valvecovers off and everything looked fine, even the valley was clean. As I looked closer I saw the head of a valve lodged in the #7 port! shock
After pulling the passenger side head off, we found the culprit. Both seats and valve heads were gone! Apparently the seats fell out WHILE IT WAS SITTING and led to the failure.
This was the last thing I expected to fail in this engine!
The rest of the pistons have some light damage so I'll probably just replace them as well.
'63 Dodge 330
11.19 @ 121 mph
Re: My 63 Dodge 330 Project: [Re: GY3] #3288191
02/08/25 05:30 PM
02/08/25 05:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Member farmboy gave me a great deal on Trickflow 240’s, Track Heat intake and bolts for the install. Building back better already! grin
Pistons and pushrods and I believe we’re in business!
'63 Dodge 330
11.19 @ 121 mph
